This is a quick write up for Transmission Fluid Drain and Fill procedure on 2nd GEN CTS. For you weekend DYI folks that want to give your CTS a quick thank you, this is for you. Keep in mind this particular procedure is not a flush, there will still be about 1/3 of the old fluid left in the tranny. There are some procedures to supplement this where you can add a hose to the transmission cooler supply line, that will flush the old fluid into a bucket. I opted not to do this as my car is only at about 60,000 miles. I would recommend doing this, along with dropping the pan and a thorough cleaning with a new gasket at around 100,000 miles.
Materials Tools used:
~Oil/Fluid Hand Pump
~4.5 Quarts of Royal Purple Max ATF (Dexron VI)
~Oil Drain pan
~1/2" Socket Wrench
~7/8" wrench 3/8" ratchet
~2 Rhino Ramps
~Angled Panel Remover Tool/Flat Head screwdriver
~Telescopic Mirror
Here we Go:
Once you have the vehicle up on the ramps with your parking brake engaged, slide under the vehicle and locate the transmission, between the two exhaust pipes. Find the drain plug and ready your socket wrench to remove the drain plug, make sure you have your drain pain positioned directly under the tranny pan. I would advise wearing latex gloves and have a few shop towels nearby in case it gets messy. Loosen the drain plug with your wrench and then unscrew by hand. Allow all of the fluid to drain completely out, this make take a few minutes. Use this time to clean the drain plug with a paper towel.
The next step is to use a flat head screw driver or in my case I used an angled panel tool to remove the top fill-plug from the side of the transmission. (It's a little challenging to get to to, as it is above one of the shafts leading into the transfer case.) Pop the plug up and remove. Clean the area around the fill hole with a shop towel to make sure no contaminants can fall into the hole when you go back to fill with your pump. Use your telescopic mirror to look around the opening of the hole.
Prepare your 5 quarts of ATF, and affix your pump nozzle and hose to the quart. Position your tube into the fill hole and begin pumping the fluid (remember, we have not put the drain plug back in at this point). Pump about half the quart into the fill hole, allowing it to drain through the pan. At this point put the drain plug back in and tighten all the way. Do not over-tighten.
Now pump the rest of that quart and 4 more. When you get to the half way point of your 4th quart, begin pumping slowly. You do-not want to over fill the transmission, this can cause problems. You want to fill it to the point where the fluid begins to seep out of the opening. At this point remove the fill tube and insert the fill-plug back in to the top of the transmission fill hole.
Clean up your tools and work space. Start the vehicle and shift from park into all of the gears.
That's it! A quick transmission drain and fill keeping your CTS running smooth!
~Oil Drain pan
~1/2" Socket Wrench
~2 Rhino Ramps
~Telescopic Mirror
Here we Go:
