What other PS fluid is the same as GM #89021184 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
2008-2013 Cadillac CTS General Discussion Discussion, What other PS fluid is the same as GM #89021184 in Cadillac CTS Second Generation Forum - 2008-2013; Look at your owners manual it specifies what fluids to use and specifically says that you can use any fluid ...
  1. #16
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: What other PS fluid is the same as GM #89021184
    Look at your owners manual it specifies what fluids to use and specifically says that you can use any fluid the meets their standards. Synthetic or petroleum based. As stated earlier, there is absolutely no need to use a GM branded product.
    Keep in mind that GM markets all sorts of care and cleaning products; would you limit yourself to GM branded spray window cleaner, of course not.
  2. #17
    Z71's Avatar
    Z71
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    Quote Originally Posted by OMG View Post
    Interesting...so I am in a pickle. I am trying to find an aftermarket fluid for the AWD transfer case. But apparently the only people that make the GLS fluid is GM. Yet they want $5 for it...
    There is none, I called BW and asked. They told me the fluid that GM sells is the only fluid that you can use which is actually made by Mobil. The same product thats available from Mobil only comes in 5 gallon and larger sizes so you are stuck with buying it from GM. If I recall correctly (not 100%) its called Mobilfluid 424 Multipurpose Tractor Lubricant BUT Mobil might have tweaked it for use in the BW transfer case.
    Because its a low volume special purpose product there is no incentive for other lube companies to formulate a replacement for the GM fluid.
    GM only recommends what makes them money.
  3. Remove Advertisements
