Trunk Leak Problem
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
2008-2013 Cadillac CTS General Discussion Discussion, Trunk Leak Problem in Cadillac CTS Second Generation Forum - 2008-2013; I searched the forum and could only find information about leaking trunks during normal rain. My trunk seems to only ...
    HansK is offline Cadillac Owners Fanatic
    Automobile(s): '08 CTS4 Blue Chip
    Aug 2011
    Denver
    33
    181
    Trunk Leak Problem
    I searched the forum and could only find information about leaking trunks during normal rain. My trunk seems to only leak when high pressure water is applied to it. So whenever I run it through an automatic car wash or wash it myself, I open the trunk and have water pouring inside from under the upper mat in the trunk.
    Has anyone else had this problem?
    The arrows on the attachment indicate the location water comes out when I open the trunk (not a picture of my care, just an example trunk)
    928S is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS 3.6L DI RWD, GMPP new engine 11/2013
    Oct 2005
    USA
    2,092
    Re: Trunk Leak Problem
    Hi HansK,
    Most likely water penetrating around 3rd brake light (CHMSL) and/or, less likely, license plate grommets...pooling inside trunk lid liner...then leaking down when you open trunk.
    My dealer's repair order says, "See Bulletin PIC5004A Water Leak In Trunk...Sealed CHMSL Harness and Replaced License Plate Grommets."
    TIP: When opening trunk lid, always pull up on decorative chromed molding above license plate, never the CHMSL; and, when closing trunk lid, pull down on righthand interior handle, never the CHMSL.
    Hope this helps.
    Aug 2011
    Denver
    33
    181
    Thanks, I will have them check it out next time I stop by the dealership.
    somedaycts is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Cadillac CTS4
    Jan 2010
    Michigan
    394
    x2, CHMSL and/or license plate grommets are at fault. My car experienced this, the dealer sealed both areas.
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,956
    Quote Originally Posted by somedaycts
    x3...guess it's a common issue. (Bone dry now) Make sure they dry out your carpet properly. My dealer pulled it right out but offered new carpeting if it developed a bad odor.
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,666
    Quote Originally Posted by HansK View Post
    Glad to see the community members were able to provide you with such helpful feedback, HansK! I look forward to your update, whenever you get the chance to have it checked out in the future.
    Best,
    Katie
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V, 2009 CTS Premium, 2016 ELR
    Jan 2005
    California
    326
    I've had the same issue, HansK. The dealership replaced the release button for the trunk shortly after I got the car because the "springiness" of the membrane button had quickly worn out. (They replaced it with a much cheaper feeling button that was a completely different design and has no spring to it whatsoever -- it's perfectly flat now.)
    Ever since the repair, when it rains or when I wash the car, the inside cavity of the trunk lid fills with water, which pours out the areas you highlighted in your photo when I open the trunk. I've had so many poorly done repairs at my dealership that I'm waiting until I make a special trip to a different one to have this and a laundry list of other problems fixed.
    Mar 2010
    Detroit, USA
    12,666
    Quote Originally Posted by reciprocity View Post
    reciprocity,
    I'm sorry to hear that you are not satisfied with some of the repairs that have been performed at your dealership in the past (including the trunk matter); if we can ever look into anything for you, please don't hesitate to send us a private message here of the forum with the last 8 digits of your VIN.
    Regards,
    Sarah (Assisting Katie)
    roggy's Avatar
    roggy is offline Cadillac Owners Fanatic
    Automobile(s): 95 STS, 02 STS, 08 CTS
    May 2005
    Toronto, Canada
    106
    I also just got this fixed. Its a bulletin so don't worry about being charged.
    My invoice reads Bulletin: PI0346C
    My service adviser said it was both the third brake light but moreso the license plate mounts. I had the same problem as soon as I took it for a car wash & I open the trunk and water would leak from under the top trunk carpeting liner. Would also be wet near the handle to close trunk.
    Since then not a drop. They resealed the third brake light and plate mounts.
    ctsfan2009 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS4
    Aug 2011
    240
    I've had mine in twice for a trunk leak, both times the driver side of the trunk would be damp after being in rain or a car wash. First time, they resealed the trunk as per the TSB. Didn't fix it. Had it in last week and they said one of my sunroof drains had come detached and this was causing the water and they resealed the drain tube. They also replaced the carpet. The car has not been in any significant rain since them so only time will tell if that fixed it.
    rchern is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Crystal Red CTS Coupe with Ebony Interior
    Dec 2006
    Mount Kisco,NY
    448
    I noticed that on the inside of the trunklid that there are drainholes but they are plugged up with rubber plugs. I'm not quite sure why there are drainholes with plugs in them.
    celmem is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS 2.0T
    Feb 2012
    SE Lake Michigan
    110
    Not too happy with my CTS right now. In the shop for this:
    1. Bad wheel speed sensor. Which shuts all the drive safety features (stabilitytrak, anitlock etc.)
    2. Trunk Leak
    3. Rear "thumping" noise over bumps at low speed.
    I assumed all of this was warranty. but noooo! I would have thought 1 and 3 were drivetrain and 2, corrosion. I told them just fix no. 1 because I'll have to in order to unload this vehicle for a Honda.
    Not happy.
    (they are, supposedly, giving me a credit for the sensor - still $200 however).
    jeffc83's Avatar
    Feb 2012
    Southeastern PA
    1,956
    Quote Originally Posted by celmem View Post
    2. Trunk Leak
    Not happy.
    Regarding your trunk leak, there's a good chance your sunroof drains are clogged. (Mine were but the dealer replaced everything under btb warranty anyway) I haven't had the issue recur in over a year now and check the drains once a month.
  16. #14
    thavil is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Black Cherry Cadillac CTS4
    Nov 2011
    Southern Maryland
    121
    Celmem - Another possibility for your trunk leak could be the third brake light. Mine leaked and they replaced the light and haven't had a leak since.
    For your thumping/clunking noise over bumps, this is a known issue. Your rear suspension knuckles need to be replaced.
  17. #15
    like2drive's Avatar
    like2drive is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS RWD 3.6L SFI Black Cherry / Cashmere
    Jan 2008
    Southern CT
    38
    385
    It has been a very wet week end in the northeast (the wettest since I have this car) and when I opened my trunk lid this morning (car was kept outside all week end!!), I could ear water rolling in the trunk lid. Moreover, the water would leak from under the trunk liner as shown in the OP. After finding and reading this thread, it appears that there is a TSB for this. What happens when the car is out of b2b warranty?
  18. Remove Advertisements
