How to change your own oil (with pictures) - Page 5
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 66 of 66
Like Tree5Likes
2008-2013 Cadillac CTS General Discussion Discussion, How to change your own oil (with pictures) in Cadillac CTS Second Generation Forum - 2008-2013; Test Sent from AutoGuide.com Free App...
  1. #61
    ArmyJoe is offline Cadillac Owners Member
    Automobile(s): 15 ATS Coupe, 13 ATS Sedan10 SRX
    Jan 2010
    52
    99
    Test
  2. #62
    Suisun-Sue is offline Cadillac Owners Member
    Automobile(s): 2013 CTS Coupe
    Aug 2014
    1
    Re: How to change your own oil (with pictures)
    I would be concerned about hitting and damaging something inside the crankcase such as a sensor, switch or such, with the extraction tube, unless I knew for certain that it was clear.
    Quote Originally Posted by MoFex View Post
    Roger
    this is not a matter of oil temperature. I was unable to push the tube deep enough.
    I changed mine for the first time at 3500 mi, even tho the oil life said 57% remaining. My perception is that during new engine break-in, the oil becomes more contaminated with break-in particles, and thus should be changed sooner. After first time, I will rely on oil life indicator.
    Interesting idea to change the filter w/o the oil. The CTS filter cartridge setup allows to do that. Thanks.
    Yes, and when I refill with exactly 6 quarts after completely draining crankcase and oil filter container, my dipstick shows about 1/3 qt. low.
  3. #63
    Randy Stone is offline Cadillac Owners Member
    Automobile(s): 2009 CTS 3.6 DI AWD
    Aug 2012
    Winter Park, Florida
    64
    51
    So it seems the oil drain plug on the AWD models is behind a cover held by 4 screws and on the drivers side. Correct? Mine is a 2009 CTS 3.6 AWD
  5. #64
    Raywwatch is offline Cadillac Owners Member
    Automobile(s): CTS-4 3.6 DI
    May 2014
    Connecticut
    58
    3
    I changed the oil in my 3.6 DI AWD the other day and the only thing I found odd was the bolts for the bottom cover were very rusty and tight. Whoever was doing the oil changes before I can only assume they weren't taking the cover off completely as the inside of the cover was oil soaked but I found no oil leaks.
    Randy Stone likes this.
  6. #65
    jimmyt198 is offline Cadillac Owners Member
    Automobile(s): 2010 CTS4
    Oct 2014
    1
    This is a great tool and makes the job easy and painless, however, any dirt particulate resting on the bottom of the oil pan will remain there. Although, obviously, running the engine to operating temperature prior to changing the oil will suspend the particulates of carbon and other nasties, and it SHOULD be sucked up by this tool, it is my suggestion to do it the labor intensive manner so that there is nothing left to chance.... Just my opinion. (I have been working on automobiles for over 35 years)....
  7. #66
    CaddyRum is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Premium Coupe
    Oct 2014
    Northern VA
    So tomorrow I plan to change my oil using Mobil 1 and I plan to install a spring loaded valve from
    Quikvalve to replace drain plug. Had one on my Mustang and loved it. Also the valve allows you to attach a
    Piece of tubing to help direct the oil in tight places. Hoping this will allow me not to have to remove the
    Shroud fully next oil change. I'll post a pic after im done.
  8. Remove Advertisements
