$300 to replace running lamp!
Results 1 to 11 of 11
2008-2013 Cadillac CTS General Discussion Discussion, $300 to replace running lamp! in Cadillac CTS Second Generation Forum - 2008-2013; So my wife's dayime running lamp on her 08 CTS is out. Dealer telling her $200 to replace! Apperently the ...
    LadyCTS is offline Cadillac Owners Member
    Automobile(s): CTS
    Mar 2013
    51
    1
    So my wife's dayime running lamp on her 08 CTS is out. Dealer telling her $200 to replace! Apperently the bumper has to be removed. Is this a difficult repair? Maybe a DIY....
    cadsmeow6 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Nov 2011
    20
    Re: $300 to replace running lamp!
    Yes, the bumper cover needs to be removed to access the headlamp. if the shop is careful they can drop the side they are fixing but most of the fasteners need to come out anyway. Most of the job is removing the bumper cover.
    wmillar is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS DI F3 Sport Suspension
    Aug 2003
    North Texas
    72
    197
    http://www.cadillacforums.com/forums...bulb-part.html
    What you do is open the hood, remove the fittings that holds the top of your grill in place, take the fittings that hold the front fender well in place, if I remember right there is a 10mm bolt that needs to be taken out. You now can pull the lower part of the bumper away from the fender now the grill andlower part of the bumper should be loose. You can now pry it apart enough to see the bolts holding the headlight in place. Remove the headlight and replace the bulb.
    jimihemi is offline Cadillac Owners Member
    Automobile(s): 2009 CTS 3.6Di AWD
    Jan 2012
    Rhode Island
    6
    its not easy i've tried it and given up. i just turn my headlights on all the time for now so it doesn't look like i have a light out. it crazy that it is so laborious and expensive. i may wait until another light goes out and make it worth my while.
    Chris Pelkey is offline Cadillac Owners Member
    Automobile(s): 2009 CTS Blue Diamond 3.6L DI AWD
    Dec 2012
    Fairfax Station, VA
    46
    One of mine went out in November and I talked to my service manager about replacing it. He told me that it would cost around $160-175 to replace it. I told him that I would replace both of them and about the time I was going to bring the car in the light started working again. It just went out again last week. Have to find a pothole to see if it just a loose connection...
    CTS3LSTICK is offline Cadillac Owners Member
    Automobile(s): 2011 CTS 3.0L Manual
    Dec 2011
    7
    I have this down to about 30 mins. I have the standard halogen headlights, and have replaced both lights with Osram Nightbreakers, and replaced the approach lights with LED's
    For me the hardest part was removing the 10mm bolt behind the fenderwell, and even then it was not that hard. 30 to 35 mins, drop the front bumper, take out the headlamp assembly, put it back...
    It looks fabulous.
    like2drive's Avatar
    like2drive is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS RWD 3.6L SFI Black Cherry / Cashmere
    Jan 2008
    Southern CT
    38
    387
    Quote Originally Posted by Chris Pelkey View Post
    Just in case it wasn't done on your car, there is a recall for the low beam connectors. Since it comes as a kit, they also replace the bulbs.
    Bulletin No: CSP-11055
    Date of Bulletin: 03/14/2012
    Summary Description:
    CADILLAC/GMC/SATURN: SEE DOCUMENT SEARCH BUTTON FOR OWNER LETTER. CERTAIN MODEL YEAR VEHICLES MAY EXPERIENCE AN ISSUE OF A LOOSE ELECTRICAL CONTACT WITH LOW BEAM HALOGEN HEADLAMP BULB CONNECTOR WORKING INTERMITTENTLY. *PE
    Dec 2012
    Fairfax Station, VA
    46
    Quote Originally Posted by like2drive View Post
    Thanks, I'll check it out.
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    $200 or $300?
    caddad08's Avatar
    caddad08 is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS4 DI Hot Lava Edition PDZ AWD FE2
    Jan 2011
    Fishers, IN
    63
    402
    My passenger side DRL just went out and I checked with my local auto shop. They want $16 for the bulb and $170 for the labor to replace it. I have the HID assembly
    Dec 2012
    Fairfax Station, VA
    46
    I called Cadillac about this and they researched it and said my car wasn't covered. They did however agree to send me a $100.00 maintenance coupon.
  14. Remove Advertisements
