Investigated Door Lock Actuator for Repair/Fix - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 40
Like Tree6Likes
2008-2013 Cadillac CTS General Discussion Discussion, Investigated Door Lock Actuator for Repair/Fix in Cadillac CTS Second Generation Forum - 2008-2013; Only an engineer could figure that one out. Wait a minute here, Zeevert IS an engineer! Awesome write-up!!!...
  1. #16
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,957
  2. #17
    HurstGN is online now Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,764
    Re: Investigated Door Lock Actuator for Repair/Fix
    Quote Originally Posted by zeevert View Post
    ... much great detail removed ...
    Reassembly is almost the reverse of disassembly.
    I like to connect the two lock rods first. Make sure you don’t “trap” the 3rd rod behind the latch.
    Push the electrical connector on, WHILE pushing the red/burgundy lock clip back in.
    Attach the latch to the door with the two torx screws.
    THEN you can attach the 3rd rod by closing the yellow clip. You need to do this connection AFTER attaching the latch to the door.
    Push the cable thru the plastic inner cover and connect the yellow clip to the door.
    Connect the cable to the door panel / door handle.
    Now you need to be careful and gentle. There are two long, white alignment pins on the door panel. I managed to break one of them, and I broke the plastic trim around the inside door lock button.
    Hook the door panel over the door lock button and the window ledge.
    Gently align the two alignment pins in their holes, then firmly press the door panel to the door on the 8-9 clips.
    Now you can actually test your door lock and latch.
    Install the three Phillips head screws, and the two covers.
    Well, that will never get you a job writing manuals for GM. You simply state reassembly is the reverse of disassembly and the customer is on his own.
    Seriously, very nice writeup.
  3. #18
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,547
    Quote Originally Posted by HurstGN View Post
    Are you kidding me? It is most probably exactly what GM has spec'd for their Technical Writers!
  5. #19
    felix711's Avatar
    felix711 is offline Cadillac Owners Fanatic
    Automobile(s): 2017 ATS V
    Feb 2005
    Phoenix, Arizona
    253
    Question? Im also having door lock issues. I have keyless entry and the door I am having trouble with is the drivers passenger. Sometimes I cant unlock the drivers passenger door, either with the keyless entry or with the unlock button on the drivers door or the drivers door handle. Is my problem with the drivers door lock actuator or the drivers passenger door lock actuator? Thx
  6. #20
    jeffc83's Avatar
    Feb 2012
    Southeastern PA
    1,957
    Quote Originally Posted by felix711
    Passenger based in what you've described.
  7. #21
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,710
    Quote Originally Posted by felix711 View Post
    Hello felix711,
    I am sorry you are experiencing an issue with the door lock actuator on your kelyess entry and on the door handle. I see you have engaged with other forum members on here and are looking for advice. If you would like the opportunity to further discuss your situation with us, please reach out via private message. We look forward to hearing from you.
    Sincerely,
    Laura M.
    Cadillac Customer Care
  8. #22
    George Ware is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS & 2006 Cadillac STS
    Oct 2008
    El Paso Texas
    57
    37
    Thanks guys!
    I have issue with my 2008 CTS.
    I have to use the key my door will not open.
    my VIN# is 80118935
    I'm also having issues with the rear drivers side passengers side door.
    George Ware
    macmoney@elp.rr.com
  9. #23
    Mar 2010
    Detroit, USA
    12,710
    Quote Originally Posted by George Ware View Post
    Thanks guys!
    my VIN# is 80118935
    George Ware
    macmoney@elp.rr.com
    Hello George Ware,
    I am sorry for the door lock issues you are experiencing with your CTS. If you would like to further discuss your current situation with us, please reach out via private message so we can work towards a resolution together.
    Sincerely,
    Laura M.
  10. #24
    zeevert's Avatar
    zeevert is offline Cadillac Owners Fanatic
    Automobile(s): Sold my 2009 CTS4 and my 2004 CTS
    Dec 2007
    Brighton, MI
    60
    121
    If a door will not lock/unlock with the remotes or the inside switch, and the other doors lock/unlock normally, I'd say that chances are it's the lock/latch in the non-functioning doors.
    I would have to unlock and lock my door with the key. The door would not automatically lock when driving. You could lock and unlock using the manual knob near the window.
    I suspect this is a fairly common problem for the CTS, because there are several part numbers and there are a bunch of used lock/latches available on Ebay.
  11. #25
    cd24747's Avatar
    cd24747 is offline Cadillac Owners Member
    Automobile(s): 07 Escalade EXT 09 CTS4
    Sep 2007
    Camillus N.Y.
    60
    Sorry if this has been asked but in my 09 cts4 both front doors will not open unless you stick the actual key in, turn it and then pull on the door. Is this the fix for that? Anyone got part numbers for both sides?
  12. #26
    tinman's Avatar
    Jul 2006
    9,547
    Look on any parts site. GMpartsdirect or rockauto or call Chris at Rippy Cadillac - you can find his number on the right hand side of this Forum as they are supporters of this site.
  13. #27
    cd24747's Avatar
    Sep 2007
    Camillus N.Y.
    60
    Quote Originally Posted by tinman
    Does that sound like the problem?
  14. #28
    tinman's Avatar
    Jul 2006
    9,547
    I have no clue. You asked for part numbers so I tried to help. Gm parts direct has exploded view diagrams if you can drill down to the correct parts.
  15. #29
    cd24747's Avatar
    Sep 2007
    Camillus N.Y.
    60
    Ok. Thanks.
  16. #30
    tinman's Avatar
    Jul 2006
    9,547
    You're welcome.
  17. Remove Advertisements
