Issue with information display unit on '08 CTS (it changes on it's own randomly)
Results 1 to 2 of 2
2008-2013 Cadillac CTS General Discussion Discussion, Issue with information display unit on '08 CTS (it changes on it's own randomly) in Cadillac CTS Second Generation Forum - 2008-2013; Hey everyone, hopefully someone here can give me some direction on this. I have a '08 CTS sedan with 65k ...
    MustangKid is offline Cadillac Owners Member
    Apr 2013
    1
    Hey everyone, hopefully someone here can give me some direction on this. I have a '08 CTS sedan with 65k and just recently noticed that occasionally when starting up the car and I start to drive the information display unit (the odometer display) just starts cycling and changing through the menus on it's own! If I hit the up/down arrow it will briefly go to the next item on the list but then continue to cycle repeatedly. It's rather annoying and usually within about 15 minutes will stop and work as normal. This will happen maybe 2 out of the 10 times I will start up and drive. At first I thought the cold weather was somehow causing this, but even in warmer weather it's doing the same thing.
    Has anyone else experienced this?
    Is there a way to reset the computer system or is this just an indication of a defective electrical part.
    Thanks.
    caddad08's Avatar
    caddad08 is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS4 DI Hot Lava Edition PDZ AWD FE2
    Jan 2011
    Fishers, IN
    63
    402
    Re: Issue with information display unit on '08 CTS (it changes on it's own randomly)
    Haven't had this issue but hopefully someone on the forum has and will provide some insight as to what it took to eradicate the problem.
