Results 1 to 4 of 4
Thread: Caliper specs
    mister bob is offline Cadillac Owners Member
    Automobile(s): 2009 CTS
    Oct 2010
    63
    Caliper specs
    I have a 2009 CTS and am replacing the front brake pads, does anyone know the thickness specs for the front rotors?
    Thanks.
    somedaycts is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Cadillac CTS4
    Jan 2010
    Michigan
    394
    Re: Caliper specs
    If you have a non-CTS-V the minimum discard thickness should be 28.5mm. If you have OEM rotors on your car, MIN THICKNESS xxMM should be part of the rotor casting, cast into one rotor cheek in between the veins, with one letter per vein.
    blankster is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS Premium AWD 3.6 DI (Sold)
    Sep 2009
    Chicago Area
    472
    Re: Caliper specs
    If you are replacing the pads, I would suggest replace the rotors. These are heavier vehicles with a fair amount HP with pretty strong braking. I gave up resurfacing rotors years ago. With all the cycles of wear and heat fatigue etc. its not worth keeping them. Either go with OEM or use some of the higher quality rotors out there like those from Raybestos etc.
  5. #4
    r1concepts's Avatar
    r1concepts is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Dec 2006
    Cerritos, CA
    256
    Re: Caliper specs
    I can help you out with new rotors and pads. I am a vendor on here so I can offer your a forum discount. PM me and I'd be glad to help you out.
  • You may not post replies
