How reliable are these cars - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
2008-2013 Cadillac CTS General Discussion Discussion, How reliable are these cars in Cadillac CTS Second Generation Forum - 2008-2013; Gas grades aside I was also reading about catalyst convert replacements/ shaking, squeaking breaks that cant be fixed and shaky ...
  1. #16
    thoed.essay is offline Cadillac Owners Member
    Automobile(s): 03 Diamond White CTS Lux/Sports PKG
    Jul 2010
    West TX
    69
    Re: How reliable are these cars
    Gas grades aside I was also reading about catalyst convert replacements/ shaking, squeaking breaks that cant be fixed and shaky steering wheel with rough idling which all issues were ALWAYS a problem with my 03 cts anyone else encounter the same?
  2. #17
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,318
    None here.
  3. #18
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,957
    Quote Originally Posted by M5eater
    the D/I uses regular 87 and makes 300HP.
    the F/I 3.6 is a carry-over, and those engines reccomend 89.
    Thanks...
  5. #19
    like2drive's Avatar
    like2drive is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS RWD 3.6L SFI Black Cherry / Cashmere
    Jan 2008
    Southern CT
    38
    388
    Quote Originally Posted by M5eater View Post
    From my owners manual:
    For the F/I 3.6L (2009 CTS), they say to use regular unleaded gasoline with a posted octane rating of 87 or higher.
    Therefore, they recommend 87 as for the D/I engine.
  6. #20
    somedaycts is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Cadillac CTS4
    Jan 2010
    Michigan
    394
    "If the vehicle has the 3.6L V6 engine (VIN Code 7), use regular unleaded gasoline with a posted octane rating of 87 or higher. For best performance or trailer towing, you could choose to use middle grade 89 octane unleaded gasoline. If the octane rating is less than 87, you might notice an audible knocking noise when you drive, commonly referred to as spark knock. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. If you are using gasoline rated at 87 octane or higher and you hear heavy knocking, the engine needs service."
    The few times I have used 87 there have been noticeable NVH deficiencies. I only use 89 on my car.
  7. #21
    jeffc83's Avatar
    Feb 2012
    Southeastern PA
    1,957
    Quote Originally Posted by somedaycts
    Do you have the non-DI?
  8. #22
    Jul 2010
    West TX
    69
    premium was always in my cts i did notice the idling wasn't as bad when i changed the oil but the catalyst converter was always shaking and kinda embarrassing at a drive threw it sounded like the car was gonna die right there. so has anyone else had this happen in there 08 or the breaks always squeaking?
  9. #23
    Jan 2010
    Michigan
    394
    Quote Originally Posted by jeffc83 View Post
    I do have the non-DI engine.
    Quote Originally Posted by thoed.essay View Post
    There's a service bulletin for one of the rear exhaust hangers due to clunk noises coming from the rear or something like that. I haven't heard of any significant problems with the 08+ exhaust rattling beyond that bulletin. All 08 and certain 09 models had a rear brake squeal issue (mine has it), there's a service bulletin that involves replacing the pads, caliper brackets, and abutment clips in order to mitigate that noise. I also had squeal in the front brakes....my dealer replaced the front pads with aftermarket junk before I bought the car, within a year they were squealing. Since replacing the rotors/pads with OEM parts I haven't had any problems...there's aftermarket solutions that will work just as well. I also had significant steering wheel vibration, which has since been solved after a new set of tires (Bridgestone) and a full front/rear alignment.
  10. #24
    Jul 2010
    West TX
    69
    thanks somedaycts exactly what i needed to know and then some! Not expecting to trade in the tahoe until April but when i do ill let everyone know how it goes!!
  11. Remove Advertisements
