Results 1 to 15 of 15
Thread: Bought a car with different size of tires.- 2010 CTS
    glara0830 is offline Cadillac Owners Member
    Automobile(s): 2010 CTS AWD Performance
    Oct 2012
    1
    Hi.
    I bought a brand new 2010 Cadillac CTS AWD Performance collection on July 2011.
    I just found out that my car has a different size of tires from right and left.
    Brogan Cadillac in Totowa, NJ sold me a car that have differenct side of tires.
    My car is only 6000 miles and i noticed that when i went to get an oil change from other dealer.
    Here's size of tires of Cadillac.
    Left - P235/50R18 97V (front)
    P235/50R18 (rear)
    Right - P265/45R18 (Front)
    P265/445R18 (Rear)
    What 's the danger of using different size of tire like above?
    I know it's not good to have mismatch tire on a car.
    Please advice~~~~
    truckinman is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac STS 3.6
    Apr 2012
    Columbus OH
    32
    1,219
    Well it'll wreak havoc on your spider gears. Those are the gears in your differentials that allow for different speeds while cornering from side to side
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Quote Originally Posted by glara0830
    Hi.
    P235/50R18 (rear)
    P265/445R18 (Rear)
    Please advice~~~~
    At some point, some idiot rotated your tires. Those are the sizes that are supposed to be on your car. But the 235s should be on the front, the 265s should be on the rear...
    Make sure that when you get the tires in the correct place that no one tries to rotate them again. Dealers mess this up all the time with the Vs...
  5. #4
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,036
    Re: Bought a car with different size of tires.- 2010 CTS
    to the CTS forum.
    The above post is my 2 cents....nothing more.
  6. #5
    C&C's Avatar
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,963
    Bring it back to Brogan and tell them that you car has staggered tire sizes and to do as 'Jim' stated; put the 235's on the front and the 265's on the rear.
  7. #6
    Mar 2010
    Detroit, USA
    12,711
    Glara, I'm in agreement with C&C -- bringing this concern to your dealership's attention is your best next step. If you continue to have concerns after taking your CTS back to them, please email me anytime at Katie_Lucille@gmexpert.com and I can contact your dealer on your behalf.
    Best,
    Katie
    Cadillac Customer Service
  8. #7
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by truckinman
    Actually, the rolling diameters of both sizes are practically identical. So spider gears should be fine.
  9. #8
    b4z is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Standard SrX grey/black 2006 GTO
    Mar 2003
    Chas. SC
    54
    1,795
    I r confused. Did any of the cTSs come with staggered tires? Other than the coupe and Vs, of course.
  10. #9
    blankster is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS Premium AWD 3.6 DI (Sold)
    Sep 2009
    Chicago Area
    472
    I believe the tire sizes on the 2010 sedan are same front and rear. Maybe the wheels at some point were swapped with a coupe. I also think the wheel with for the rears on a coupe are different. Also there may be a variation in offset.
  11. #10
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,556
    Aren't the AWD staggered?
    Dunno, I have a RWD.
  12. #11
    Lockhart is offline Cadillac Owners Member
    Automobile(s): 2011 CTS4 3.6 DI Premium Sedan Crystal Red
    Sep 2011
    INDY
    13
    NO..... AWD tires are not staggered. I have 19" all season tires.. 245x45x19.
  13. #12
    tinman's Avatar
    Jul 2006
    9,556
    As I said before I don't know about AWD. Is there any difference between models?
  14. #13
    al williams is offline Cadillac Owners Member
    Automobile(s): '11 coupe-- manual shift-- 1 of 65 built.
    Jul 2010
    California
    76
    Tire Rack lists those tires as the original sizes for the CTS Coupe, with the wider tires in the back. As someone pointed out, they are essentially the same diameter so they won't cause any trouble with your drivetrain or traction control. But with different width on each side, the car might feel a little different cornering hard to the left or to the right, or it might pull slightly to one side or the other when driving straight.
    The coupe has wider rear fenders, so the wide tires might rub the inside of your fenders when you are cornering or going through dips. And there is less room for tire chains. You should at least get the dealer to swap the right front and left rear tires to get the big tires on the back and the small tires on the front.
    You can also have someone read the codes on the build card that is on the bottom of your spare tire cover to see what the factory had in mind when they built the car, and decide what to do based on that. They either intended staggered tires, in which case you should just relocate the tires as above, or they intended matching tires, in which case you might want to insist on replacement of the wrong-sized tires (and wheels if applicable) with what is supposed to be on the car.
    If you stick with these wheels and tires, when you buy new tires, you should measure the width of all of your wheels to make sure that the wheels at each end of the car are the same width.
  15. #14
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    54
    3,350
    Quote Originally Posted by Lockhart
    The AWD coupe does have staggered tires.
  16. #15
    Sep 2009
    Chicago Area
    472
    The staggered tire size dials in some under-steer into the vehicles performance which may be applicable to the characteristics of the coupe and not the sedan.
  • You may not post replies
