Hawk Brake Pads - J55 -Don't make the same mistake that I made!
Results 1 to 14 of 14
2008-2013 Cadillac CTS General Discussion Discussion, Hawk Brake Pads - J55 -Don't make the same mistake that I made! in Cadillac CTS Second Generation Forum - 2008-2013; My 2008 3.6L DI AWD just passed 50K in mileage. Just before that I brought it in to a Cadillac ...
    Fred_CTS's Avatar
    Fred_CTS is offline Cadillac Owners Member
    Automobile(s): 2008 CTS-4 3.6 DI AWD
    Mar 2004
    New Bedford, MA
    30
    My 2008 3.6L DI AWD just passed 50K in mileage. Just before that I brought it in to a Cadillac dealer to have a coil pack replaced while it was still under the 50K warranty. They fixed it and said that the car would soon need new front brake pads and they quoted "around $340" for the job. I usually do all of my own work so I delcined. I went to the interent and looked up Hawk Ceramic brake pads on a popular auto supply site. I ordered a pair after locating the correct ones for 3.6L V6 w/performance brakes. When I went to install them I found that the pads were too long and too narrow. I double checked at several supply sites and all of them listed the HB467Z.540 pads for a 2008 CTS with the performance brakes. I called their customer service and I gave them the exact measurements of the OEM pads and they could not find a pair that would fit. They will do some checking and email me the RMA to return these Hawk pads.
    It has been quite some time since I last visited this forum because the CTS is my wife's and I spend most of my time on the Corvette forum, as I also have a 2008 Corvette. It took only a quick search to learn that there are very few sources for ceramic brake pads if you have the J55 RPO for the heavy duty brakes. Even a call to the local Cadillac parts department did not provide me with that information. They don't have the J55 brakes in stock so they could not give me the measurements. I wish that I had visited this forum before placing the order. I see that Tire Rack does have the correct FMSI D1331-8443 ceramic pads but they are very pricey.
    So if you are thinking about getting ceramic pads be aware that all of the parts supply sites on the internet are listing 467Z.540 FMSI D1019 as the correct pads for the performance brakes and they are wrong!
    Has any forum member located a good source for ceramic pads for a CTS with the J55 brake option? BTW, in 55,000 ,iles I never had the problem of squeaking brakes that I learned about while searching this forum. I'm just tired of having to clean the front wheels almost weekly.
    jghiller's Avatar
    jghiller is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 XTS Premium
    Aug 2008
    SC/NJ
    1,391
    Re: Hawk Brake Pads - J55 -Don't make the same mistake that I made!
    The one recall on squeeling brakes for the 08 CTS was with the standard brakes. I had that one done. There might have been one for a different symptom with the J55 brakes.
    Fred_CTS's Avatar
    Mar 2004
    New Bedford, MA
    30
    I am aware of the TSBs for brake squeal but my car never had that problem. I am returning the Hawk pads that I ordered online because they are not the correct pads for the J55 heavy duty brake option. Apparently there are 3 different pads for the 2008. Hawk lists the standard base w/o performance brakes HB439Z.555 and the base car with performance brakes HB467Z.540 but they do not make pads for the J55 Heavy Duty brake option. My research on this forum shows that the proper pads are FMSI 8443 D1331 and that they are available at Tire Rack for $121.00 for Satisfied Ceramic VS pads PR1331-C. I located those same brand ceramic pads online for half that price and immediately ordered them. I do not know why there were for sale at such a low price and assume that they were probably mistakenly priced for the rear pads, which cost less. In any case, if I do get the PR1331-C pads for the J55 option delivered at half the price ... I got a real bargain. I want to try the ceramic pads on the front even though I will be giving up a little bit of stopping power in favor of the reduced brake dust.
    RAB's Avatar
    RAB
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by Fred_CTS View Post
    . . . . . Has any forum member located a good source for ceramic pads for a CTS with the J55 brake option?
    Fred_CTS... As far I know - the only outlet in the US that offers ceramic brake pads (front) for a J55-equipped CTS is Tire Rack, but as you mentioned they're very pricey.
    When I organized a 'group buy' a couple of year back for J55 ceramic pads for about 25 forum members here, I contacted a company called ABS Friction - they're located in Guelph, Ontario. Here's a link to their website: http://www.absfriction.com/
    Suggest you contact the sales dept at ABS Friction to see if you can obtain a set of 'J55' ceramic pads for yourself, directly from them. Note that ABS Friction is a manufacturer of brake pads. I found their ceramic brake pads to be excellent - I installed them on my J55-equipped 2008 AWD CTS4.
    I now have a 2009 RWD CTS, equipped with standard duty JE5 brakes.
    FYI - here's a link to a pdf of FMSI D1331-8443 (J55 front brake pad) that I located on the web in early 2008.
    http://www.keepandshare.com/doc/1653...14-pm-64k?da=y
    EDIT: Fred, I just saw/read your most recent post after I posted this one. Congrats on finding/ordering a set of J55 front pads for half price. Hopefully those pads are the exact ones (fit & form) that you need for the application.
