Page 3 of 29 FirstFirst 12345678910111213 ... LastLast
Results 31 to 45 of 422
Thread: Successful navigation swap into a non Nav CTS
  1. #31
    MTL_CTS's Avatar
    MTL_CTS is offline Cadillac Owners Fanatic
    Automobile(s): 2011 Cadillac CTS-4 Coupe Raven Black
    Apr 2008
    Montreal, Quebec
    300
    re: Successful navigation swap into a non Nav CTS
    What was the name of the ebay user?
  2. #32
    1968vert is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    72
    Quote Originally Posted by MTL_CTS View Post
    Global Autotech
  3. #33
    rudeboyspi is offline Cadillac Owners Fanatic
    Automobile(s): 2008 cadillac cts
    Mar 2012
    157
    Thanks for the reply. 1968vert i send you some emails with pics of the pigtail wires. Those are what i am having issues with. The ebay seller that did the radio unlock , i wasn't able to find them. I select in red the 2 connectors i am having trouble with. see pic
  4. #34
    Mar 2012
    157
    I decide to have a sound shop install the Navigation for me in my 2008 cadillac cts. The guy told me that it cannot be done. I took it to 2 diffrent shops. I decide to do it myself. I was able to modify the wiring pingtail and connect everything. ITS WORKS HAHAHAHAHa, but the radio is locked . I will send it out to the ebay unlocker that 1968vert listed above. I might ship it tomorrow, but I will check with my local dealer first and i will post pic for everyone else. The start to finish of the project.
  5. #35
    Mar 2012
    157
    I just got back from the dealer and was told that they cannot unlock the radio. I contact that eBay seller and they will get it lock. So I will ship it out tommorrow. Hopefully I will have better luck. I will also install the USB connector. That might require more work. I think I will wait until I get the radio back. I will keep updating the post. I still didn't get any help from 1968vert
  6. #36
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Jan 2005
    Left the desert - Back in FL
    56
    1,303
    try the user Global-Auto-tech.
    I can't beleive that these units can't be unlocked and re-used. That's a load of horsesh!t.
  7. #37
    Mar 2012
    157
    I agreed, the Cadillac dealer sucks ass. I love the car and I even like it better than my 2005 Mercedes c230 kompresser. I just cannot believe that this an American car and it is a headache to get nav install.
  8. #38
    fortes89 is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS
    Apr 2011
    Miami, Fl
    27
    144
    good stuff, maybe one day ill attempt. keep us posted!
  9. #39
    Nov 2007
    72
    Quote Originally Posted by rudeboyspi View Post
    If I remember correctly, the white one goes to the radio. when I bought my setup, It came with just the pigtails. Having the full harness might make it harder to trace the wires. If you check the two 8 pin connectors that go to the motorized screen, you'll see some of the wires go to that connector. The wires that are wrapped in foil go to the amp. they are for the audio guidance I believe. I don't know about the other connector. I think the display panel connector is the same color. try that one out.
    rudeboy-
    sorry for the late response. just a heads up, did you get a premium amp also? You'll need one. Putting that amp in was the most difficult part of the swap.
  10. #40
    Mar 2012
    157
    I was hoping that i don't have that problem. Can you post a pic of the AMP that is needed. Do you have any details on how to run the VSS wire. That is the only one I cannot locate to connect to, the other question is how do you get the gps antenna under the dash? any ideas to get that mounted
  11. #41
    Nov 2007
    72
    The amp that you'll need is the premium amp. It has a fourth connector port. The base model only has three ports. I bought mine of of eBay for $50. Try to get pigtails. I ended up going to a dealer to buy the fourth connector and the terminals for it. Putting the amp in involves removing the driver seat and the rear bottom cushion. You'll have to add five more circuits to the 44 pin radio connector that go to the amp. The other 20 pin connector that connect to the radio has some leads that go to the amp also. I think those are for the voice guidance. This will also be a good time to run wires for a backup camera. The GM LAN wire ( dark green) from the amp goes to a white connector under the carpeting by the left rear of the driver seat. You'll see a few dark green wires going to a white connector. The new amp pretty much bolts in once yOu move a clip. Almost all the wires going to the amp connectors will have to be re-pinned. If you don't have the pin outs I'll try to email you one. The base model is a 8 speaker system was as the premium is a 10 speaker. I'm still running 8 but if you want the 10, the two missing speakers are in the rear window shelf. Also, the front tweeters are run off the same signals as the front speaker. The premium models, the tweeters had there own signals. I just left mine the way it was. Probably explains why I can't hear the turn signals or the door chime?
    The vss wire comes from the ebcm ( abs). I think it is a green and yellow wire. There is a connector that is near the driver side valve cover that the vss signal for the radio ends at. Hope this helps. Let me know if you need help, I'll try to check back often.
    Quote Originally Posted by 1968vert View Post
    Oh, the gps antennae goes under the defrost vent. I had to pull both a-pillars out to remove it. There's actually already a spot for it. It is to the left of the center speaker. I just set it in there. Doesn't rattle or anything.
  12. #42
    Mar 2010
    Detroit, USA
    12,711
    rudeboyspi, I can completely understand your frustration and am sorry to hear about the unlocking issue! Please feel free to email me at Katie_Lucille@gmexpert.com with your name and VIN anytime if you'd like me to investigate further on your behalf.
    Best,
    Katie
    Cadillac Customer Service
  13. #43
    Nov 2007
    72
    audio x1.JPGaudio x1.2.JPGaudio x2.JPGaudio x2.2.JPGaudio x3.JPGaudio x3.2.JPGaudio x3.3.JPGaudio x4.JPGaudio x4.2.JPGI attached a couple of pdf documents. One is the schematics of the radio, the other has pinouts for the connectors. If you scroll to page 90, you'll see the pinouts for the amp. Page 275 youll start seeing the pinouts for the radio. It has all the connector names and part numbers for the connector and terminals. My car had the UQA option radio. The UQS is the premium option.
  14. #44
    Mar 2012
    157
    Thanks for the info guys. I shipped radio today. I will let you know when I get it back.
  15. #45
    Rdecrane5 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Cadillac CTS Coupe RWD
    Mar 2012
    35
    116
    Has either of you found a usb port that works? I am currently trying to find a cable that plugs into the back of the radio. I already have purchased a cable and the trim that will work in the center console. The usb port on the back of the radio appears to be a mini usb, but I tried one and it wont fit. I was hoping I could use a cable from the chevy trucks since it is only $20 and the cts one comes as a complete center console harness which is over $100. I have not confirmed the chevy one would work, I was hoping to find out before I ordered it.
  • You may not post replies
