Check engine light reason
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By HurstGN
2008-2013 Cadillac CTS General Discussion Discussion, Check engine light reason in Cadillac CTS Second Generation Forum - 2008-2013; My check engine light came on this week while I was climbing a steep mountain in my '09 3.6 DI. ...
    Steadfastrock is offline Cadillac Owners Member
    Automobile(s): CTS
    Jun 2009
    28
    My check engine light came on this week while I was climbing a steep mountain in my '09 3.6 DI. The dealer says that the code indicates that my axillary water pump failed. I didn't know that I actually had an axillary water pump. Apparently it is electric and runs only when the standard cooling system can't handle the load. The dealer had to order one, of course.
    RAB13 is offline Cadillac Owners Member
    Oct 2009
    32
    Re: Check engine light reason
    Good Luck Steadfastrock. Mine has been on order for over 1 month. Called customer service, absolutely no help. No surprise there! I'm told it will be in sometime by mid August. The part may not be that big a deal but I hate driving around with my check engine light on. BTW. This is the second time it's needed to be replaced.
    Automobile(s): CTS
    Jun 2009
    28
    My dealer reset the system while I wait for the part, so I have no light (and my remote start works again).
    Oct 2009
    32
    My dealer reset the light also but it came on again in a couple of days.
    exm22psu is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS DI AWD Premium
    Apr 2009
    46205
    45
    585
    Huh, is this part of the heavy duty/performance cooling system? I didn't know it was on there either ...
    zen
    zen is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS CPE
    Apr 2010
    199
    It looks more like a "bypass valve" than a motor. It appears to allow some water from the radiator outlet to bypass back into the top of the radiator. I'm refering to the device that is imediately back of the top of the radiator on the right side (passenger side). I would think it is there for a faster engine warmup in cold weather.
    Cristano is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS 08, Cadillac Deville 97
    Oct 2011
    28
    5
    Im having the same problem my service engine light came on so I took it to get it checked and i got the same code P2601, just wondering around how much did it cost you to get it fixed?
    warrick69 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4 3.6L DI Performance Pkg
    Jul 2014
    7
    I got this code P2601 on my 2008 CTS 4 3.6L DI. Did anyone know if this covered under the powertrain warranty or if any notice/recall for this issues has been issued? thanks for your reply
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,391
    Not a recall or powertrain warranty item. See your other post for more information.
    HurstGN is online now Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,740
    Cost is about $30 and time to install. It's not a bypass, it's a pump to circulate coolant after the car is shut off and the coolant is still too hot. I learned from Marv, search and you shall find.
    Tbbt likes this.
  13. Remove Advertisements
