CTS ambient lighting
Results 1 to 9 of 9
2008-2013 Cadillac CTS General Discussion Discussion, CTS ambient lighting in Cadillac CTS Second Generation Forum - 2008-2013; 2011 CTS Coupe base model, drop the panel under dash but can't find connector. Can anyone help me out?...
    ajg8465 is offline Cadillac Owners Member
    Oct 2012
    3
    Panzer Leader's Avatar
    Panzer Leader is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS 3.6 V6 RWD Performance Sedan
    Jun 2012
    Mandeville, Louisiana
    588
    Re: CTS ambient lighting
    Are you doing the dash kit or floor well lighting?
    Oct 2012
    3
    Just doing the floor wells
    jprop is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    9
    The under dash wiring for the floor ambient lighting was removed sometime during the 2010 model year run. My 2010 does not have it and none of the 2011s have it. Others have installed it by tapping into the dash ambient lighting harness but I'm not sure how that would work if you don't have that dash ambient lighting harness. It does require partial disassembly of the center console to get to the wires and the cutting and splicing of the same. There is some good info here:
    http://www.cadillacforums.com/forums...otwells-3.html
    Also, type "ambient" into the search engine. There are pages of good info on this DIY project. Good luck! Jim
    Oct 2012
    3
    Wondering if the harness can be added
    Can the ambient lighting harness be added?
    Dec 2007
    9
    I'm sure the ambient lighting was part of the main under dash wiring. So, I would guess no, it can't be added; at least not easily.
    davidpariso is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Coupe
    Dec 2010
    Chicago IL
    4
    does the ambient lighting come on when the headlights turn on? Or, does it only work when the dome light is pressed?
    CTSCHICK Guest
    it comes on with the headlights
    Dec 2010
    Chicago IL
    4
    where can I tap into that has power when the headlights go on? I dont have a harness
  12. Remove Advertisements
