NAV screen flicker?
Results 1 to 12 of 12
2008-2013 Cadillac CTS General Discussion Discussion, NAV screen flicker? in Cadillac CTS Second Generation Forum - 2008-2013; In the last month my NAV screen has started to flicker under WOT... Anyone seem this? Know why? How to ...
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    NAV screen flicker?
    In the last month my NAV screen has started to flicker under WOT... Anyone seem this? Know why? How to fix?
    Seems electrical to me; battery not holding enough amps... Figured if check here before tearing the dash apart...
    RAB's Avatar
    RAB
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    Re: NAV screen flicker?
    Michael, the intermittent problem could be caused by...
    • A loose connector
    • A poor connection between a male and female terminal at a connector
    • A poor terminal to wire connection
    • Wiring which has been pinched, cut, or its insulation rubbed through
    • Wiring broken inside the insulation
    • A failing Nav screen
    As a first step I recommend you connect a scan tool to the car and check to see if any DTCs have been set.
    Sounds like an intermittent poor connection issue to me, involving either a power feed wire or a communication wire.
    Links to Nav/Infotainment system circuit diagrams (covers both North American and Euro-spec CTS):
    - Nav circuit with surround amplifier pdf file 1 of 4: http://www.mediafire.com/view/?t9qx0wgvb8w1j35
    - Nav circuit with surround amplifier pdf file 2 of 4: http://www.mediafire.com/view/?ppnoipj7xocppeg
    - Nav circuit with surround amplifier pdf file 3 of 4: http://www.mediafire.com/view/?uufu5u4mvhcdstm
    - Nav circuit with surround amplifier pdf file 4 of 4: http://www.mediafire.com/view/?69fvao12wqavee3
    > Circuit depiction of Nav screen (referred to as RADIO/HVAC DISPLAY in diagram) is found at bottom of pdf file 2 of 4.
    May 2011
    Austin, TX
    37
    404
    Thanks RAB!
    You've got way too much time on your hands buddy!
    RAB's Avatar
    RAB
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by Michael_atDell View Post
    Thanks RAB!
    LOL! Yes - evidently I do have too much time on my hands right now! It won't last, so take advantage of it!
    Actually it doesn't take me long to research this sort of stuff. It would take a helluva lot longer for you to tear your dash apart!
    May 2011
    Austin, TX
    37
    404
    Fixed this yesterday at my dad's shop. Must have been a loose connector, nothing was frayed or pinched. Went ahead and lubed the moving parts before I reassembled...
    Palladin is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V
    Mar 2013
    65
    5
    Hey Michael. I have the same problem. Which wires did you recheck and how did you get to the area to lube the parts?
    jimbobucket is offline Cadillac Owners Member
    Automobile(s): 2012 CTS 3.6 AWD Premium
    Feb 2013
    Murrysville, PA
    4
    I'm having the same issue. I have a warranty claim into GM (dealer initiated) but that was 30+ days ago.
    I too am guessing its a loose wire. How did you get the console out/off?
    May 2011
    Austin, TX
    37
    404
    Quote Originally Posted by jimbobucket
    There's a how to post somewhere on these forums...
    Philvette is offline Cadillac Owners Member
    Automobile(s): 2009 CTS4 and 2013 Escalade
    Sep 2013
    Dubuque,IA
    75
    1
    Michael,
    I have the same problem on a 2009 CTS4.
    The screen flickers under accelleration or when the horn is honked.
    The screen works fine under steady driving conditions.
    Which connectors did you check and where are they located?
    Philvette
    BIC
    BIC is offline Cadillac Owners Member
    Automobile(s): 2010 CTS-4 Sport Wagon Premium Collection 3.6L FE2
    Nov 2010
    Midwest
    62
    43
    I have been having this NAV screen flickering or blackout under varying conditions. Very intermittent, which could be a loose connection as you suggest. A month or so ago, the dealer found a tech bulletin or something similar and did some kind of software/firmware update. But, just had it flicker again today. Before I bring it back to the dealer to check the connections, does anybody have any more specific troubleshooting guidance? Thanks.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,710
    Quote Originally Posted by BIC View Post
    Hi BIC,
    I am sorry that you are experiencing this Nav. screen flickering and apologize for any inconveniences it may have caused. I see you are looking for some feedback from the forum. Although I cannot provide any specific troubleshooting guidance, I would like to help look in to this concern. If you choose to head back to the dealership, please PM me your VIN, mileage, dealership, and contact information so I may open a case file on your behalf.
    Have a great night,
    Austin J.
    Cadillac Customer Care
    Panzer Leader's Avatar
    Panzer Leader is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS 3.6 V6 RWD Performance Sedan
    Jun 2012
    Mandeville, Louisiana
    588
    Had same problem on my 2011.....so far, no problem on the 2013....... Sad story on a car that cost this much..... Looking at the Holden Super Sport now. ...... Hey GM, wake up, your quality control is lacking.....
  15. Remove Advertisements
