Gracenote Update ISO Download - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 49
2008-2013 Cadillac CTS General Discussion Discussion, Gracenote Update ISO Download in Cadillac CTS Second Generation Forum - 2008-2013; Thanks RAB for the iso image. @RAB, the vb00.0 info is displayed once the iso disk is loaded, and before ...
  1. #31
    speedbump49's Avatar
    speedbump49 is offline Cadillac Owners Member
    Automobile(s): '11 CTS Coupe RWD
    Jul 2010
    57
    Re: Gracenote Update ISO Download
    @RAB, the vb00.0 info is displayed once the iso disk is loaded, and before you select Update. Once the update was complete the unit was rebooted by the installer. Once i confirm unit was working, I reinserted the disk and the same version number was reported. So I canceled the second upgrade operation and left it at that.
  2. #32
    2sa
    2sa is offline Cadillac Owners Member
    Automobile(s): 2008 CTS Sedan-White Diamond
    Oct 2012
    13
    Attempted this update today. Downloaded the file and burned to a DVD on my Mac. Did not work so I burned another copy. The car does seem to recognize it as a iOS update but is asking for another disc. Audio system is stuck at this screen now. Suggestions?
  3. #33
    RAB's Avatar
    RAB
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by 2sa View Post
    2sa, I don't know if using a Mac to burn the ISO to a DVD has anything to do with the problem you're facing. I've never used a Mac. What burn program are you using? Suggest you use ImgBurn (free download) if it's available for Mac machines, or perhaps consider using a Windows PC having ImgBurn installed.
    I assume you're burning to a DVD -R or +R. Make sure the program is set up to finalize the DVD at the end of the session.
    Note that one of the update files that's extracted from the ISO is a zero byte file, and your Mac /the burn program you're using may not be recognizing/placing that file on the DVD you're creating (just a thought).
    A properly configured DVD should clear the problem /complete the update.
  5. #34
    2sa
    Oct 2012
    13
    Thanks RAB. I will give it another shot with a Windows PC or the program you suggested. Good to know it is correctable.
  6. #35
    2sa
    Oct 2012
    13
    Mission accomplished. Mac Disc utility will get it done...you just have to make a couple of adjustments to settings prior to burning. Appreciate the help and the file.
  7. #36
    Castle Rocker is offline Cadillac Owners Member
    Automobile(s): 2009 CTS
    Jan 2009
    Colorado
    1
    Quote Originally Posted by typo681 View Post
    Hi - I downloaded the iso and burned it to the a USB Flash Drive using the ISOtoUSB program you mentioned. When I put it in my car, I got the "update" or "cancel" prompt, so I hit update, but it didn't do anything, it just said "insert update disk 1 of 1". What am I doing wrong?
    I received the same static message "insert update....". I was trying this with key in Accessory On mode. Then I removed USB drive, started the car, inserted the USB, and this time when I hit "Update" button, the message said "insert update disk 0 of 0", and proceeded to install the update. it took about 10 minutes with the car running.
    Good luck.
  8. #37
    kchevy Guest
    I have the hard drive radio only. Does this update work with the non-nav radio? I put the file (ISO) on a USB drive, inserted it in the USB port and it displayed that it did not contain any audio file? Am I doing something wrong?
  9. #38
    RAB's Avatar
    RAB
    Jun 2007
    Ontario, Canada
    2,108
    ^ kchevy, the update works only with the Nav/Infotainment system (rpo UAV) - it will not work with the non-Nav 40GB HDD system (rpo U2S).
  10. #39
    eborunda's Avatar
    eborunda is offline Cadillac Owners Fanatic
    Dec 2011
    123
    DO you guys know if there is an update (gracenote) for the 08 CTS with NO navigation ?
  11. #40
    popeof2nd is offline Cadillac Owners Member
    Automobile(s): CTS DI
    Dec 2011
    Nashville
    12
    What settings did you adjust in Mac Disc utility?I tried burning the file in Toast and the update would not proceed.
    Thanks..
  12. #41
    kchevy Guest
    Quote Originally Posted by RAB View Post
    Thanks but how would a non nav radio be updated????
  13. #42
    RAB's Avatar
    RAB
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by kchevy View Post
    By using an update disc that's been created for the non-Nav system. Unfortunately such update discs aren't being offered at this time. GMNavDisc offered non-Nav update discs in 2009 and 2010, but I never saw one listed for 2011 or later. Now GMNavDisc is gone, replaced by Navigation.com (Navteq). Suggest you contact Navigation.com and ask about Gracenote update disc availability for a non-Nav system. You might try contacting Gracenote.com for their info & advice, but they'll likely just flick you back to GM (i.e. Navigation.com).
  14. #43
    kchevy Guest
    Thank you for the info.
  15. #44
    2sa
    Oct 2012
    13
    Quote Originally Posted by popeof2nd View Post
    Thanks..
    Sorry, I have been away from the computer. I used the following link for instruction on the Mac Disc utility http://reviews.cnet.com/8301-13727_7-10407910-263.html
  16. #45
    Dec 2011
    Nashville
    12
    Thanks,I ended up just burning at a slower speed on disc utility and it worked fine and the update took about six minutes.
  17. Remove Advertisements
