Upgrade my 09 CTS to a bluetooth VCIM
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
2008-2013 Cadillac CTS General Discussion Discussion, Upgrade my 09 CTS to a bluetooth VCIM in Cadillac CTS Second Generation Forum - 2008-2013; I want to put a bluetooth VCIM in my 09 CTS (non nav). I have read so many threads that ...
    rcssr is offline Cadillac Owners Member
    Automobile(s): 2011 CTS COUPE AWD
    Mar 2010
    27
    QuestionUpgrade my 09 CTS to a bluetooth VCIM
    I want to put a bluetooth VCIM in my 09 CTS (non nav). I have read so many threads that my brain is scrambled, but none seem to be case specific to my car. 2 connector, 3 connector, post 2011, pre 2011, Buick, Impala....UGH! Can someone tell me which one will 'plug in' to my car so that my bluetooth will work. Onstar is OK but I won't use it, that said I like everything to work properly if possible. Do I have to buy an antenna or does my car combine the existing one? I am ready to head to the salvage yards but I would love to know what is the correct fit. I know that the ideal fit would be out of a bluetooth 09 CTS but is that my only option??
    Thanks, Bob
    dsteinmann is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS Lux - 2008 CTS DI Luxury Performance II
    Jul 2009
    Ofallon, Missouri, United S
    34
    335
    Yes get one out of any cts 3.6, and if it's after a 2011 then it will have just two antennas on it so you just don't plug in the onstar gps, if you have Nav. On start will still work along with on start app for your phone, on starr just won't be able locate you. What options does your car have
    I Just seen its non nav. So you Should be fine getting any, 3.6 CTS. but if you get a 11+ then you will get the APP, and if you want OnStar to have your location then you will need to switch out the Antenna on the roof as it has the diplexer built in. mine had a free year left as it came off a new CTS So I just left the VIN never attempted to get it programmed. Remote door worked fine also. If you Have Remote start and want the app and get 11+ Get one from a CTS with Remote Start. Or else you will need the VCIM programmed to get the Remote start from your phone working
    Mar 2010
    27
    Re: Upgrade my 09 CTS to a bluetooth VCIM
    Thank you soooo much for your detailed response. My car does not have remote start. If I get a VCIM from a doner with it, will I be able to upgrade that as well? The picture you sent is from an 09? I have not yet removed mine so I don't know what it looks like. Does my wireing look like the one in your pix? Not sure I understand about the antenna thing. I am a pretty good and savy wrench but electronics is not my thing. What is a multiplexer??
    Thanks again, Bob
    Jul 2009
    34
    335
    Quote Originally Posted by rcssr View Post
    Thank you soooo much for your detailed response. My car does not have remote start. If I get a VCIM from a doner with it, will I be able to upgrade that as well? Id Say it probably wont work but who knows The picture you sent is from an 09? That's my 08 With the 11 VCIM Mounted on the rear deck lid I have not yet removed mine so I don't know what it looks like. Does my wireing look like the one in your pix? Should be the Same Not sure I understand about the antenna thing. I am a pretty good and savy wrench but electronics is not my thing. What is a multiplexer?? It basically splits the 2 connections back out to two.Thanks again, Bob
    So If you want onstar to totally work then you would need the antenna off a 11+ (that's if your going after a 11+) But your mileage may vary on getting it programmed to your VIN if that's a concern for you.
    http://www.cadillacforums.com/forums...ml#post2657408
    Heres some more pics from that project.
    danoh123's Avatar
    danoh123 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS 3.6 Premium AWD
    Sep 2012
    Boston area
    167
    How much did you spend for this module? I wonder how much new antenna would cost??? Lastly, I wonder if the dealer would be willing to do this
    leigh1322 is offline Cadillac Owners Member
    Automobile(s): 08 CTS 3.6 D.I. FE-3 6M Red
    Mar 2011
    61
    74
    I spent about $145 for a used '10 vcim. Does not matter if the car hadnav or not. Put it in my 08. Plug n play. BT works flawlessly with my nav. Never activated onstar. Handsfree and voice commands work great. Had to download an '10 instruction manual to get the command list. The bluetooth antenna came with my unit. Plugs into vcim which is under the rear window. $20+ dollars if you need to buy it. The 09 vcim had a software bug that iirc only involved the nav. The '10 mpdel has an update. The '11 model also has the smartphone app which is cool but that is where you get into issues with antenna on the roof as they changed the no. of wires going to it. I ducked that one.
