Front Speaker cuts in and out - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Like Tree1Likes
2008-2013 Cadillac CTS General Discussion Discussion, Front Speaker cuts in and out in Cadillac CTS Second Generation Forum - 2008-2013; Yes Katie Customer Assistance then if needed I start going up the ladder usually the 1st. call gets me a ...
  1. #16
    Surfstix is offline Cadillac Owners Fanatic
    Automobile(s): 2016 XTS Premium
    May 2012
    Hampstead NC
    129
    Re: Front Speaker cuts in and out
    Yes Katie Customer Assistance then if needed I start going up the ladder usually the 1st. call gets me a reference number for the issue and a call to the dealer to setup an appt. I used to just back down most of the time before this car, I just refuse to spend the money and not have the Manufacturer back their products any longer.
  2. #17
    jkfcb01 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Sep 2010
    27
    Pyromaniac
    I'd be interested to hear what you did for your aftermarket system...
    Jason
  3. #18
    tman19 is offline Cadillac Owners Member
    Automobile(s): CTS 2012
    Mar 2013
    1
    Same issue on 2012 CTS, left side would cut out and or drop in volume considerably, when hitting bump. Took to dealership with no help, they initially were going to
    replace front speaker but then could not get to duplicate so gave up. Followed instructions above (amp was in same place for 2012 and very easy to access). It seems to have addressed issue. Thanks for help.
    Disconnected and reconnected and added electronic jelly.
  5. #19
    DobisPR is offline Cadillac Owners Member
    Automobile(s): 2011 CTS4 Luxury
    Jun 2014
    1
    Same issue on my 2011 CTS4 Luxury. I will follow the same as tman19 and try out the disconnect + jelly + reconnect.
  6. #20
    RAB's Avatar
    RAB
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by tman19 View Post
    ^ I'm not sure what the term "electronic jelly" actually represents (googling the term yields nil results), but the proper lubricant-corrosion inhibitor to use on electrical/electronic connectors is silicone dielectric grease. I don't support using petroleum grease/jelly (such as vaseline) due to its very low melting point - most brands liquefy at about 100 deg. F. Another issue is that petroleum jelly releases flammable vapor, even at low temperatures.
    /RAB
  7. #21
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,714
    Speaking of petroleum jelly, the inventor of Vaseline ate a spoonful every day of his long life.
    I know you need to know this.
    RAB likes this.
  8. #22
    dyalenti is offline Cadillac Owners Member
    Aug 2014
    2010 CTS
    I have the same problem, I've had it back to the dealer 5 times too. They replaced the speaker twice, changed the coax cable and the last time they said there was a short in the wiring which blew the speaker??? So they replace the wiring harness, replaced the speaker and guess what? 1hour later it did it again. I called them up and returning the car for repair. I'll let you know how it turns out!
    2010 CTS
  9. #23
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Hi dyalenti,
    I’m sorry that you are dealing with this speaker issue in your CTS and I can understand how frustrating the lack of a resolution could be. If you would like an additional layer of assistance while working with the dealership, please feel free to PM me with your VIN, mileage, dealership, and personal contact information. If not, please keep us updated on how the repairs go.
    Enjoy your weekend,
    Austin J.
    Cadillac Customer Care
  10. #24
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,873
    dyalenti,
    A speaker is a mechanical device. It has no power source on it's own. Shorting the leads of a speaker does nothing. It's equivalent to taking a piece of wire and forming it into a loop. Nothing happens. A short would affect the amp powering the speaker, but not the speaker itself, unless the short was to a direct DC source of sufficient amperage to damage the coil. But if that happened, a fuse should have blown on the circuit if the short was going to draw that many amps. Plus you should have noted other issues with the car and not just the speaker cutting out
  11. #25
    Aug 2014
    Hi Austin J., thanks for offering help.
    I finally took it upon myself to resolve the problem and I applied the procedure suggested here as to unplug the connections to the amp in the trunk and it has been working perfectly since.
    I find it amazing that I can find the solution here and the dealer can't.
    I've had two issues with the car, one with my radio and one with my seat and both solution were found here in a few minutes. I strongly suggested to change the seat's frame at the last visit (4th time) and they finally did. As for the radio, well........
    dyalenti
  12. #26
    Mar 2010
    Detroit, USA
    12,722
    Hello dyalenti,
    You are welcome. Thank you for providing an update for us and letting us know that you resolved the issue on your own. I do apologize for any inconvenience you encountered throughout the process of working with your dealer. If additional questions or concerns arise, please feel free to contact us via private message.
    Laura M.
  13. #27
    pennetta1969 is offline Cadillac Owners Member
    Automobile(s): CTS 4
    Jun 2016
    Kent WA
    1
    I have a 2010 CTS4 that I am having this same issue now for about a year and no one can seem to fix it. It is so annoying I am thinking about selling my baby!!! I have it customized to match my Harley and its just go me beside myself! Now that I have found this site and some recommendations I am going back to the dealer and have them check it out. Thanks!
  14. #28
    13WhiteCTS4 is offline Cadillac Owners Member
    Automobile(s): 2013 CTS4
    Sep 2016
    Long Island, NY
    55
    39
    My 2013 with 15k miles on it started to so this. Funny how it's always on the drivers side. I guess I'll give the dealer a shot at it first before I pull any harnesses
  15. Remove Advertisements
