Subwoofer Install with Bose Amp and NAV
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 53
Like Tree2Likes
2008-2013 Cadillac CTS General Discussion Discussion, Subwoofer Install with Bose Amp and NAV in Cadillac CTS Second Generation Forum - 2008-2013; I have an 08 CTS with the Bose Amp and Navigation System and wanted to add an aftermarket subwoofer and ...
    ibiza1010's Avatar
    ibiza1010 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Wagon (Crystal Red w/Recaros)
    Oct 2007
    Bentonville, Arkansas, United
    28
    I have an 08 CTS with the Bose Amp and Navigation System and wanted to add an aftermarket subwoofer and amplifier to replace the stock subwoofer in the rear decklid.
    I used a JL Audio A1400 amplifier (340 watts @ 4ohm) connected to a JL Audio Powerwedge CS112RG-W3v3 subwoofer enclosure. The enclosure fits nicely under the rear decklid in the trunk and doesn't take up too much room. The enclosure has 1 - 12 inch W3v3 subwoofer rated up to 500 watts. I also utilized an MTX Re-Q module to provide a remote turn on sense for the amplifier and also to supplement the loss of bass in the stock Bose equalization scheme.
    The stock Bose amplifier is located in the driver's side rear trunk area in the opposite side of the stock battery location. To get to the amplifier you unscrew the 2 black plastic cargo retainers and pry out the two black plastic trim "plugs" with a flathead screwdriver on the driver's side trunk carpet area. Then pry the two black plastic trim pieces surrounding the metal cargo hooks in the lower black plastic piece below the trunk opening. Once the two trim pieces are removed surrounding the metal cargo hooks you can pull directly up on the black plastic piece covering the trunk latch and it will easily remove. Now, you can fold the trunk carpeting covering the amplifier forward towards the rear seats. The Bose amp has 4 plugs (see attached picture) and the plug nearest the rear of the car is the one you need to splice into for the Sub output signal. The line-level signals from the Bose amp are not amplified (there is a separate amp for the subwoofer in the cargo shelf area), the Subwoofer + signal is the Blue with White stripe wire. The Subwoofer - signal is the Light Green with Black stripe wire.
    The MTX Re-Q supplies the amplifier turn-on wire (typically blue) by monitoring the signal coming off the front full range speaker signals. Left Front full range door + signal is Tan, - is Gray. Right Front full range door + signal is Light Green, - is Dark Green. 12V Constant and Ground are wired directly to the battery in the trunk.
    The stock subwoofer is disconnected but still in the stock location.
    The additional bass provided by the aftermarket subwoofer and amp is powerful but not overpowering. I found the addition to be worthwhile and fairly easy to install. The hardest part was researched the stock wiring codes.
    Let me know if you have any questions.
    Maeztro's Avatar
    Maeztro is offline Cadillac Owners Fanatic
    Automobile(s): CTS '08
    Apr 2008
    Tampa, FL
    215
    Re: Subwoofer Install with Bose Amp and NAV
    Got an pics of the aftermarket amp installed?
    ibiza1010's Avatar
    Oct 2007
    28
    The amp was installed on the back of the sub enclosure so that I can easily take the whole thing out in one piece if I need the extra trunk space. This picture shows the amp on the opposite side of the enclosure before all the wiring was cleaned up.
    rich66's Avatar
    rich66 is offline Cadillac Owners Member
    Automobile(s): Cadillac 2008 CTS
    Dec 2007
    Austin, Texas
    99
    Wow thanks for that!
    Pyromaniac is offline Cadillac Owners Fanatic
    Feb 2008
    244
    I have a whole setup in my car w/ JL Z series speakers, a 10W7 (I wanted the 12W7, but the High Output box wouldn't fit, I'm considering switching to a 12W6v2 though because I have that in my old car and the sound is the best quality you can get at that level) and a 1000/1 for the sub and a 450/4 for the speakers.
    My setup takes up a good amount of my trunk, and my amps are in my spare tire well. Yours barely takes up any space, so that's great!
    Just a tip, if you're looking for a little bit more bass, remove the stock sub because it will give the bass an opening into the cabin.
    ngiardina's Avatar
    ngiardina is offline Cadillac Owners Connoisseur
    Automobile(s): CTS DI Fully Loaded, Magnaflow, CAI, F1 Tint, Rosen TVs
    Mar 2008
    Jersey
    35
    1,013
    Gentlemen, I am adding 2 Alpine Type R 12s pushed by 1000w of digital power. Also, I paid for the fold-down rear seat, and intend to use it. Next week or two until I debut the Sapele trimmed enclosure.
    Feb 2008
    244
    Quote Originally Posted by ngiardina View Post
    I used 2 own a single Alpine Type R in my 99 Maxima before I switched it out with a JL W6v2.....The type R's are a great sub for the money.
    WhtDmnd04CTS's Avatar
    WhtDmnd04CTS is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 Cadillac CTS4, Performance Collection, NAV, AWD
    Feb 2007
    875
    i had 2 Type R's in my old Grand Cherokee pushed by a Hifonics Brutus 1500W amp
    i didn't have it anywhere near turned up and it was still insanely loud
    pyro and ngiardina- you dynmat your trunk at all?
    Feb 2008
    244
    Yeah, my trunk and my doors are completely dynomatted.
    ngiardina's Avatar
    Mar 2008
    Jersey
    35
    1,013
    I will be dynomat ultra-ing the floor of the trunk and the underside of the lid.
    ianrwesley is offline Cadillac Owners Member
    Sep 2007
    7
    Where did you find the stock wiring codes?
    I would like to add speakers/sub/amp but would like to get at the pre-amplified inputs for the amps.
    Netsloth is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Aug 2007
    Jacksonville, FL
    42
    61
    What did you use for the remote turn-on for the amp? Also, where did you go through the firewall to get the power to the trunk?
    ngiardina's Avatar
    Mar 2008
    Jersey
    35
    1,013
    Quote Originally Posted by Netsloth View Post
    He used the MTX reQ, which autosenses signal coming through the speaker wires, but the remote lead is the switched 12v power wire at the factory amp. Probe each one of the wires until you get 12 to 14 volts dc with the key and radio on, and 0 volts dc with them off.
    Firewall?? Power??? The battery is in the trunk.
  16. #14
    Aug 2007
    Jacksonville, FL
    42
    61
    Thanks for the info. I have a V, battery under the hood.
  17. #15
    ngiardina's Avatar
    Mar 2008
    Jersey
    35
    1,013
    I am pretty sure the battery is under the hood on all the gen 1 cars. This is the gen 2 forum, though. And wire codes will not transpose.
  18. Remove Advertisements
