Tire Pressure Monitor-- Reset ?
Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
Like Tree8Likes
2008-2013 Cadillac CTS General Discussion Discussion, Tire Pressure Monitor-- Reset ? in Cadillac CTS Second Generation Forum - 2008-2013; 5,000 miles.. need to rotate tires..need information on reset of TPM after tires are rotated.. thanks for info.. joncar...
    joncar is offline Cadillac Owners Member
    Automobile(s): Cadillac,CTS
    Feb 2008
    rockledge, florida
    26
    The_Judge's Avatar
    The_Judge is offline Cadillac Owners Connoisseur
    Automobile(s): '11 CTS 3.6 Premium, Black on Black, 19" Summer Tire Package
    Jun 2008
    Hermosa Beach, California
    1,524
    Re: Tire Pressure Monitor-- Reset ?
    Found this in the manual -- hope it helps:
    TPMS Sensor Matching Process
    Each TPMS sensor has a unique identification code.
    Any time you replace one or more of the TPMS sensors
    or rotate your vehicle’s tires, the identification codes
    need to be matched to the new tire/wheel position.
    The sensors are matched to the tire/wheel positions in
    the following order: driver side front tire, passenger
    side front tire, passenger side rear tire, and driver side
    rear tire using a TPMS diagnostic tool. See your
    dealer/retailer for service.
    The TPMS sensors can also be matched to each
    tire/wheel position by increasing or decreasing the tire’s
    air pressure. If increasing the tire’s air pressure, do
    not exceed the maximum inflation pressure indicated on
    the tire’s sidewall. To decrease the tire’s air-pressure
    use the pointed end of the valve cap, a pencil-style
    air pressure gage, or a key.
    You have two minutes to match the first tire/wheel
    position, and five minutes overall, to match all four
    tire/wheel positions. If it takes longer than two minutes,
    to match the first tire and wheel, or more than
    five minutes to match all four tire and wheel positions,
    the matching process stops and you need to start over.
    The TPMS matching process is outlined below:
    1. Set the parking brake.
    2. Turn the ignition switch to ON/RUN with the
    engine off.
    3. Press the Remote Keyless Entry (RKE) transmitter’s
    lock and unlock buttons at the same time for
    approximately five seconds. The horn sounds
    twice to signal the receiver is in relearn mode
    and Tire Learning Active message displays on the
    DIC screen.
    4. Start with the driver side front tire.
    5. Remove the valve cap from the valve stem.
    Activate the TPMS sensor by increasing or
    decreasing the tire’s air pressure for 10 seconds,
    or until a horn chirp sounds. The horn chirp, which
    can take up to 30 seconds to sound, confirms
    that the TPMS sensor identification code has
    been matched to this tire position.
    6. Proceed to the passenger side front tire, and repeat
    the procedure in Step 5.
    7. Proceed to the passenger side rear tire, and repeat
    8. Proceed to the driver side rear tire, and repeat the
    9. After hearing the confirming horn chirp, for the
    driver side rear tire, the horn sounds two more
    times to signal the tire learning mode is no longer
    active. Turn the ignition switch to LOCK/OFF.
    10. Set all four tires to the recommended air
    pressure level as indicated on the tire and
    loading information label.
    11. Put the valve caps back on the valve stems.
    GT!, GT!, doozmlk and 7 others like this.
    Feb 2008
    rockledge, florida
    26
    thank you very much, i read and read but did not find this info... i printed it out to use now and later,, thanks again.. joncar
    The_Judge's Avatar
    Jun 2008
    1,524
    Quote Originally Posted by joncar View Post
    Glad to be of help. I found it in the PDF version of the manual, which is searchable. I think there's a link to it someplace on this site.
    C6Vette's Avatar
    C6Vette is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS DI FE3
    Feb 2006
    Oakton, VA
    45
    404
    Has anyone tried doing this by lowering the pressure? I'm curious how easy it is to do.
    Ronster is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 Black/Ebony CTS-4, Other(s): 2009 Wicked Solstice
    Feb 2008
    Lake County Ill, USA
    58
    748
    I rotated the tires and did this tpms thing in my garage. worked just like the book says.
    there is plenty of time, and it takes only a few pounds drop to ID each corner. I have a compressor so I could top them off after but there was enough air left to drive anywhere to put more in if you have to.
    rg
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    60
    2,541
    I did it too. Very easy and quick process...
    928S is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS 3.6L DI RWD, GMPP new engine 11/2013
    Oct 2005
    USA
    2,092
    Like Ronster and Mofex said, it's quick and easy!
    For unknown reasons, my TPMS stopped working altogether. So I reset and matched the sensors to the tires, per the owner's manual, and the system has since performed flawlessly. Also pleased with my Craftsman air compressor, and I wonder why I didn't buy one to keep in my garage years ago.
    C6Vette's Avatar
    Feb 2006
    Oakton, VA
    45
    404
    OK, one more question. If I have another set of tires/rims with TPMS sensors that are the same, can I swap out the tires and then just do the same procedure? Would it then register the new tires/rims?
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Yes, If the sensors are the correct part numbers you should be able to program the car to recognize those.
    C6Vette's Avatar
    Feb 2006
    Oakton, VA
    45
    404
    Thanks guys, appreciate the help!
    MoFex's Avatar
    Oct 2007
    metro Atlanta
    60
    2,541
    If they are GM sensors compatible with the system the procedure should work...
    ldelre is offline Cadillac Owners Member
    Automobile(s): 2003 DeVille
    Jun 2009
    1
    For my car, that advice was close, but not close enough. If you only get one beep when you press the lock and unlock at the same time, and the above does not work, do this: Go find a big magnet and follow the instructions below:
    TPMS RELEARN & RESET PROCEDURES
    On the Corvette and Cadillac applications, the transponders in each wheel must be reset if the wheels are rotated to another position on the vehicle. This can be done by placing a J-41760 magnet over the valve stem or by using a Tech 2 or equivalent scan tool.
    Magnet method: With the key on, engine off, press both the lock and unlock buttons on the key fob. A horn chirp within 10 seconds indicates the TPMS receiver is in the programming mode. Place the magnet over the left front valve stem until the horn chirps. This forces the LF pressure sensor to transmit its code to the main module. Repeat the same procedure for the right front, right rear and left rear sensors in this order. Verify all four pressure readings are displayed on the driver information center.
  16. #14
    Brooks2 is offline Cadillac Owners Member
    Dec 2007
    30
    Where is this magnet available ?? Through GM parts ??
    Thanks, Mike
  17. #15
    crystal_red's Avatar
    crystal_red is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS DI AWD FE2 CRYSTAL RED TINTCOAT/LIGHT TITANIUM
    Apr 2009
    Clarkston Michigan
    295
    Any strong magnet will do. You can usually find one at any auto parts store or at an electronics shop.
  18. Remove Advertisements