    By the way.. I detected no reduction in stopping power when I switched from semi-metallic to ceramic front brake pads on my J55-equipped 2008 CTS4. No doubt resistance to "fade" is marginally less with the ceramics, but then I never drove my CTS4 on the Nurburgring course!
    Helmutk's Avatar
    Helmutk is offline Cadillac Owners Member
    Automobile(s): 2016 XTS4, 2008 CTS4, 1996 Eldorado ETC
    May 2009
    59
    88
    Did you order the Satisfied Pro Ceramic VS PR1331-C pads from Amazon? I just found them on there at half the Tire Rack price also and ordered them. Hope they are the right ones!
    jhermit is offline Cadillac Owners Member
    Automobile(s): 2008 CTS DI
    Jul 2010
    71
    Anybody knows if EBC has pads for these breaks? I'm OK with the Satisfied ones, but EBC has the red ones I really like :-)
    Fred_CTS's Avatar
    Mar 2004
    New Bedford, MA
    30
    Quote Originally Posted by Helmutk View Post
    Yes those are the pads that I ordered at $68.20 with free S&H. I just noticed that the price went up today to $75.26, which is still way less that the cost at Tire Rack. I keeping my fingers crossed that they send me the correct Satisifed Pro Ceramic PR1331-C pads because that price seems too good to be true when they list out at $140.00. Like I said in my earlier post ... I think that they may have mistakenly priced them as the rear pads, which are PR1337-C. I'll know in a few days.
    PGH STEELERS is offline Cadillac Owners Member
    Automobile(s): 2008 CTS (3.6 AWD)
    Oct 2010
    Westerville, Ohio
    15
    Man I hope I don't have a problem, today I went to Oreilly's here in Westerville, Ohio and purchased ceramic brake that are made from 'BrakeBest Select' model # C1331. Per the guy at the store, he stated that this will be the correct pad for the J55 series. Well I'll be installing these brake pads this weekend weather permitting and I'll let you all know if I ran into any problems.
    zen
    zen is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS CPE
    Apr 2010
    199
    Pep Boys stocks the PR 1331-c pads, $ 69.99. They are the right ones for J55 and I have them installed without any problem.
    Fred_CTS's Avatar
    Mar 2004
    New Bedford, MA
    30
    Yep ... the PR1331-C pads are the correct ones for the J55 optioned performance brakes. I got mine today from Amazon.com at the $68.20 delivered. They are the same Satisfied Pro-Ceramic pads sold at the Tire Rack for $121.00. I sent back the Hawk pads that were 3/4" too long even though they insisted that they were the correct pads for the performance brakes. Hawk may make them for the J55 but they did not list any IMSA 1331-C pads on their website.
    C6Vette's Avatar
    C6Vette is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS DI FE3
    Feb 2006
    Oakton, VA
    45
    404
    I just went to Amazon and couldn't find anything that looked like what you guys listed. I need new pads now and I don't know where to buy them. Did you guys replace your rotors as well, or did you just use the same rotors?
    b4z
    b4z is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Standard SrX grey/black 2006 GTO
    Mar 2003
    Chas. SC
    54
    1,795
    If you reread the the thread you will see that they are several parts stores noted above that now carry the correct part #.
    cts4ever is offline Cadillac Owners Member
    Automobile(s): 2008 CTS & 2010 SRX
    May 2010
    25
    This forum is the best!
    I came "this close" to ordering the Hawk pads that are STILL listed for the '08 CTS with J55 performance brakes, but a voice told me to check the forum first, and sure enough... So thanks to Fred_CTS and everyone else who has contributed to this thread! It sent me around the corner to Pep Boys where I picked up the Satisfied Pro PR-1331C pads for 56 bucks!
    My car only has 16,000 miles on it, but I was so sick and tired of cleaning the front wheels every few days (A few stops are all that's needed to see the dust!) that I wanted ceramics bad! Cadillac lists none, so because of this forum, I bought and installed these. Perfect fit, and a week later, the wheels are looking fine! The pedal effort and feel don't seem to be any different, but I'm still breaking them in, so I can't yet vouch for their performance.
  16. #14
    rtlawlor is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS 3.6L Direct Injection
    Jun 2014
    Huntington Beach, CA
    31
    22
    okay that is so weird. Because i have a 2008 Cadillac CTS, Fully loaded premium model, w/ performance brakes. And when i went to buy pads today, they sold me these kinda medium length ones, with tabs in the middle. I take off my olds ones and mine are longer, with tabs more towards the bottom. The ones i needed are part number 1332. and they sold me the 1331. every manufacture will add a letter or two in the front or end of that part number. The bosche ones i got were 1332X. After i had to go back and return the 1331C (Pro-Stops).
    i was at Pepboys. closest place to my house. not because i enjoy there store.
  17. Remove Advertisements
