Successful navigation swap into a non Nav CTS - Page 25
Page 25 of 29 FirstFirst ... 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 LastLast
Results 361 to 375 of 422
Like Tree16Likes
2008-2013 Cadillac CTS General Discussion Discussion, Successful navigation swap into a non Nav CTS in Cadillac CTS Second Generation Forum - 2008-2013; Does anyone know where I can get new bose amplifier conectors... I got 2 loos conectors which cause right side ...
  1. #361
    ITALYNSTALYN is offline Cadillac Owners Member
    Nov 2012
    60
    Does anyone know where I can get new bose amplifier conectors... I got 2 loos conectors which cause right side speaker when car hits bumpy road.... Thanx
  2. #362
    Nov 2012
    60
    Rudeboi I also get hours of radio resetting itself and getting no sound... After a lot of investigating it seems as though it is a faulty windows program that cadillac uses....and / or cheap amp conectors. Try putting radio on and touch/move the conectors on amp.
  3. #363
    rudeboyspi is offline Cadillac Owners Fanatic
    Automobile(s): 2008 cadillac cts
    Mar 2012
    157
    Quote Originally Posted by ITALYNSTALYN View Post
    Have you check the dealer? Also is it the connector on the speaker that is loose or the ones on the amp?
  5. #364
    Nov 2012
    60
    The conectors on the amp in the trunk....when I touch them sound goes off and on....others have had sound issues with these cheap conectors.
    Remember or know where I can get another set?
  6. #365
    Mar 2012
    157
    Sorry I wish I could help. Mine came with the connectors.
  7. #366
    Nov 2012
    60
    How's your sound issue?
  8. #367
    Mar 2012
    157
    After a few test the issue is my radio hdd. It seems that it get hot and then that sound issue happens. The head unit causing the issue. It as a fan on it that needed to be replaced
    Quote Originally Posted by rudeboyspi View Post
    I think I can get you the part numbers for those connectors. That would have to wait until I leave work. Then you can call the dealer and ask if they have those parts.
  9. #368
    Nov 2012
    60
    Your a good man. It's very appreciated! Did changing your fan fix your problem?
  10. #369
    Mar 2012
    157
    Yes, unit was getting hot.
  11. #370
    Mar 2012
    157
    Hi
    There are 4 connectors that connect to the amp. The x1 would be the first one facing the light which have the power wire.
    Amp x1 6098-4798 (8pins)
    Amp X2 6098-4611 (16 pins)
    Amp x3 7283-9076-30 (16pins)
    Amp x4 7283-9078-80 (16pins)
  12. #371
    Nov 2012
    60
    Rudeboyspi your a gentlemen. I appreciate what you do for this forum. If anyone has any questions feel free to ask me.
    Thanx man
  13. #372
    Mar 2012
    157
    Thanx man
    No problem, I hope that helps.
  14. #373
    GeneMpls is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Silver Perf Coupe awd gone but not forgotten ; 2013 Silver Premium Coupe- awd
    Jun 2012
    71
    170
    Re: Successful navigation swap into a non Nav CTS
    Sorry to pirate your thread but I would love to buy a used Instrument panel filler that is taken out when the nav unit is used. Anyone have one? Thanks Gene
  15. #374
    Mar 2012
    157
    Quote Originally Posted by GeneMpls View Post
    Hey Gene
    Have you try ebay?
  16. #375
    Jun 2012
    71
    170
    I actually have. Thanks Gene. I want to imbed a 7" Garmin GPS in one but I can always use my original one I guess.
  17. Remove Advertisements
