Results 1 to 3 of 3
Thread: Cooling fluid
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    61
    2,541
    Cooling fluid
    I am going to replace cooling fluid. I checked the service manual and it calls for plastic tubing to go over the radiator mounting pin. Anyone knows what the size of the tubing is? I want to get ready for the fluid change……
    Delta is offline Cadillac Owners Fanatic
    Automobile(s): Some kind of CTS
    Sep 2011
    210
    Re: Cooling fluid
    it's not 100% necessary, it just keeps it cleaner. i would imagine a standard fuel hose size would work. They're 5/8 right?
    you should just be able to open up the petcock and drain it if all else fails.
    MoFex's Avatar
    Oct 2007
    metro Atlanta
    61
    2,541
    Re: Cooling fluid
    Delta,
    thank you for the info. I will get some transparent tubing at 5/8 size and see if it fits. If not I will just do it, the job will be messier but at least the engine will have new cooling fluid....
  • You may not post replies
