Headlight issue
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
2008-2013 Cadillac CTS General Discussion Discussion, Headlight issue in Cadillac CTS Second Generation Forum - 2008-2013; Hi all. New to the forums after just purchasing a 2009 CTS with direct injection a week ago. On the ...
    LastTripToTulsa is offline Cadillac Owners Member
    Automobile(s): 2009 CTS AWD 3.6 DI
    Apr 2013
    Wisconsin
    33
    10
    Headlight issue
    Hi all. New to the forums after just purchasing a 2009 CTS with direct injection a week ago. On the way to work a couple days ago I noticed my left turn signal blinking twice as fast as normal and then after I arrived, my buddy told me I had a healight out. Figured I would check it out after work, but everything was working normal when I got home and stayed working fine for the next three days. Now this morning on my way to work the same issue was occuring. Any ideas what could be causing this? It seemed that the two days it wasn't working correctly were the two coldest days of the week. Could this maybe be a ballist issue? Any help is appreciated.
    Black'10CTS4 is offline Cadillac Owners Fanatic
    Automobile(s): '10 CTS4 Prem 3.6DI, '08 CTS4 Prem 3.6DI, '00 STS
    Sep 2012
    37
    104
    Re: Headlight issue
    Usually, that means you have a taillight out, not headlight. If its not doing it all the time, kinda sounds like a bad connection somewhere.
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V, 2009 CTS Premium, 2016 ELR
    Jan 2005
    California
    329
    Re: Headlight issue
    Does your car have HID headlights? If so, the daytime running light turns off when the blinker is on, so that may be why your friend thought the bulb was out. (It comes back on when you turn off the blinker.)
    Sounds like the filament in the bulb might have broken and then bounced back into place, so it's likely that you'll need to replace the turn signal bulb. I believe the side blinker light being out would also cause the "fast flashing" to warn you that a bulb has burned out. It's unlikely that it's a rear turn signal since those are LEDs.
    If you go to change the turn signals, do some research on here because it's a pain to do. (Technically, you'll supposed to pull the whole front bumper cover off the car, but others have found ways to squeeze their arm in through the fender well covers.) While you're dealing with the bulb replacement, you might consider switching over to LED bulbs so you don't have to mess with it again.
    Good luck!
    Apr 2013
    Wisconsin
    33
    10
    Re: Headlight issue
    It was a little darker when I went in today and I could definitely tell that the headlight was out. Turn signal lights all seemed to be working fine.
    JackB is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS AWD DI 2014 AWD CTS DI
    Oct 2004
    511
    Re: Headlight issue
    I have an 09 as well. There was a headlight connection recall some time ago. When it was fixed they were supposed to replace low beam headlight bulbs as well. You might ask the Dealer if that was done.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: Headlight issue
    Quote Originally Posted by LastTripToTulsa View Post
    Hello LastTripToTulsa,
    Welcome to the forum! I hope you are enjoying your CTS so far. I saw on a later post to this thread you said you could tell your headlight was out and your turn signals seem to be working fine again? I just want to check on the status of your vehicle now and see if it is fixed or if you are still experiencing concerns. Please let me know so I can be of further assistance. Thank you, have a great night!
    Sincerely,
    Laura M.
    Apr 2013
    Wisconsin
    33
    10
    Re: Headlight issue
    Yes I am still having issues. It seems to work 80%+ of the time, but occasionally the one headlight does not turn on, mostly in the mornings it seems. I am not electrically inclined enough to diagnose a short in the wires or anything and really can't afford to spend hundreds of dollars at the dealer to try and have them diagnose it, so it looks like it might just be something I'll have to live with.
    Tbbt is online now Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,133
    Re: Headlight issue
    Last Trip,
    You need to send a private email to Laura M. at Cad Cust. Service, giving her your VIN so she can see if your car qualifies for the active recall on headlight problems!
    Marv
    Apr 2013
    Wisconsin
    33
    10
    Re: Headlight issue
    So I hate to rehash an old thread, but I've started having this problem again. While the driver side headlight was not working intermittently before, it is not working at all now. I have the HID's so my car is not part of the recall. Anybody have any guesses as to whether this is just the case of needing a new bulb or if it's something more? I don't really feel like or have the money to take it to the dealer for them to spend a couple hundred bucks in labor to tell me I need a new bulb, but I also don't want to purchase a new bulb and go through the trouble of replacing to still have it not work.
    Pdabs's Avatar
    Pdabs is offline Cadillac Owners Enthusiast
    Automobile(s): CTS4
    Dec 2011
    NJ
    33
    600
    So put bulb from good headlight into the non working one. If it works, buy a new bulb. If it does not buy new headlight.
    Jschmank's Avatar
    Jschmank is offline Cadillac Owners Fanatic
    Automobile(s): 08 Silver CTS AWD
    Dec 2005
    Topeka, Kansas
    246
    Re: Headlight issue
    I had an HID bulb go out on my 08. Before burning out completely it had a violet shade that was very noticeable. It wasn't intermittent though it was clear when it was going bad. I have experienced more headlight problems with this car than any other vehicle I have ever owned, and anything that needs to be done to the headlights are expensive. Recently my DLR light went out and I decided I would try to fix it myself. It was actually very easy, took about 30 minutes to pull the front bumper and get to the headlight housing. The bulbs arent that expensive, its the labor they charge to get to it that is the problem.
    Mar 2010
    Detroit, USA
    12,674
    Re: Headlight issue
    Sorry for any trouble you are experiencing with your headlight issue. I see other community members have offered advice on the situation. Please keep me updated with this issue and if you would like to further discuss any concerns, reach out to me via private message.
    Regards,
    Laura M.
    Cadillac Customer Care
    Apr 2013
    Wisconsin
    33
    10
    Re: Headlight issue
    Having the car checked out tomorrow. Dealer quoted $300-$400 for a bulb itself without labor and $500+ for a ballist without labor. What a crock.
  16. #14
    Jschmank's Avatar
    Dec 2005
    Topeka, Kansas
    246
    Re: Headlight issue
    I had the high beam shutter go out on one of my 08 HID headlamps. No repair available and had to replace the whole headlight. My dealership, which has been good to me provided the part at a discount and helped with the labor but it still cost me $1000. This has been the biggest expense I have had with the car, but never expected to spend that to get a high beam that you use 3 -4 times a year.
  17. #15
    Pdabs's Avatar
    Automobile(s): CTS4
    Dec 2011
    NJ
    33
    600
    Quote Originally Posted by Jschmank
    I wish you had posted about your problem earlier. You can find cts headlights on eBay for 250-350. It takes 30 min to replace a headlight. Could have saved yourself 600+
  18. Remove Advertisements
