Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 59
Thread: 3.6 V6 timing chain replacement
  1. #16
    like2drive's Avatar
    like2drive is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS RWD 3.6L SFI Black Cherry / Cashmere
    Jan 2008
    Southern CT
    38
    390
    Re: 3.6 V6 timing chain replacement
    Sorry for the duplicated post...could not erase it!
  2. #17
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,549
    Quote Originally Posted by Surfstix View Post
    Why doesn't Cadillac use full synthetic oil?Too expensive I'd rather pay if I knew they actually put it in the car who knows whats in there when they do it unfortunately I can't do it myself due to injuries so I am held hostage by the crappy dealers who still can't fix the rough idle at start up that's how they run when cold so I'm told, they did the timing chain on mine at 16,000 miles.We don't have many dealers in Suffolk County NY that are worth much or are even trusted by me that they are doing the work and not giving it the fresh air treatment camera's are next I'm sick of excuses.No more Cadicraps for me my wifes SRX sounds like the exhaust is going to blow off the car when you step on it and what a slug that thing is can't get out of it's own way.
    What makes you say that the dealer doesn't use full syn oil?
  3. #18
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,847
    In the V8's they should, but dexos rated syn blend is in most V6's and some dealers put in conventional.
  4. #19
    mjf2802 is offline Cadillac Owners Member
    Automobile(s): xt5
    May 2008
    pa
    13
    my chain was replaced under the same circumstances at about the same mileage. made a world of difference in overall performance and sound of engine. i always thought i heard a knock at slow speed. after the new chain was installed no more.
  5. #20
    CTATDOT is offline Cadillac Owners Member
    Automobile(s): NONE
    Sep 2012
    5
    New to Caddy so this timing chain issue is perhaps troubling to here - we have a 2012 cts wagon 3.0 rwd. Is this engine prone to timing chain issues? Is so, what's are the initial symptoms to watch for?
  6. #21
    jkfcb01 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Sep 2010
    27
    I'm hearing knocking as well at just under 60k but when tech rode in the car with me he said it sounded like engine knocking and suggested different gas. I've only ever ran supreme in it and tried running 3-4 tank fills through from different brands of fuel but same result.
    It's gotten worse over the last few months and I find it hard to believe that this type of engine would knock around 1800-2100 rpm and get worse unless something were failing. My '91 Nissan240SX never made any such noise and this is a bit more advanced I'd say...
    I could understand if I had put lower octane fuel into the car but I haven't. Have a long road trip coming up next month so I hope they can take care of it by then!
  7. #22
    Tri-SS's Avatar
    Tri-SS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V, 2011 CTS-V
    Feb 2008
    Southern Ontario, Canada
    168
    What model years are prone to this issue? My car was a December '09 build, should I be on alert?
  8. #23
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,847
    2011 and newer should have the improved design, 2010 and older are prone to the issue.
  9. #24
    tinman's Avatar
    Jul 2006
    9,549
    I thought it was 2010 and newer, 2009 and older are prone to the issue. My opinion, and that is all it is, is based on what I have read on this site and has no real world experience.
  10. #25
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,847
    Some early 2010 we find have the old design...but to be certain, all 2011 & up are the new style.
  11. #26
    tinman's Avatar
    Jul 2006
    9,549
    Wonderful. I love not knowing something important about my car.
  12. #27
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    61
    2,541
    Quote Originally Posted by SC2150 View Post
    The "new" design adresses chains or the engine? I am asking as my chains were replaced not that long ago....
  13. #28
    rcmunir is offline Cadillac Owners Member
    Automobile(s): CTS 08
    Nov 2011
    Hamilton
    26
    61
    I am having the same symptoms with my 2008 CTS. It has around 124,000KM. No mods done to the engine just a magnaflow exhaust. I have no Check engine light but i can hear engine noise at low rpm and with the hood open during idle a obvious ticking sound. The engine noise is progressively getting worse and can best describe it as spluttering. I tried to change fuel types to see if it would go away but that didn't do anything.
    I am also getting a lot more carbon build up in the exhaust pipes. I am taking the caddy in on Wednesday to get it checked out as my warranty expires end of the month.
  14. #29
    Mar 2010
    Detroit, USA
    12,711
    Hello folks,
    If you have timing chain concerns and want for us to check into this further with your dealership, we're available to you. Please contact us either via private message or email (katie_lucille@gmexpert.com) with more details (including your name and contact information, as well as the last 8 digits of your VIN). Those of you writing from Canada, you can reach GM of Canada at 1-888-446-2000 (Hours: M-F 7:30am - 11:30pm, Sat 7:30am - 6:00 EST).
    Sarah (Assisting Katie), Cadillac Customer Service
  15. #30
    Nov 2011
    Hamilton
    26
    61
    Took the caddy into Leggat in Burlington--- great service! Way better than the GM folks in hamilton at John Bear!!
    They are saying everything is fine but asked me to come and show them the noise im hearing at low RPM to be sure. Also for those of you in CANADA according to service rep at Leggat GM, he said the timing chain is covered up until 2017 or 193,000 KM if it decides to fail even after having the recall done.... that is a good piece of mind as my factory warranty is up at the end of the month!!
  • You may not post replies
