Successful navigation swap into a non Nav CTS - Page 2
Page 2 of 29 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 16 to 30 of 421
Like Tree15Likes
2008-2013 Cadillac CTS General Discussion Discussion, Successful navigation swap into a non Nav CTS in Cadillac CTS Second Generation Forum - 2008-2013; Actually, the wiring would probably be the easy part. I don't know about the 2nd gen, but on the first ...
  1. #16
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    Re: Can we add OEM Nav system to 2010 CTS?
    Actually, the wiring would probably be the easy part. I don't know about the 2nd gen, but on the first gen CTS, all three different radios use the same wiring harness. Car manufacturers tend to use the same wiring harness for every trim level of a given car. It's cheaper than making different ones. That's why base cars tend to have empty plugs hanging in various places around the car.
    It's all the missing solenoids, relays, and different components installed that would drive you crazy trying to sort them all out. Methinks.
  2. #17
    dan1520 is offline Cadillac Owners Member
    Automobile(s): 2010 CTS Sport Wagon
    Jan 2011
    17
    Thanks to all for your input. It seems unlikely I will attempt to add the nav system. Perhaps its better to go for a Garmin.
  3. #18
    Bandit1's Avatar
    Bandit1 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 ATS 3.6 RWD Premium
    Oct 2008
    Ashburn, VA
    494
    Here's the latest thread on adding the oem NAV. Looks like it has been done, but he's trying to figure out how/why the HU will not mate with the VIN.
    http://www.cadillacforums.com/forums...ofit-done.html
  4. #19
    1968vert is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    72
    After searching for months for information on swapping an oe navigation system into my '09 with no luck, I decided to take it on myself. Everything seems to be working. The navigation, radio, cd all seem to function, but I'm not getting any sound. Anybody have any ideas on hooking up the speakers? The premium units had a four connector amp. The base models only had three.
  5. #20
    bojangle is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS
    Oct 2010
    31
    125
    re: Successful navigation swap into a non Nav CTS
    have you thought about swapping the amp out as well so you can get a four wire set up
  6. #21
    MTL_CTS's Avatar
    MTL_CTS is offline Cadillac Owners Fanatic
    Automobile(s): 2011 Cadillac CTS-4 Coupe Raven Black
    Apr 2008
    Montreal, Quebec
    300
    Also can you post in detail what you did, with part numbers, as I think you are the first person in history to do this successfully...
  7. #22
    Nov 2007
    72
    I'm thinking that's the route to take when I can get one for about a $100 dollars.
  8. #23
    Nov 2007
    72
    Quote Originally Posted by MTL_CTS View Post
    First thing to do is to get yourself a gm service manual. I highly recommend it. Next, try to get the most complete system you can get with wire harness pigtails or complete harness. I bought a complete unit (receiver, gps antenna, display panel, center dash panel, pigtails) out of a 2008 cts. I bought mine on eBay, or you can try a junkyard. These units are locked once they are removed from the donor car, so youll have to get it unlocked. Again, eBay was my friend. The next step is to take apart the center dash panel. The procedure is in the service repair manual. Then remove the receiver. On mine, there was three connections on the back. There was a big black 44 pin connector, an antenna and a satellite antenna connection. All three plug directly into your new receiver. Now comes the fun part. You'll have to supply grounds, a vss signal, and ign power. I found one power source in the 44pin receiver connector. The other power source I found by prying of the left dashboard access cover by the drivers door. For the vss signal, I tapped into a wire (green and yellow I think) on the driver side valve cover in the engine compartment. The gps antenna is located under the riverside defrost vent. The parts that I needed were wire taps, shrink wrap, solider, wire, trim push clips, and some trim screws. The display panel bolts right up. You will need to get some clips and screws to secure it. The new receiver bolts right in. Put in your new dash panel and if you did everything right, you should have factory navigation. I haven't figured out the sound part yet. I think I'm gonna get a premium amp with the pigtails and make a new harness to add that fourth connection to the amp.
  9. #24
    Nov 2007
    72
    I thought I would update my progress. I bought an amp that came out of a cts-v that had the extra plug. I went to my local dealer and got the extra connector I needed. I compared the connector pin-outs between the base and the premium systems. Turns out that almost all the wires going to the amp had to be re-pinned. On top of that, quite a few circuits had to be added. After a days work, I completed the install. I now have working navigation and sound in a base cts. Total cost was a little over $600.
  10. #25
    exm22psu is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS DI AWD Premium
    Apr 2009
    46205
    44
    585
    Congrats on getting this done successfully! I thought I had done well with the installation of the back up camera but this takes the cake, so to speak.
  11. #26
    sfv41901's Avatar
    sfv41901 is offline Cadillac Owners Connoisseur
    Automobile(s): 08 CTS
    Jan 2009
    Palmdale, Ca
    38
    1,249
    Congrats. Are u planning on doing the rear view cam retro?
  12. #27
    rudeboyspi is offline Cadillac Owners Fanatic
    Automobile(s): 2008 cadillac cts
    Mar 2012
    157
    Hey i bought all the parts and the wiring. can you send pic of how you did the install. i just don't know were a few wires connect to.
    PS can you send me a copy of the wiring diagram from the service manuel that you used. PM me
  13. #28
    rspreng is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Sedan RWD Radiant Silver|Ebony
    Jul 2006
    Knoxville TN
    40
    231
    Congrats and awesome achievement. You should try and sell a kit for the DIY crowd.
  14. #29
    Mar 2012
    157
    Did you have any isses with GM programming the unit?
  15. #30
    Nov 2007
    72
    Quote Originally Posted by rudeboyspi View Post
    I didn't take any pics when I did the swap. I'll gladly help you with the swap. Send me an email liftedfx4@yahoo.com
    I actually sent the silver box to a company on eBay that specialized in unlocking gm radios. If they couldnt do it, I probably would have sold everything and buy a Tom Tom.
    The cadillac dealer I went to was a joke. They claimed you couldn't reprogram the unit. With no one else successfully doing the swap, I was ready to give up on it
  16. Remove Advertisements
