problem after replacing ECM
Results 1 to 7 of 7
2008-2013 Cadillac CTS General Discussion Discussion, problem after replacing ECM in Cadillac CTS Second Generation Forum - 2008-2013; 2010 CTS Wagon Premium, was in acccident, and ECM was damaged. I bought a new one and now the car ...
    dansauto is offline Cadillac Owners Member
    Automobile(s): 2010 CTS
    Oct 2012
    4
    2010 CTS Wagon Premium, was in acccident, and ECM was damaged. I bought a new one and now the car wont start? I read it needs programming but shouldnt it still turn over? I checked pin outs and it seems like the BCM is not sending signal to the ECM for the starting sequence? The BCM is orginal and programmed (everything works and the theft light goes out) any thoughts? Anyone know where the BCM is located also?
    jghiller's Avatar
    jghiller is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Sedan Lux Silver Coast
    Aug 2008
    SC/NJ
    1,382
    Re: problem after replacing ECM
    Take it to dealer. Contact them to come get it if necessary or use roadside assistance(warranty/Onstar).
    Oct 2012
    4
    no warrenty due to accident, I have a garage and pretty handy, so before I spend $120/hr I want to check as much myself. I did jump the relay and the starter cranks, but no fuel or spark. I know I have to take it to the dealer to program the ECM, but if I have some other issues I want to fix them before I take it to the dealer.
    thanks
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by dansauto View Post
    thanks
    Dansauto, I can appreciate that and am very sorry that you were in an accident. If you do decide to involve the dealer and would like me to contact them to follow up for you, etc., please don't hesitate to email me at Katie_Lucille@gmexpert.com for further assistance.
    Best,
    Katie
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    thanks
    I'd take it to a dealer so they can hook up the Tech-II and perform diagnostics.
    Or buy a Tech-II yourself.
    Normal mechanical or electrical diagnostics here will not work. You need DTC's.
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    60
    2,541
    Quote Originally Posted by M5eater
    Normal mechanical or eletrical diagnostics here will not work. You need DCT codes.
    +1 on this one. Today's cars are complicated and troubleshooting of electronics requires specialized tools.
    Oct 2012
    4
    fyi, I found out when you replace the ECM the car will not Crank or start until it is reprogrammed.
  10. Remove Advertisements
