Anyone having Issues With the Tilt Steering?
Results 1 to 4 of 4
2008-2013 Cadillac CTS General Discussion Discussion, Anyone having Issues With the Tilt Steering? in Cadillac CTS Second Generation Forum - 2008-2013; 2010 CTS Premium - Mine on occasion will stop in "auto" mode (stays almost full up) or sometimes when I ...
    blankster is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS Premium AWD 3.6 DI (Sold)
    Sep 2009
    Chicago Area
    472
    2010 CTS Premium - Mine on occasion will stop in "auto" mode (stays almost full up) or sometimes when I use the lever to move it down it takes several attempts to get it to move. Seems like it binds once and awhile during the top third of travel. Of course every time I bring this up to the dealer the infamous "cannot duplicate" response is what I get
    TeamZambo's Avatar
    TeamZambo is offline Cadillac Owners Fanatic
    Automobile(s): Crystal Red 2008 CTS FE2, Pearl 2010 ESV Plat
    Jun 2010
    New Mexico/Illinois/Mexico
    34
    216
    Re: Anyone having Issues With the Tilt Steering?
    I had this issue, it was the plug that was getting snagged when the wheel was coming out and up.
    Sep 2009
    Chicago Area
    472
    Well the dealer replaced the memory module and that worked for several weeks but now its beginning to loose the memory position again. Very frustrating. I suspect the tilt steering mechanism is giving false positions to the memory module or the steering motor(s) themselves are binding. I think this problem has been going on for about 2 years. This has really been the only issue I've had that was not fixed right the first time. The real frustration is the problem is intermittent and as usual the dealer cannot duplicate. I wish someone from engineering could provide some input.
    Sep 2009
    Chicago Area
    472
    After I posted 10/1 about the problem coming back, I actually went under the dash and lubed the worm gears that drive the tilt steering. Problem solved! I suspect that the lack of gear lube caused the mechanism to bind a bit making the module think it was at full down or obstructed when it was not. Anyway I will have to mention it to the dealer when I'm in for an oil change.
  7. Remove Advertisements
