Clean Air Duct Freshener Problem
Results 1 to 6 of 6
2008-2013 Cadillac CTS General Discussion Discussion, Clean Air Duct Freshener Problem in Cadillac CTS Second Generation Forum - 2008-2013; After owning my 08 CTS for just over a month, I decided to try and take care of the odor ...
    thavil is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Black Cherry Cadillac CTS4
    Nov 2011
    Southern Maryland
    121
    After owning my 08 CTS for just over a month, I decided to try and take care of the odor coming from my vents. I purchased a can of Clean Air Duct Freshener from Pep Boys today and followed the instructions to spray in the vents, the cabin intake and the fresh air intake. After letting the car idle for 10 minutes as instructed, my AC/heat controls were not functioning properly. I tried to raise the temperature but it lowered instead. I tried to change between recirculation and fresh air but the button didn't respond. I then tried to change from the dash vent to the floor and my radio changed stations!! I decided to turn off the engine and let everything dry out. Three hours later, all controls are working properly.
    Question - Besides using this product on a car with so many electronics, what did I do wrong? Could spraying in the passenger side floor cabin intake cause this or spraying in the outside fresh air intake do it? Hopefully I will not have any lasting affects from this.
    wmillar is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS DI F3 Sport Suspension
    Aug 2003
    North Texas
    73
    197
    Re: Clean Air Duct Freshener Problem
    Did you change cabin air filter.
    Nov 2011
    Southern Maryland
    121
    Quote Originally Posted by wmillar View Post
    Yes, I changed it the first week I owned it.
    Aug 2003
    North Texas
    73
    197
    I've had problems with odors in the past, and I just spray in the vent where the cabin air filer is. You can either use lysol or you can go to the drugstore and get some Orange citrus spray that they use in hospitals to get rid of odors. I've also read that some people put a Bounce dryer sheet. and put it inside the vent where the cabin air filter is.
    Nov 2011
    Southern Maryland
    121
    Thanks for the suggestions on the odor but this isn't what my post is about. I would like to know if someone else has almost fried their climate control & infotainment system while trying to kill the odors coming out of the vents?
    AirDuctRepair is offline Cadillac Owners Member
    Automobile(s): NONE
    Jun 2013
    Chattanooga, TN
    29
    1
    As your AC/heat controls were not functioning properly even in idle condition so you must check the a/c is switched on or not.you should use efficient products to take care of the odor coming from your vents.May be spraying in the passenger side floor cabin intake cause this failure.For better guidance you should refer best links which are as follows.
    Links Are:
    http://homerepair.about.com/od/heati...ing-System.htm
    http://chattanoogaairconditioningrepair.com/
    http://www.ductmasters.net/services_commercial.php
  9. Remove Advertisements
