Holy Oil Consumption Bat Man!
Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
Like Tree3Likes
2008-2013 Cadillac CTS General Discussion Discussion, Holy Oil Consumption Bat Man! in Cadillac CTS Second Generation Forum - 2008-2013; Bought my 2009 CTS last October with about 34,000 miles on it. Got about 38,000 miles on it. Oil percentage ...
    GreaseMonkey's Avatar
    GreaseMonkey is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS 3.6L Black Ice/Ebony
    Sep 2011
    Sterling Heights, MI
    336
    Bought my 2009 CTS last October with about 34,000 miles on it. Got about 38,000 miles on it. Oil percentage is in the 60s, so I decided to check the oil level.
    Not even on the stick! It took about 1.75 quarts to get it to full. I'm going to continue to keep an eye on it, but that's pretty crazy. My previous vehicle, a 2008 Dodge Caliber SRT4 pushing 15 psi of boost would only eat up .5 to 1 quart of oil every 5,000 miles.
    928S is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS 3.6L DI RWD, GMPP new engine 11/2013
    Oct 2005
    USA
    2,092
    Re: Holy Oil Consumption Bat Man!
    Hey GreaseMonkey,
    Your oil consumption is about the same as my '08 3.6L DI (odometer 32Kmi), also the GM accepted rate of 1qt. in 2Kmi., TSB #01-06-01-011F "Info on Engine Oil Consumption Guidelines," Jan 13, 2009.
    Your 60% oil life remaining after 4Kmi. looks very very good to me. Mine is 75% after less than 1Kmi. since last oil & filter change (mild winter weather, average trip 4-6 miles) .
    All of which reminds me...I need to check the oil level now before I forget again...damn!
    Sep 2011
    336
    I know 1 quart for every 3,000 miles seems to be pretty standard print per most OEMs. Still just shocked that a N/A 3.6L V6 consumes more oil than a 300 HP forced induction 4 cylinder.
    Oct 2005
    USA
    2,092
    It's probably worth noting that 2008-2012 CTS owner's manuals say
    "It is a good idea to check the engine oil every time you get fuel. In order to get an accurate reading, the oil must be warm and the vehicle must be on level ground,"
    while the TSB, referenced above, says
    "To assure a sufficient amount of oil has drained back to the crankcase, and an accurate reading can be obtained, the vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading."
    I've found the latter to be true, and, in my experience, fuel stop oil reading can be a misleading waste of time.
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    The fuel stop reading line is just a carry over. Car manuals have said you should check oil and fluids every fuel stop for decades.
    ctsfan2009 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS4
    Aug 2011
    240
    I think every car I've ever owned "recommended" checking the oil at every fuel stop. I've always adhered to the idea that the engine needs to sit for at least a few minutes to let everything drain back into the oil pan. Having said that, I haven't checked the CTS's oil in a while. I still have 40% oil life left(oil has about 5K on it now) so I will do that tonight after I get home. So far, I haven't added any so we'll see how much she has used. Last check all was fine.
    sandcracker21 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 DI
    Nov 2011
    Chicago, IL
    243
    At what point of "oil life" on the info center do y'all change oil? My dealer recommened changing at 50% life but seems like that's a little early. I would rather be early than late though.
    kdstrum's Avatar
    kdstrum is offline Cadillac Owners Fanatic
    Automobile(s): 2015 CTS
    Jun 2008
    Norfolk, Virginia, United Stat
    44
    150
    hey i don't know what's going on but i've checking my oil every week and am not burning oil. make sure you let the car sit for and hour or so. i have have let the dealer after and oil change thinking i was 1+ quarts low told me to wait and hour before i check it
    Oct 2005
    USA
    2,092
    Quote Originally Posted by sandcracker21 View Post
    I used to change oil & filter annually at about 8Kmi. and 40% oil life remaining. Now, after last year’s premature-timing-chain-wear recall/OLM recalibration and shortened oil change intervals, I wait for "Change Engine Oil Soon" message to appear on DIC display at about 5% oil life remaining.
    JackB is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS AWD DI 2014 AWD CTS DI
    Oct 2004
    515
    I have been reading about this oil consumption issue for some time. Just to let you know that it is not every CTS, my 09 now has 36k miles and it has never needed oil added other than changes.
    kdstrum's Avatar
    Jun 2008
    44
    150
    same here 08 rwd 3.6di 21000 miles
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    i'm pretty sure that engine oil consumption is directly related to the break-in procedure (or lack thereof) when the engine was new
    proper break-in should result in very low (or zero) oil consumption
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Maybe, but GM isn't the only one that has D/I engine oil consumption problems;
    the VW 2.0T and Audi 3.0T for example, burn pretty much a quart every 2K miles..
  16. #14
    Sep 2007
    Wilmington, NC
    13,969
    https://www.google.com/search?q=engi...ption+break-in
    looks like honda and acura top that google search (for auto brands)
    but if you add cadillac to that search it brings up a few threads from this forum discussing break-in and how it relates to consumption
  17. #15
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    that first link explains a lot of misconceptions. Engines are supposed to burn a little amount of oil, I won't disagree that a quart every 2K on a daily driven engine is probably a little more than typical, but engines are not supposed to contain every drop it had at 0 miles on these 10-13K mile OLM OCI's. The fact that some engines do is coincidence or probably because they spend most of their life at or around idle..
    I had to add a half quart to the LSA a little while ago infact.. but that's because of the MIR day and a few autocross runs, so I'm not freaking out about it .
  18. Remove Advertisements
