Brake Pad / Rotor Change
Results 1 to 3 of 3
2008-2013 Cadillac CTS General Discussion Discussion, Brake Pad / Rotor Change in Cadillac CTS Second Generation Forum - 2008-2013; Anyone have a good write-up on how to change the brake pads and rotors on the 08 cts4? I'm going ...
    CaddyShack CTS4 is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac Cts4 ; 3.6L DI
    Dec 2011
    Chicagoland Area
    31
    Anyone have a good write-up on how to change the brake pads and rotors on the 08 cts4? I'm going to be changing the brakes soon, anyone do it themselves yet? Will a C-Clamp do it to reset the piston onto the new pads or will i need some kind of special tool for that part? Anything I should be aware of before I change my pads/rotors out (I got all oem parts, j55 system)
    08 CTS4 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 AWD
    Mar 2011
    156
    Re: Brake Pad / Rotor Change
    Not much to add other than I pulled the front rotors and pads on my 08'CTS4 about 8 months ago just after purchase to ensure everything looked ok.
    Nothing different on these front brakes and any other GM product Ive worked on. simple pad removal and If memory serves it is a dual piston design ?
    I did use the C-Clamp method to compress the pistons back and all was good.
    It always amazes me the cost of brake jobs when people take their cars in for brake work. Its seems by the time their done, the shop has replaced the pads, rotors, calipers , etc. at a very high cost. Brakes at least on GM vehicles are very straight forward with minimal labor time involved.
    Good luck but the fronts are a piece of cake.
    Dec 2011
    Chicagoland Area
    31
    Yes it's dual piston design on the front calipers. I still need to get brake cleaner and grease for the job.
    I'm not sure what the caliper bolts should be torqued too.. can't really find information on it
