Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: Ac mold smell
    kenny5533 is offline Cadillac Owners Member
    Automobile(s): cts
    Apr 2012
    1
    Ac mold smell
    I have a 2008 cts and the ac smell very bad when running for a while and then turn off. I always run on the fresh air setting to eliminate any moisture but cant figure out wht it still smell. Anyone have this problem
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,555
    Re: Ac mold smell
    There was a recent thread where someone had clogged drains from their evap (I think it was). Maybe you have a similar problem. In that thread was a diagram of the system and how to clean out those drains.
    Maybe someone else will chime in with additional info and thoughts.
    Mar 2010
    Detroit, USA
    12,711
    Re: Ac mold smell
    kenny5533,
    I am not seeing any general information on this mold smell you've described in the resources I have here; have you had it looked into in the past?
    Regards,
    Sarah (Assisting Katie)
    Cadillac Customer Service
  5. #4
    RAB's Avatar
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    Re: Ac mold smell
    ^ Hey kenny5533 - At the Auto Repair Reference Center site I located an instruction to eliminate air conditioning odor (AC mold smell) on the 2nd Gen CTS. The procedure calls for deodorizing the evaporator core using a Deodorizing Aerosol Kit. Below I've included a link to the instruction pdf that I've uploaded to my account at MediaFire:
  6. #5
    tinman's Avatar
    Jul 2006
    9,555
    Re: Ac mold smell
    RAB, good info, but is this GM's bandaid or is it a cure? What would be the underlying cause?
  7. #6
    exm22psu is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS DI AWD Premium
    Apr 2009
    46205
    45
    585
    Re: Ac mold smell
    I had a mold smell and changed the cabin air filter and it went away.
  8. #7
    RAB's Avatar
    Jun 2007
    Ontario, Canada
    2,108
    Re: Ac mold smell
    Quote Originally Posted by tinman View Post
    tinman, thanks. I'd be hoping it would be more of a cure than a bandaid, given the "deodorizing aerosol" spray is applied directly to the evaporator core. The question that remains is.. what are the actual contents of the aerosol can? If it's only a deodorant then the job would likely be just a bandaid fix. If the spray contains anti-mold/anti-fungal agents, then that would tend to act as a cure. I've never tried this particular procedure yet - haven't had to - but it may be an option for those experiencing frequent or persistent AC mold smell.
    As to the underlying cause.. air conditioning systems of all types are unfortunately prone to the problems of mold & fungi formation & propogation. I suppose the main issue in the CTS is that the evaporator core remains cold for a little while - but more importantly wet for a long time after the car and HVAC system have been turned off. One way automotive engineers could deal with this issue is to have the HVAC blower continue to operate for several minutes after the car has been turned off, to help remove all humidity from the evaporator. The problem (AC odor) is of course worse in certain parts of the country where ambient temperatures and levels of relative humidity are higher than average.
  9. #8
    caddad08's Avatar
    caddad08 is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS4 DI Hot Lava Edition PDZ AWD FE2
    Jan 2011
    Fishers, IN
    64
    402
    Re: Ac mold smell
    Personally, I would try a cabin air filter change as a first step since it only takes 10-15 mins to do unless there is no mold smell when the system is running in heat or fresh air.
  10. #9
    RAB's Avatar
    Jun 2007
    Ontario, Canada
    2,108
    Re: Ac mold smell
    Have to say that a cabin air filter change-out does nothing for AC mold smell.. and that includes the Fram "Fresh Breeze" so-called deodorizing filter which I have learned from experience as being all hype and providing no particular benefit. I was happier with the WIX OEM filter I had purchased for my previous '09 CTS. The OEM filter has a greater number of folds (compared to the Fram) and provides a greater area (more squares inches) of filter media.
  11. #10
    TX_09CTS is offline Cadillac Owners Member
    Feb 2012
    54
    38
    Re: Ac mold smell
    My 2009 had been previously owned by a smoker. Dealer had detailed interior, changed cabin filter, etc but couldn't get rid of odor entirely. They knocked about $1500-$2000 off the price & it had only 20K miles on it, so I figured I could get rid of it. I shampooed carpets, cleaned headliner, all glass, used Lysol & Ozium to directly into ventilation system (from cabin filter location), but I couldn't get the smoke odor 100% out of there. I had to about 97% gone after all that work, then I used the magic bullet (product) that got rid of all smoke odors & left car smelling great. It's called Autoshocker and works great. http://www.autoshocker.com/
    It will leave a slight "bleachy" smell for a day or 2 after the treatment, but my car was completely odor-free afterwards.
  12. #11
    jeffc83's Avatar
    jeffc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS4 DI Premium (SOLD) / 2013 XTS Luxury (TOTALLED) / 2015 BMW 328i XDrive Lux
    Feb 2012
    Southeastern PA
    1,957
    Quote Originally Posted by RAB
    Damn, looks like I'll be replacing my pos Fram filter then...even with just a few hours of use. I knew I shouldn't have purchased that. I'm not experiencing any odd odors but want nothing but the best for my CTS Thanks RAB.
  13. #12
    RAB's Avatar
    Jun 2007
    Ontario, Canada
    2,108
    Re: Ac mold smell
    Quote Originally Posted by jeffc83 View Post
    LOL! Jeffc83, the Fram filter isn't necessarily a p-o-s ... it just doesn't do, IMO, what its name (Fresh Breeze) and its description /marketing hype would have you believe. I've found the [Arm & Hammer] baking soda that is apparently impregnated into the surface cells of the Fram filter media does nothing to improve the quality (read "smell") of outside air drawn into the cabin. The fact that the Fram filter uses less total filter media (fewer folds) than the OEM micronAir filter [offered by a few companies under varying part numbers] means the Fram filter will likely become dirt-loaded and require change-out far sooner than the OEM filter. But that of course assumes that the Fram filter's "micron rating" is the same as the OEM filter. Fram may have messed around with their filter media's micron size/rating in order to get the baking soda to stick/impregnate, which means their filter may not be catching some of the smaller particles the micronAir OEM filter is capable of doing.
    I wouldn't pull out the Fram filter if it's relatively new (I'll leave mine in for now), but I'll be going back to the OEM filter at the next cabin filter change-out. I may experiment with a scented dryer sheet - place it at the intake side of the filter - as a way to deodorize (or rather odorize) incoming air. The nice odor may end up being way overpowering.. so my experiment could well be short-lived!
  14. #13
    jeffc83's Avatar
    Feb 2012
    Southeastern PA
    1,957
    Lol, I guess I'll wait till the next air filter change. Nice idea with the dryer sheet but I still enjoy the new car/leather scent. (for now)
  15. #14
    BobbyandRyan's Avatar
    BobbyandRyan is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS Premium 3.6
    Sep 2010
    110
    I changed my cabin air filter in both my CTS and my wife's car. Both had mold smell and black in spots. When filters were out I cycled a can of Lysol directly into the intake. Replaced with new filters and problem solved. I did make sure I had proper drainage in both.
  16. #15
    RAB's Avatar
    Jun 2007
    Ontario, Canada
    2,108
    Re: Ac mold smell
    ^ Based on BobbyandRyan's incredible findings, please disregard GM's (and my) recommendations to deal with chronic/recurring AC mold smell. Damn.. how could we have been so wrong on this? All that's needed is a change-out of your foul-smelling moldy old filter and emptying a can of Lysol into the cabin air intake.. and Voilą! Apologies for providing info and a link to what is clearly nonsense.
  • You may not post replies
