Tire Pressure Monitor-- Reset ? - Page 2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 48
Like Tree8Likes
2008-2013 Cadillac CTS General Discussion Discussion, Tire Pressure Monitor-- Reset ? in Cadillac CTS Second Generation Forum - 2008-2013; Thanks a bunch, Mike...
  1. #16
    Brooks is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    89
    Re: Tire Pressure Monitor-- Reset ?
  2. #17
    jw38 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4
    Jan 2009
    91
    Quote Originally Posted by ldelre View Post
    For my car, that advice was close, but not close enough. If you only get one beep when you press the lock and unlock at the same time, and the above does not work, do this: Go find a big magnet and follow the instructions below:
    TPMS RELEARN & RESET PROCEDURES
    On the Corvette and Cadillac applications, the transponders in each wheel must be reset if the wheels are rotated to another position on the vehicle. This can be done by placing a J-41760 magnet over the valve stem or by using a Tech 2 or equivalent scan tool.
    Magnet method: With the key on, engine off, press both the lock and unlock buttons on the key fob. A horn chirp within 10 seconds indicates the TPMS receiver is in the programming mode. Place the magnet over the left front valve stem until the horn chirps. This forces the LF pressure sensor to transmit its code to the main module. Repeat the same procedure for the right front, right rear and left rear sensors in this order. Verify all four pressure readings are displayed on the driver information center.
    As the owner of both the CTS and a C6 Corvette, I can tell that using the magnet to reset the TPMS is MUCH easier than having to mess with the tire's air pressure!
  3. #18
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    60
    2,541
    Tried the magnet method yesterday. Did not work. I have a rare earth, very strong magnet....any ideas?
  5. #19
    gonzalezfj is offline Cadillac Owners Member
    Automobile(s): 09 CTS
    Sep 2008
    Eastern PA
    75
    87
    Quote Originally Posted by MoFex View Post
    Older cars use magnet to reset. Newer ones you need to change tire pressure or use an electronic gadget to reset the sensors.
    Don't know when the cutoff is for Caddy. In Corvettes it's 2005 or older use the magnet.
    Frank Gonzalez
  6. #20
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Magnets won't work on CTS. You either have to have the programming tool... $$$$$.... or do the tire pressure increase/decrease method.
    It only takes about 2 psi to trigger the learn, let air out for 8-10 seconds, stop and wait for the beep.
  7. #21
    MoFex's Avatar
    Oct 2007
    metro Atlanta
    60
    2,541
    I did the pressure change twice. It worked great! And as I have a PorterCable ais compressor inflating the tires back is not a problem. Just wanted an easier way...
    ewil3rd,
    thank you for the info.
  8. #22
    mrny25's Avatar
    mrny25 is offline Cadillac Owners Member
    Automobile(s): 2003 Deville Base Model
    Oct 2009
    Albany NY
    37
    8
    Excellent information.. I have a 2003 Deville and the service tire pressure on the dash is driving me nuts. I had a TPM sensor replaced and never reset the sensors. Going to try the magnet this weekend.
  9. #23
    jghiller's Avatar
    jghiller is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 XTS Premium
    Aug 2008
    SC/NJ
    1,390
    Procedure, identified as one the owner should do, is documented in the user manual.
  10. #24
    louiefl99 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS Coupe
    Jan 2005
    Southeast Florida
    54
    584
    Before doing the relearn, I pump all the tires up to 40 psi and then simply bleed down. It will chirp right around 36 psi and then I don't need to go back and adjust the pressure a second time.
  11. #25
    mrny25's Avatar
    Oct 2009
    Albany NY
    37
    8
    I just did the magnet reset procedure on my 2003 deville,it worked perfect. I bought a 90lbs of force
    magnet from the Harbor Freight store near me it took about 1 minute to do all 4 tires. Key on engine off
    hold the lock and unlock buttons until you hear a chirp then place the magnet next to the drivers wheel
    valve stem until you hear a chirp then go to the passenger front do the same thing,rear passenger tire
    then finish at the rear drivers side tire. Great info guys thanks. The magnet cost like $3 dollars in case
    your wondering.
  12. #26
    buzz's Avatar
    buzz is offline Cadillac Owners Fanatic
    Automobile(s): 2013 XTS Premium, 2016 Acadia Denali
    Nov 2005
    Minnesota
    294
    So, where did you purchase this $3 magnet? I would like to have this in my tool box in the event I need it in the future. It is a bit of a PITA to inflate/deflate all four tires when I need to reset the TPMs; as when the tires are rotated, for example. As it is, I am considering the purchase of the GM tool; i.e., about $75.
    Here is the next, albeit maybe obvious question for experienced users, how do you turn the ignition to "on" without starting the engine for an STS with push-button starting? I may be showing my ignorance here; but, with a simple "key" ignition system, it is really easy. This push button start system, IMHO, is silly! You still need a key, so why not just have it hanging on the dash or steering column? Maybe I am showing my age, here!
  13. #27
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,682
    buzz,
    From page 2-28 in your owner's manual:
    The red circle indicates what you would push when the engine is off to put your vehicle into Accessory Mode (your engine is not running, but you can use your windshield wipers/radio/etc).
    I hope this helps!
    Sarah (In for Katie)
  14. #28
    HUD
    HUD is offline Cadillac Owners Member
    Automobile(s): 2010 CTS
    Mar 2005
    Camarillo, Ca.
    73
    74
    On my DTS, I use the magnet to set the pressure monitor. Can the magnet also be used on my 2010 CTS?
  15. #29
    sofaking427 is offline Cadillac Owners Member
    Nov 2012
    will this Per the manual for a CTS process work for an 03 Deville ?
  16. #30
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,063
    Quote Originally Posted by sofaking427 View Post
    Probably not. Entirely different vehicles and electricals. Try posting in the proper forum for the Deville.
  17. Remove Advertisements
