Lighting questions - simple questions
Results 1 to 12 of 12
Like Tree1Likes
  • 2 Post By ByByBMW
2008-2013 Cadillac CTS General Discussion Discussion, Lighting questions - simple questions in Cadillac CTS Second Generation Forum - 2008-2013; I have two lighting questions that I have been scratching my head. 2011 CTS sedan Luxuy 1. When you step ...
    rspreng is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Sedan RWD Radiant Silver|Ebony
    Jul 2006
    Knoxville TN
    40
    231
    Lighting questions - Brake and Dash Lights - help please
    1. When you step on brake, the brake lights do not come on - engine not running, key not in ignition. Normal?
    2. When you turn on parking lights or headlights, center stack lights come on but not the gauge lights - key not in ignition. Normal?
    Thanks
    Bob
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: Lighting questions - simple questions
    If you would like to send me your VIN number I will look into this for you and see what I can find out.
    Breanne
    Jul 2006
    Knoxville TN
    40
    231
    Anyone care to check their vehicle out for me and let me know what you see?
    Jon's Avatar
    Jon
    Jon is offline Cadillac Owners Master
    Automobile(s): 16 ATS-V, 04 CTS-V, 09 CTS, 07 SRX, 04 CTS
    Feb 2004
    Alberta, Canada
    31
    6,651
    Both are normal
    Jul 2006
    Knoxville TN
    40
    231
    Quote Originally Posted by Jon View Post
    Both are normal
    Many thanks Jon.
    Does anyone find this set-up as odd? Especially the brake lights. I thought that circuit was hot all the time. Wonder the reason GM engineered it that way?
    928S is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS 3.6L DI RWD, GMPP new engine 11/2013
    Oct 2005
    USA
    2,092
    Quote Originally Posted by rspreng View Post
    I'd guess that dead brake lights prevent battery drain immediately before maximum battery power is needed to start the engine.
    CTS Owner's Manual:
    "PRESS BRAKE TO START ENGINE (AUTOMATIC TRANSMISSION ONLY)
    If the vehicle has the keyless access system, this message displays if you try to start the engine without having the brake pressed."
    Jul 2006
    Knoxville TN
    40
    231
    Quote Originally Posted by 928S View Post
    CTS Owner's Manual:
    Thanks, would have thought since LED the amp drain would be null compared to coventional bulbs.
    ByByBMW's Avatar
    ByByBMW is offline Cadillac Owners Member
    Aug 2007
    98
    My 08 Corvette is the same way. Thought it strange at first but it is just the way it is. I guess GM figured there is no good reason to have the brake lights come on if the whole car is turned off.
    rspreng and rspreng like this.
    Jul 2006
    Knoxville TN
    40
    231
    Quote Originally Posted by ByByBMW View Post
    Cool that must be the way GM is going. I had an 02 Z06 but they lit up w/o the key. Thanks.
    Now I wonder the reasoning behind not lighting the gauge lights.
    BreakingThrough's Avatar
    BreakingThrough is offline Cadillac Owners Fanatic
    Automobile(s): Thunder Gray '08 CTS 3.6 FE2 Premium
    Apr 2011
    Hermosa Beach, CA
    33
    319
    The no brake lights when car is completely off is nothing new. I had a brand-new 1999 Mercury Cougar that was the same way. It was the first time I'd encountered a car that required you to turn the car to the "on" position (or completely start the car) for the brake lights to work. I took a driving test in that car, and here in California, they check that your lights function before the test. I actually worried that I would run into an issue when they asked to check the brake lights before the tester got in my car for the test. Interestingly, they had me turn the key to "on" before checking any of the lights. So it's nothing too unorthodox.
    ctsfan2009 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS4
    Aug 2011
    240
    Just went out to the garage and tried mine and sure enough, no key with me and no brake lights! Mine has keyless access so I have to press the brake pedal to start it and if I have the keyfob with me, they do light up before I start it. As for the IP lights, mine does that too. My Infiniti did that as well. The cluster likely turns off completely when the ignition is off so this is why it doesn't illuminate when the car is off.
    Jul 2006
    Knoxville TN
    40
    231
    Quote Originally Posted by BreakingThrough View Post
    Thanks, this is the first new car in awhile, my current daily driver is a 2003 GMC 2500HD and it is old school.
    ---------- Post added at 09:39 PM ---------- Previous post was at 09:37 PM ----------
    Quote Originally Posted by ctsfan2009 View Post
    Thank you ctsfan2009 for checking, appreciate it. New car nuisances I guess.
  15. Remove Advertisements
