Successful navigation swap into a non Nav CTS - Page 21
Page 21 of 29 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 LastLast
Results 301 to 315 of 421
Like Tree15Likes
2008-2013 Cadillac CTS General Discussion Discussion, Successful navigation swap into a non Nav CTS in Cadillac CTS Second Generation Forum - 2008-2013; Originally Posted by rdade Have anyone finish swapping their navigation into a non Nav CTS?? I have a 08 Cadillac ...
  1. #301
    bojangle is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS
    Oct 2010
    31
    125
    Re: Successful navigation swap into a non Nav CTS
    Quote Originally Posted by rdade View Post
    Have anyone finish swapping their navigation into a non Nav CTS?? I have a 08 Cadillac Cts4 with non nav and i want to know where i can get the parts. I have tried ebay, amazon, and many salvage yards but no one seem to have navigation system for this car available. Do i need to try CTS-V? Will it fit into my 08 model? any help is greatly appreciated.
    I went called local bone yards and found the set up for cheap. lkq has them but they're over priced.
  2. #302
    Dano636's Avatar
    Dano636 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Coupe RWD Black
    Apr 2012
    In the drivers seat!
    75
    I found the part numbers for the center console USB harness...
    USB Harness - 20877757 - $126.76
    USB Bracket - 25814514 - $5.75
    And there was much rejoicing!!!
  3. #303
    rdade is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac cts 4
    Apr 2013
    15
    i search the local bone yard here in Virginia and nothing. i even tried using cragslist..there was one in California for $1500...i decided to pass on it and look for something cheaper.
    Dano where did you get the harness and bracket..ebay?
  4. #304
    Dano636's Avatar
    Apr 2012
    75
    Rdade, I haven't bought them yet, probably just get them from the dealership tomorrow if I can't find them on the www for cheaper.
  5. #305
    Oct 2010
    31
    125
    Quote Originally Posted by Dano636 View Post
    http://www.gmpartsgiant.com/parts/gm...-20877757.html
    a few $$$ cheaper than the price you posted
    I have officially been able to get everything working. Had a few problems like the sound was shitty but, that was improper wiring, ground loops, shielding, and connections. When I shielded my wiring, I had the shielding grounded at both ends. well, apparently that isn't how it should be done. I only need to have one end grounded or it'll create a ground loop. current will flow through it instead of drain out of it. sounds good now and works great. impressively the navigation works better than my phone nav but, I also have sprint so that might not say much.
  6. #306
    dekes1 is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2010
    44
    15
    Add me to the list of successful swaps. It's a very large project, a solid two days if you have everything ahead of time. but it's not impossible. I will say though that it's about a $1500 project. I know some have done it cheaper, but to really do it right you'll spend at least that much.
    Not to discourage anyone, but a few things to know that may not have been stressed enough in this thread:
    1) you will need to replace the front dash speakers if you have the 8-speaker set up (swapping tweeters for normal 3.5" full range speakers)
    2) you will need to add the UQS 10-speaker amplifier if you don't already have the 10-speaker setup (the 8-speaker UQA amplifier will not work)
    3) you will need to add rear speakers if you want to do full front-rear fading
    4) you'll need to add the microphone to the overhead console for voice control, Centerpoint tuning, and nav directions
    5) the hardest part for me to find was the center console USB harness. many junk yard visits required
    6) those speakers needed in the front dash will need their own wires run back to the amplifier
    7) run the wires for the rear view camera while you're in there (even if you don't plan to do the camera at that time) you'll be happy later if you ever want to add it
    8) make sure the faceplate you buy has all the features your car contains. for example, my car was one of the earlier ones that has the heated washer fluid feature. i had to find a faceplate that had the Nav buttons but also the hot washer fluid buttons. for the record, those faceplates are easy to disassemble so you can swap parts easily
    9) dont forget the nav screen top trim plate. i drove around for about a month without one and it looked stupid
    rdade and rdade like this.
  7. #307
    rudeboyspi is offline Cadillac Owners Fanatic
    Automobile(s): 2008 cadillac cts
    Mar 2012
    157
    Quote Originally Posted by dekes1 View Post
    This is all true. I have done mine just like that. I did mine little by little over a few weeks.
  8. #308
    Apr 2013
    15
    I tried to upload the image but was not able to.
    Anyway, how do I connect the nav screen to the satellite radio. I purchased the nav screen w/pigtails off of ebay but do not know how to connect it to the unit. I searched everywhere but I keep coming back to this site for help.
    what cables do I need to connect it or part number where I can find the cable. its a black cable with a blue harness on the ends. it's located on the nav screen and on back of the unit.
  9. #309
    Automobile(s): none
    Jan 2010
    44
    15
    Not sure I understand the question. The display has three connectors and all three must be plugged in. One of them is a cable with blue connectors that plugs directly into the display as well as directly into the radio. The other two connectors from the display have to be wired into the car as noted elsewhere on this forum (mostly just power, ground and remote turn on circuits)
  10. #310
    Apr 2013
    15
    dekes,
    thanks for replying. the blue connector that connects the two together is cut in half. Where do I find a replacement cable? I tried all the dealership and none will sell me this particular part. So I need part number to find and buy this for my radio.
  11. #311
    Mar 2012
    157
    dekes,
    I think that blue wire provide the video feed to the screen. You can check eBay or junk yards. The dealer do sell that wire, you have to get someone knowledgeable. I think it would cost like $300 from the dealer, that is what my dealer told me when I started my project. That is a rip off though. Sorry I don't have the part number.
  12. #312
    Apr 2013
    15
    Thanks rudeboyspi,
    I will try another dealer. Do the wires from the 8 pin connector(gray) connects to any wires of the other 8 pin connector(black) or do they all connect to the 20 pin connector on the unit? What i'm trying to say is that I connected a couple of wires together on the two 8 pins (I read the schematics that you and 1968vert posted)and then what was left over I tried to connect to the 20 pin connector. or should I connect some of the wires to the 44 pin connector.
  13. #313
    green6811 is offline Cadillac Owners Member
    Automobile(s): 2010 cadillac 2010 cts 4 wagon
    Jun 2013
    Bronx New York
    54
    1968vert or anyone do you have the schematic to the 44 pin out I swap my radio with a navigation radio everything work but I have no sound
  14. #314
    Mar 2012
    157
    Quote Originally Posted by green6811 View Post
    Did you change out the amp?
  15. #315
    Jun 2013
    Bronx New York
    54
    yes I change the amp to the 10 speaker amp
  16. Remove Advertisements