    I have the related vcim model numbers in my files if you want them. But I found them all online.
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,904
    Quote Originally Posted by leigh1322 View Post
    ... Never activated onstar. ....
    How does this all work without onstar activated?
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,957
    Quote Originally Posted by HurstGN
    It simply adds the Bluetooth function to your car...Onstar isn't needed for that to work.
    Mar 2011
    61
    74
    It uses the microphone and speakers from the onstar module, plus the voice command section. Since that stuff was already built into the onstar module, and it is very high quality there was no need to duplicate it, and they added the bluetooth function at that point in the hardware. So it is like an extra chip in the onstar module and the bluetooth antenna hangs out the back of that box.
    So you get high quality mic hardware yet the BT is real easy for us to add.
    frais is offline Cadillac Owners Member
    Automobile(s): 08 3.6 DI
    Jul 2010
    Linden
    27
    12
    So i just came across this . Totally need this in my 08 3.6 cts with no nav. I just want the bluetooth. I attempted to read and understand what you wrote. But I drew blanks. What i got out of it is all i need is to rip off some electrical parts off a cts 3.6 that has blutooth and install it to my cts. then download the language and install some how.
    jeffc83's Avatar
    Feb 2012
    Southeastern PA
    1,957
    Quote Originally Posted by frais
    I'm not positive about this but you may be able to just swap out your VCIM to get Bluetooth...I have the NAV but wouldn't think that would be required for Bluetooth. There's a great thread here that shows you what's involved. I added myself and it wasn't too difficult of a job...few hours and a lot of patience. Just to clarify, this will give you a Bluetooth connection for your cell phone. If you want to stream audio, you'll need to purchase a Bluetooth adapter with 3.5mm adapter for the center console.
    Jul 2010
    Linden
    27
    12
    So this wasn't too difficult? other than taking a chunk of your day. which is fine. Now all i need is a VCIM with bluetooth? If i can find a second gen cts with a VCIM with bluetooth, all i have to do is replace mine with this one? The above post says he had all the features so i think he might of gotten it with more available features.
    jeffc83's Avatar
    Feb 2012
    Southeastern PA
    1,957
    It's not for the faint hearted but not a bad job overall. Yes, I got a VCIM from a 2011 CTS, which disabled my onstar. Did the other guy(s) benefit by more features, no. (i only lost onstar which I cancelled anyway) You want the generation 8 VCIM if you want to keep onstar...I know others have installed different units without losing it but you'd have to search the threads for the model numbers. Lookup "2008 Gen 7 to Gen 8 OnStar" in this forum.
  16. #14
    Xtant12's Avatar
    Xtant12 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS-AWD DI ( Hot Lava Edition )
    Oct 2012
    Island Lake IL
    33
    123
    The issue is not getting the Bluetooth to work, it is the programing. I did ALL THIS, and when I went to the dealer OnStar REFUSED to reprogram the VCIM. So basically if I got in an accident they would look doe a red Saturn vue, not a Hot Lava CTS. Bluetooth worked just fine with just connecting the box. The car has it all wired in, just the 08 doesn't have the plug for it in the Vicm. That's why everyone changes them out.
    Im still pissed off about it. All that money and effort all for nothing.
    I think GM should pony up something for the inconvenience.
  17. #15
    mrconorluby is offline Cadillac Owners Member
    Automobile(s): CTS
    Jul 2016
    3
    I need an antenna and the module for an 09? I'm so confused and read everything for hours..thx
  18. Remove Advertisements
