Successful navigation swap into a non Nav CTS - Page 7
Page 7 of 29 FirstFirst 1234567891011121314151617 ... LastLast
Results 91 to 105 of 424
Like Tree16Likes
2008-2013 Cadillac CTS General Discussion Discussion, Successful navigation swap into a non Nav CTS in Cadillac CTS Second Generation Forum - 2008-2013; I already had Bluetooth before so after the install it still worked....
  1. #91
    rudeboyspi is offline Cadillac Owners Fanatic
    Automobile(s): 2008 cadillac cts
    Mar 2012
    157
    Re: Successful navigation swap into a non Nav CTS
  2. #92
    Mar 2012
    157
    Update
    Voice guiedance isn't working also voice commands. I get clear sounds from radio, cd,USB, DVD and Bluetooth. I think it might have some to do with voice discrete and drain. Those are on the amp x3.
  3. #93
    Mar 2012
    157
    Hi 1968vert
    Does voice recognition worked for you? I did find the connectors for it on the 20 pin connector, they are a pink and pink/black wires. I don't know were it connect back to. Cannot locate we're to connect them. If any one can help. But my Bluetooth works fine. Hey 1968vert it seems like I am also getting low volume from my left front speaker. I look over the connectors and still same thing any ideas?
  5. #94
    Mar 2012
    157
    I think i found the 2 wires. They are on the right front by the door panel. I will test it later. i still don't know why voice guidence isn't working, could it be the VSS signal?
  6. #95
    1968vert is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    72
    Rude boy, I'm not sure about the extra wires coming from the 20 pin connector. That is one part of the installation a need to finish. What does the voice recognition do? I think there's a missing microphone that goes into the overhead console. I know my car doesn't have any
  7. #96
    Mar 2012
    157
    Quote Originally Posted by 1968vert View Post
    The voice recognition lets you push the button on the steering wheel and then you speak what you want the Nav/radio to do. I did have that with my bluetooth setup with my original radio. I do have a mic in my car because I have bluetooth. I will let you know, if I worked it out. I did find the wires but haven't tried it. I am still trying to figure out my speaker issues. i kept my orignal 8 speakers but some wires to the AMP X connectors are missing. I am still working on that. Can you post a pic of your AMP X wiring, so that I can see what I am missing?.
  8. #97
    Mar 2012
    157
    I got turn signals and the door chime sounds now. I will be doing more testing.
  9. #98
    Mar 2012
    157
    does anyone know what the center channel low audio signal(-, +) used for on UQS. hey 1968vert did you also run those wires to the AMP x4? I am wondering if that is the reason why I am not getting any sound from navigation guidenace for turn to turn directions. please reply ASAP. thanks
  10. #99
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,299
    I don't know where the mileage info is stored, but I have OBD ecometer in my car, and whatever data it gets through the OBD port, the ecometer does its own fuel economy calculations onboard.
  11. #100
    Mar 2012
    157
    Hey 1968vert
    I finally got the screen to go up and down automaically after turning car on and off. I was tapping into the wrong power wire by the door panel. I am still waiting on the pic of the AMP wiring, so that I can compare it to mine. I got a problem with sound not coming from front left tweeter and driver speaker, still not getting navigation voice command(No sound from that lovely lady). I do get the pause in the volume but cannot hear the info. Any help from anyone would be great.
  12. #101
    Nov 2007
    72
    Rude boy,
    Did you connect the set of wrapped wires coming the 20 pin connector? I have yet to do them so I don't know what they do yet. My guess is that those wires are for the guidance. I guess I haven't really noticed if my front left speakers are working. I have to check it out. I know, for sure, that we will have to run separate circuits for the tweeters. What did you do to get the door chimes and turn signals?
  13. #102
    Mar 2012
    157
    Rude boy,
    I didn't connect the set of wrapped wires coming from 20pin connector. So you are not getting voice guidance from your NAv? They worked but they are very low volume. Well for the door chimes and signals is a little tricky. I got them to work but you will get a popping sounds intermittently from the very front left speaker by the defrost vent. i took the gray and tan wire from amp 1x and connect them to AMP 2x pin 4&5. I notice that they are the same on the wiring diagram. check it out. I get louder sounds but popping sound from front left speaker. I chang it back because it sound better the other way. I don't care about the door chimes or signal. i do need that voice guidance from the nav.
  14. #103
    rcmunir is offline Cadillac Owners Member
    Automobile(s): CTS 08
    Nov 2011
    Hamilton
    26
    61
    hey any updates on how all of this is going for you?
    You guys should do a write up of what you need and how to do it, im sure a lot of people would love that.
  15. #104
    Mar 2012
    157
    Quote Originally Posted by rcmunir
    I know how you feel but I still have a few issue that need to be worked out. I am still having issues with my speakers and also not getting any voice guidance from the navigation while navigating. I would get the pause audio while driving but cannot hear the lady voice. I am not sure what the problem is. I will be installing shielded wires his weekend. I got USB, iPhone 4s , DVD, radio, hdd and Bluetooth working. I am having trouble with the speakers wiring on the amp. I follow the gm repair PDF but still having issues. All function works but those issues still ongoing. I was hoping to get a picture of someone that did 8 speaker amp swap to 10 speaker amp. But no help
  16. #105
    Nov 2011
    Hamilton
    26
    61
    Quote Originally Posted by rudeboyspi View Post
    You have already accomplished a lot more than anyone would of expected. Good job man.
    I'm hoping this thread picks up again and someone can help you out
    Good luck and keep us posted.
  17. Remove Advertisements
