GM recomended gas
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
2008-2013 Cadillac CTS General Discussion Discussion, GM recomended gas in Cadillac CTS Second Generation Forum - 2008-2013; The Cadillac owners manual suggests using only gas with a Top Tier Rating, I have been filling up at Costco ...
    Delly is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Coupe
    Mar 2011
    Northern VA
    8
    GM recomended gas
    I have been filling up at Costco for their lower price.
    Does anyone know who supplies gas to Costco ?
    928S is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS 3.6L DI RWD, GMPP new engine 11/2013
    Oct 2005
    USA
    2,092
    Re: GM recomended gas
    Quote Originally Posted by Delly View Post
    Sorry, no. Regardless of refiner/distributor, the gasoline sold by Costco (Sam's Club, WalMart, Kroger, and many other retailers) is NOT GM-recommended Top Tier™: http://www.toptiergas.com/retailers.html.
    MotownPimp's Avatar
    MotownPimp is offline Cadillac Owners Connoisseur
    Automobile(s): CTS Coupe Performance Stick
    Jan 2011
    Northern California
    74
    1,008
    I had no idea such a list existed. Very helpful thread...particularly the list of approved suppliers.
    I knew there had to be a reason I hang out with y'all!
    bobelew is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    207
    I am not sure what part of the country you live, but here in Washington state, Costco gas is now rated as "Top Tier" and has been for several months now. According to Costco their gas has one of the most robust detergent regular grade gasolines out.
    Mar 2011
    Northern VA
    8
    Thanks bobelow.
    from the manual:
    Look for the TOP TIER label on the
    fuel pump to ensure gasoline meets
    enhanced detergency standards
    developed by auto companiesFrom the manual
    Do the pumps out there display the Top Tier logo,
    The pumps in Northern VA do not.
    somedaycts is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Cadillac CTS4
    Jan 2010
    Michigan
    394
    GM only "recommends" using "top tier" fuel, just as you'll find the oil cap "recommends" Mobil1 oil, and the Ford Fusion gas cap "recommends" BP fuel. Interesting that Ford would "recommend" BP fuel when it's not a "top tier" gimmick. Keep using Costco gas, and keep saving money.
    Also from the manual:
    "At a minimum, gasoline should meet ASTM specification
    D 4814 in the United States or CAN/CGSB-3.5 or
    3.511 in Canada."
    "For customers who do not use TOP TIER Detergent
    Gasoline regularly, one bottle of GM Fuel System
    Treatment PLUS, added to the fuel tank at every engine
    oil change, can help clean deposits from fuel injectors
    and intake valves. GM Fuel System Treatment PLUS is
    the only gasoline additive recommended by General
    Motors.
    Also, your dealer/retailer has additives that will help
    correct and prevent most deposit-related problems."
    housewolf is offline Cadillac Owners Member
    Automobile(s): CTS Sport Wagon
    Jul 2011
    Tomball, TX
    37
    From a friend that works in the supply chain for one of the largest oil companies in the US -
    All fuel comes out of the same pipeline infrastructure that all US refineries pump into. ExxonMobil can put 30,000 bbls in the pipeline at Texas and immediately pull the same amount out on the east coast. It matters not who made the fuel because it is all made to the same spec. As long as the fuel entering the line meets the required spec... in it goes. The refineries don't even know who's fuel they are selling at what station. You could be filling up at Shell with fuel that Valero produced. They have no way of knowing either, and don't care, because it's all the same.
    What matters most is the condition of the underground storage tanks where you buy your fuel. The little bit of additive put in the product to make it brand specific at the supply depot can't possibly offset potential contaminants from poorly maintained storage tanks.
    Oct 2005
    USA
    2,092
    Quote Originally Posted by somedaycts View Post
    GM only "recommends" using "top tier" fuel, just as you'll find the oil cap "recommends" Mobil1 oil...
    Just for the record. Yes, in the Owner's Manual, GM "recommends" using only Top Tier™ gasoline; but "Mobil 1" was a paid product placement on the oil filler cap, not even mentioned in the Owner's Manual.
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    60
    2,541
    ..... can help clean deposits from fuel injectors
    and intake valves.......
    Ye, and it clean the intake valves best in the DI engines
    Jan 2010
    Michigan
    394
    Quote Originally Posted by MoFex View Post
    If so, why is Ford not one of the automakers supporting "Top Tier" gasoline? Surely their direct inject, turbocharged Ecoboost engines will suffer from not using "Top Tier" gasoline .
    MoFex's Avatar
    Oct 2007
    metro Atlanta
    60
    2,541
    Because Ford is smart....
    Top Tier gasoline in a DI engine has no influence on intake valves
    Injectors - I would think that given the high pressure (1,800 psi plus) the injectors are "self-cleaning".....
    GMFAN is offline Cadillac Owners Fanatic
    Automobile(s): 2014 SRX Premium w/20" chrome
    Mar 2009
    TN.
    481
    All the buzz about 'top tier' gasoline is highly over rated. I buy a lot of my gas at Kroger, (including for the Vette). Never a problem, car's perform very well. I do have one rule I follow, I always make sure I fill up at high volume stations. Oh yeah, I'll put in a bottle of Techron every 3rd or 4th fill up.
    Jul 2011
    Tomball, TX
    37
    Quote Originally Posted by GMFAN View Post
    Correct. I have a modified ~575 hp GTO that uses the "most competitively priced" (93 octane) fuel I can find. It's five years old, runs 10.80s N/A in the 1/4 on pump gas and has never had an issue.
    As I said earlier; plain and simple. There is no difference.
  16. #14
    00blueYZF is offline Cadillac Owners Member
    Jul 2007
    Metro Detroit
    51
    ^ Here is the key in bold
    I'm not disagreeing that the fuels aren't similar, but GM recommends Top Tier so you don't have to add the Techron (which probably offsets the savings of buying cheaper fuel over 3 tanks)
    Why risk getting deposits at high mileage after the warranty has run out? SIDI injectors are not only expensive, they are finicky when it comes to clogging.
  17. #15
    Mar 2011
    Northern VA
    8
    My last fillup at costco
    12.924 gal @ $3.579 = $46.25
    The Exxon closest to my house Would have been
    12.924 @ 3.699 = 47.98 a differnce of 1.73
    For $1.73 a week I guess I'l switch to, Exxon
  18. Remove Advertisements
