Successful navigation swap into a non Nav CTS - Page 12
Page 12 of 29 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 166 to 180 of 422
Like Tree16Likes
2008-2013 Cadillac CTS General Discussion Discussion, Successful navigation swap into a non Nav CTS in Cadillac CTS Second Generation Forum - 2008-2013; I see alot of folks adding NAV to their non NAV cars... GM should start considering selling NAV upgrade packages ...
  1. #166
    austin's Avatar
    austin is offline Cadillac Owners Connoisseur
    Automobile(s): ~2011 CTS-V Coupe & 2013 SRX~
    Apr 2005
    Boston, MA
    1,749
    I see alot of folks adding NAV to their non NAV cars... GM should start considering selling NAV upgrade packages for you guys and make everyone's life alot easier. It's a win win situation for everyone. This seems long overdue.
  2. #167
    rudeboyspi is offline Cadillac Owners Fanatic
    Automobile(s): 2008 cadillac cts
    Mar 2012
    157
    Quote Originally Posted by rcmunir
    got sound working for music/onstar/phone.
    Working on getting voice guidance working and as well as signal/door chimes
    Rudeboi do you remember what wires you shielded to get those working?
    Ok for door chimes and signal sounds, you need to connect the front speakers to amp x2 connector and not x1. Please check earlier post regrading that.
  3. #168
    jkfcb01 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Sep 2010
    27
    grsychckn, did you end up getting the HDD unit? Curious of the cost, I have only the AUX connection and no Bluetooth so I'm trying to upgrade the things that are the easiest.
    Thanks
    Jason
  5. #169
    eborunda's Avatar
    eborunda is offline Cadillac Owners Fanatic
    Dec 2011
    123
    Re: Successful navigation swap into a non Nav CTS
    I have an 08 that came without Nav. Where did u get the head unit and pop up screen for yours ? I want to swap mine, also did yours come with a special antena ( for the Nav )
    Thanx
  6. #170
    rcmunir is offline Cadillac Owners Member
    Automobile(s): CTS 08
    Nov 2011
    Hamilton
    26
    61
    you will have to get the parts from ebay or a wreck yard. I recommend a wreck yard as you would need the wiring. Go through the entire thread and it should help you out. It is a very long, frustrating process but worth it at the end.
  7. #171
    rodsrsr is offline Cadillac Owners Member
    Automobile(s): 2010 CTS
    Jan 2013
    4
    This may have already been shown but its my first post and I just came across this product. It runs $1,000 less than the Prodigy and still retains all the factory features.
    http://gm-navigation.com/cadillac-cts-gps.html
  8. #172
    Mar 2012
    157
    Quote Originally Posted by rodsrsr View Post
    It shows at $2500 price tag. I did the factory upgrade and cost was around $1200
  9. #173
    Jan 2013
    4
    I'm reading this entire thread now...Its very involved to say the least, but I see it can be done. Congrats on accomplishing this huge project.
  10. #174
    Mar 2012
    157
    I need a favor from one of you guys. Can one of you check the sub in the trunk and tell me the colors of the wires and which one goes to + and- . My connector broke of and don't remember which one positive or negative.
  11. #175
    Mar 2012
    157
    Can anyone help?
  12. #176
    1968vert is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    72
    Quote Originally Posted by rudeboyspi View Post
    Can anyone help?
    did you still need help with that? I'm working on my amp, I can take a quick peek.
  13. #177
    Mar 2012
    157
    Yes please, I need to know which wire colors are on the sub
    Hey vert can also take a pick of the wires on the amp and post it. I also asked for that awhile now. I still don't get high mid's.
  14. #178
    Nov 2007
    72
    The rear most wire is black/red and the one closest to the rear seats are black/green. Sorry bout the pics, I got caught up in other things. I'll take some pic's tomorrow since I have the trunk apart. I think I have the opposite prob as what you have. I get the mids but my highs suck. On our models, the front door and dash speakers are wired in parallel and share the same signal. My fronts are still wired to X1 at the amp. I take it that yours are wired to X2? I don't have door chimes, turn signals, or voice guidance. My plan was to run a pair of wires down each side of the car. I would cut and splice one of the tan and gray wires at X200 (left dash bolts access panel) and one of the L. green and d. green wires at X225 (right dash bolts access panel). These two connectors are where the front speakers connect to the main body harness. The other ends of my new wires will go to X2. My front dash speakers should get there own signals and hopefully solve my door chime and turn signal problem. hope this helps.
  15. #179
    Mar 2012
    157
    Quote Originally Posted by 1968vert View Post
    That is correct. Mine is setup that way to x2. I will be doing the something and separate the front speak from door speakers. I changed my sub out because it couldn't handle the amp.
    Thanks for the info. I will help a lot with my sub.
  16. #180
    Nov 2007
    72
    Rudeboy,
    this is how they look as of today. Ill be adding four new circuits to x2 for the front dash speakers. Front door speakers will stay in x1. I'm also thinking of adding some 5.25" speakers in the rear shelf since mine didn't come with them. What kind of sub did you use?
  17. Remove Advertisements
