Need some help finding a problem... amp/sub blown?
Results 1 to 6 of 6
2008-2013 Cadillac CTS General Discussion Discussion, Need some help finding a problem... amp/sub blown? in Cadillac CTS Second Generation Forum - 2008-2013; So, I added an aftermarket Subwoofer and Amplifier to the Bose Amp in my 2011 CTS Sedan. Everything was perfect. ...
    bphillips is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Premium
    May 2011
    New Orleans, LA
    46
    So, I added an aftermarket Subwoofer and Amplifier to the Bose Amp in my 2011 CTS Sedan. Everything was perfect. Today, I decided to swap the aftermarket amp for another one that I had that came with the subs, and what I did not notice was the the Negative and Positive were very lightly labeled on the amp and opposite than the other amp. I assumed (foolishly) that Positive was on the left and Ground was on the right (like the other amp), so I connected as so. I reconnected the battery, and upon starting the car, there was no sound from the stock Bose amp and the Parking Assist was turned off. I checked all the wiring, and realized where the problem was, but seeing as the previous amp worked, I put everything back the way it was before, reconnected the battery, closed it all up, and started the car. Same problem!
    I tried putting a new fuse in the "Audio System/Subwoofer" fuse location with no dice :-/
    What should I do!?
    Any/All help is VERY appreciated!
    May 2011
    New Orleans, LA
    46
    Re: Need some help finding a problem... amp/sub blown?
    really? no one?
    tonyfort's Avatar
    tonyfort is offline Cadillac Owners Fanatic
    Automobile(s): Former owner 2008 CTS
    Mar 2010
    228
    No promises that I can help, but I think I'd need more detail on how you have it connected up to everything to even try. Do you have a dedicated line running from the battery for the aftermarket amp? Are you using line-level inputs on the aftermarket amp or low-level RCA?
    chagrin falls is offline Cadillac Owners Fanatic
    Automobile(s): 2013 srx perf, 2010 cts4 prem
    Mar 2008
    Chagrin Falls, Ohio
    160
    Sorry I can't help your amp problem but I'm curious that you have a CTS Platinum. I didn't realize Cadillac offered the Platinum Package on the 2011 CTS. Would appreciate how you ordered same. Thanks!
    May 2011
    New Orleans, LA
    46
    So, here's an update.
    It seems that accidentally reversing the polarity did a lot less than I thought. All it simply did was blow the one fuse I read over in the manual.
    In the manual, I saw the "Audio Speakers/Subwoofer" fuse as 15A and replaced it with no avail. I pretty much stopped there with the fuses. Well, after checking everything, seeing as the problem was no power to the amp itself, I decided to re-read the manual and saw that I had (VERY STUPIDLY) skipped over the fuse labeled AMPLIFIER. (D'OH!)
    So, replacing that, everything was perfect. It seems as if the Amplifier and the Park Assist are the same fuse? They both went out, then were both fixed with a simple fuse replacement.
    Agh, my own stupidity!
    Also, in response to Tony: I simply spliced into all the wires going in/out of the Amplifier. I connected all the necessary wires to a Re-Q5. I spliced into the + and - Subwoofer connection for the signal, then + and - 12v current, then + and - front-left tweeter (for signal detection). This allowed the Re-Q5 to have an always-on power supply, but only turn on when a signal was being sent from the Bose Amp to the front-left speaker. Then, when it was on, it sent a remote signal to the aftermarket amplifier, allowing it to turn on. The Re-Q5 also supplied to Equalized RCA Subwoofer Signal. The Aftermarket amp + and - 12v was connected in parallel with the Re-Q5 + and - 12v going into the Bose Amp.
    In response to Chagrin Falls (Ohio?): My mother, who bought the car, told me it was a 2011 CTS Platinum, but it appears that it is not. OnStar said it was, but a VIN lookup states that it's just a premium. Ah, I shouldn't have looked it up and just kept the feeling of "yeah, it's a platinum. be jealous." Haha!
    tonyfort's Avatar
    Mar 2010
    228
    glad you got it figured out!
  9. Remove Advertisements
