How to: install rear view backup camera NON Nav CTS
Results 1 to 12 of 12
2008-2013 Cadillac CTS General Discussion Discussion, How to: install rear view backup camera NON Nav CTS in Cadillac CTS Second Generation Forum - 2008-2013; Okay I've finally done it. lots of research and testing/trouble shooting. so here it is; *list of parts you need: ...
    bojangle is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS
    Oct 2010
    32
    125
    GNTX-657 (the mirror I used, keeps it OEM with onstar)
    2 inter connects gm part#175265-1 I got them from:
    http://www.mouser.com/ProductDetail/...liN80oxFE3h5Jy
    camera- I used Baretta USA BU-CP-TLP and got it at
    https://www.sonicelectronix.com/acco...der&id=1457851
    misc but connectors if neccassary
    *first I took the old camera off
    *I then ran all the wires from the trunk forward
    I left enough room for the power wire to plug in where the camera will be as well as the video cable, ran them down through that group of wires through that mesh thing you can see in the picture.
    the power wire in ran into the battery compartment and left hanging for now. The video cable i ran across the top of the trunk from the passenger side to the drivers side. I pulled the carpet back on the drivers side. pushed the wire up as close to the back seat as possible from in the trunk
    went in the back drivers side door and pushed the seat aside a little and reached for the video wire, here is a pic of the space to reach in by the back seat driver side
    then i ran it under the trim pieces all the way up front
    after that i ran it up the a pillar just pushing it between the weather seal and the a pillar
    across the headliner just pushing up and behind
    and up to the mirror
    *now for the wiring
    I started with the mirror. you will need to crimp the +/- from the video with the inter connects
    put the + in pin number 6 and - in pin number 7
    when you push them in you can plug the harness in the camera and tighten it up
    now thats all done move back to the trunk, the reason i ran the power down into the battery door is thats the easiest for the +/-. i took a quick connect and tied the + in to the light green wire in the group of wires behind the battery as it is the reverse light power
    Oct 2010
    32
    125
    Re: How to: install rear view backup camera NON Nav CTS
    now the - I put a connector on the - and grounded to the ground on the body where the battery is grounded
    the last part is mounting the camera. i have one that attaches to license plate lights as theres to much shit to drill through for a flush mount camer.
    now get in start your car, put it in reverse, and check
    if you have any questions I will do my best to help
    Nick
    sfv41901's Avatar
    sfv41901 is offline Cadillac Owners Connoisseur
    Automobile(s): 08 CTS
    Jan 2009
    Palmdale, Ca
    38
    1,249
    Great job. Nice to see another way of doing the rear view camera.
    MTL_CTS's Avatar
    MTL_CTS is offline Cadillac Owners Fanatic
    Automobile(s): 2011 Cadillac CTS-4 Coupe Raven Black
    Apr 2008
    Montreal, Quebec
    300
    Great write up. I want to do this on my 2011...
    Do you guys happen to know if the mirror and wiring is the same 2008-12?? I am speaking to the seller on ebay he seems to think there are different mirrors and wiring in the 08-10's as opposed to the 2011-12's
    Also bojangle do you have pictures of what the camera looks like insalled at the rear?
    Thanks
    ricinok is offline Cadillac Owners Member
    Automobile(s): 2011 Evolution Green CTS
    Dec 2011
    10
    Nick, appreciate the write up, looking forward to doing this to my 2011 as well.
    MTL...have you been talking to Bob (think that's his name) on eBay? Chatted with him and ge seemed to think all you needed to do on a 2011 is install mirror, camera and run video wires. Said rest is there if you have auto dimming mirror function.
    Oct 2010
    32
    125
    Quote Originally Posted by MTL_CTS View Post
    Thanks
    i had to get a different style camera, once it comes in i will update the post
    Thanks
    i intially got the idea from a 2011 cts, from what i know the wiring is the same. all you have to run is the video wires and the power wires for the camera, thats it. i found where they go which was the hardest part. with that out of the way you guys should have this in no time
    MTL_CTS's Avatar
    Apr 2008
    Montreal, Quebec
    300
    Ricinok, yeah I'm talking to Bob Prim on eBay... Ok bojangle thanks for the info!
    Phrede is offline Cadillac Owners Member
    Automobile(s): '08 XLR-V
    Oct 2009
    KY
    59
    3
    I'm working on doing this on my XLR-V. Do you have pictures of the mirror mount. Mine is kind of a triangular shape with groves. I believe this is similar to a C6 Corvette. I think I can figure out the wiring of the mounts are compatible. Any problem with the size of the display?
    Oct 2010
    32
    125
    i dont have a picture of the mount but the display is slightly bigger than the stock one, not too bad
    motopsycho231 is offline Cadillac Owners Member
    Automobile(s): 08 cts raven
    Aug 2010
    46
    Put wires in 6&7. Stuck it in reverse. No screen. Power light on mirror blinks when in reverse but screen doesn't come on. Help!?!
    hamblen is offline Cadillac Owners Member
    Automobile(s): 2006 STS
    Feb 2011
    53
    7
    Just did this for my Wife for Christmas as a surprise. She nearly wet her pants when it came on!!
    Thanks!
    huntercasillas is offline Cadillac Owners Member
    Automobile(s): CTS
    Oct 2015
    22
    I can't get the interconnects into the mirror's harness. Is there a certain way to put them in? I have the exact same mirror, and bought the GM interconnects from the link you posted, however when I try to put them into pin #6 and #7 it seems forced. After finally getting them in, the cable won't click into the mirror. Any help would be appreciated.
  15. Remove Advertisements
