Carpet around center console
Results 1 to 7 of 7
2008-2013 Cadillac CTS General Discussion Discussion, Carpet around center console in Cadillac CTS Second Generation Forum - 2008-2013; I just noticed that the molded carpet panel that comes up from the floor to the center console on my ...
    jdanna is offline Cadillac Owners Member
    Automobile(s): CTS
    Apr 2011
    17
    I just noticed that the molded carpet panel that comes up from the floor to the center console on my drivers side, has come a bit seperated from the center console.
    the passenger side is fine, but if i pull back the drivers side a bit i can see all down into the car.
    it doesnt look there there are any clips or mounts, that it is just molded to the right shape.
    has anyone seen this before? is there a way to push it back in and have it stay? i was thinking maybe heat it up with a heat gun and then leave something there too keep it in place while it cools?
    im kind of at a loss here since i cant find a single clip or mounting point
    exm22psu is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS DI AWD Premium
    Apr 2009
    46205
    45
    585
    Re: Carpet around center console
    The carpet is molded to stay in place and so there are no clips. If it's lost its shape you might want to use clear silicone so that if you ever need to separate the carpet from the tunnel, you can do so.
    Automobile(s): CTS
    Apr 2011
    17
    i dont think silicon would be strong enough really. its got a decent bit of spring to it.
    also i dont think there is a good surface on the inside of the tunnel to glue to
    spaceman78 is offline Cadillac Owners Enthusiast
    May 2005
    887
    AngryRe: Carpet around center console
    mying was like that the day i bought the car, looks like it was cut to short
    Apr 2009
    46205
    45
    585
    That's weird. Mine in my 2009 is molded with a lip that fits under the console. Can you take a picture?
    Ghost Deany is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade, 2005 CTS
    Nov 2007
    NJ
    32
    788
    I had the same problem on my 08, it was so bad that it was warped out almost right next to the gas pedal, i tried velcro, that wont even hold it, i eventually used 2 black screws and screwed it into the center console area without hitting any wires, and that seems to be a crappy fix for the crappy problem
    Automobile(s): CTS
    Apr 2011
    17
    honestly that doesnt sound too bad - what did you screw into?
    i dont want to screw into my trans tunnel
    ill take pictures tomorrow
  10. Remove Advertisements
