Easy Radar Detector Installation
Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
Like Tree3Likes
2008-2013 Cadillac CTS General Discussion Discussion, Easy Radar Detector Installation in Cadillac CTS Second Generation Forum - 2008-2013; Installed my radar detector a couple days ago to the rear view mirror in about 5 minutes. Installation was very ...
    RustedElvis's Avatar
    RustedElvis is offline Cadillac Owners Fanatic
    Automobile(s): 08 Light Platinum CTS
    Jan 2008
    So Cal- one of the beaches
    34
    219
    Installed my radar detector a couple days ago to the rear view mirror in about 5 minutes. Installation was very easy thanks to a sleathcord (same as invisicord). My radar detector(Beltronics 965) will not work if it is not properly installed.
    Step 1: Remove wire harness plug from rear view mirror.
    Step 2: Remove plastic covering from the plug
    Step 3: Push ground with black wire on the top row, only wire on the top row.
    Step 4: Push 12v with solid yellow wire on the bottom row (3rd wire from the left)
    Step 5: Push the wire plug back into the rear view mirror, mount radar detector and start engine. Hardest part was taking the plastic cover off the wire harness. Detector powers on when the car starts and powers off immediately when the engine is turned off.
    http://s10.photobucket.com/albums/a1...t=100_3445.flv
    short video of power on/off of radar detector
    CTSM and mnmjack like this.
    Crackerzot's Avatar
    Crackerzot is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Jan 2008
    310
    Re: Easy Radar Detector Installation
    Great write up, I'm surprised nobody had the courtesy to thank you for it before me. I installed my detector in my '02 'Vette the exact same way, in terms of tapping into the mirror harness, with the exception that I made my own cord. It's the best solution as far as I'm concerned.
    thepiazza is offline Cadillac Owners Fanatic
    Oct 2007
    134
    I just recieved my new detector (Passport 9500i) and was hoping to get some feedback. I see you have had yours installed for a month now any problems? Looks like your installation is the easiest to follow and would like to set mine up the same way. I also see you placed your detector behind all those dots on your windshield does that cause any interference?
    Jan 2008
    34
    219
    ^Yeah it's been a little over a month and I've had no problems whatsoever. I did move the detector about an inch to the left and down. Not because it was causing interference but to hit the mute button easier. Surprisingly I've only clocked two motorcycle cops in a month and I always get those speed safety radar signs that tell you have fast you're going. There are a lot of those in my area.
    TSS's Avatar
    TSS
    TSS is offline Cadillac Owners Connoisseur
    Automobile(s): 07 Lade & 06 SRX (Gone); 2010 Enclave CXL; 2010 MKS Ecoboost
    Jun 2006
    3,673
    Nice write up!
    SpeedracerZ06 is offline Cadillac Owners Member
    Automobile(s): 08 CTS-4 DI FE2
    Jan 2008
    43
    30
    I tapped the same wire but instead of doing it at the plug behind the rear view mirror, I tapped it up in the upper console area where the map lights and homelink are. I did this because the cable I had is stranded and won;t easily push into the back of the connector pins.
    You can trace the bundle of wires from behind the mirror up into the console. I cut the electrical tape that holds the bundle of wires together and tapped into the solid yellow for power. I used the homelink ground wire for my ground because it was easier to get to.
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by thepiazza View Post
    Placing a detector on the dot matrix area of the windshield is a bad idea because the suction cups will give away much quicker and you risk the detector falling and breaking.
    Also, As for mounting a 9500i in the same position you will have issues with the satellite signal going in and out.
    mnmjack likes this.
    greyghost04's Avatar
    greyghost04 is offline Cadillac Owners Connoisseur
    Automobile(s): '14 CTS 2.0 Luxury AWD, '14 SRX 3.6 AWD
    Apr 2004
    Chicago
    1,275
    Quote Originally Posted by tomm View Post
    tomm,
    That has always been my opinion too. Being you are in the business, I take your word as gospel. Thanks for the info.
    Oct 2007
    134
    tomm, thanks for the info it just seems if I bring the detector down below the mirror that I might not have a clear shot out the back, I'll have to look into it. Does anyone know off any other installs that don't adhere to the windshield (maybe the rear view instead) it's a pain putting my sunshield up every time.
    Ad Nauseum is offline Cadillac Owners Member
    Automobile(s): 2008 CTS DI
    Mar 2008
    Calgary, AB
    6
    CoolRe: Easy Radar Detector Installation
    Hey Elvis, how did you get the plug off the back of the mirror? I'm afraid I'm going to break mine. There's that clip that's on the driver's side but that doesn't seem to release it.
    Jan 2008
    34
    219
    Quote Originally Posted by Ad Nauseum View Post
    Just wiggle it out of there. It's hard but it will eventually come out. You could also try using a flat head screw driver to force it out as you push the clip in.
    Apr 2004
    Chicago
    1,275
    Quote Originally Posted by RustedElvis View Post
    Elvis,
    Thanks for your pics. Went to my mechanic and after viewing your post and pics, he was able to hard wire my detector.
    thanks again.
    Apr 2004
    Chicago
    1,275
    BTW,
    That plug is hard to get out. I dropped the center overhead console. It pops right down. The whole wire harness shown in the pics in this post are now exposed. Easy to pick out the yellow and black. There are 2 black grounds and either will work. Good luck.
  16. #14
    Bee iLL's Avatar
    Bee iLL is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Raven Black STS-V, 2010 Radiant Silver SRX Premium 2.8T
    Apr 2007
    Chicago
    34
    470
    I use this rear view mount in my Jeep for my beltronics sti but works with escorts also. I think valentine sells there own version of this mount. http://www.countryjoycrafts.com/350Z/escortmount.htm Not sure if it will work in the CTS, as I don't have one.
  17. #15
    Mr Snappy's Avatar
    Mr Snappy is offline Cadillac Owners Fanatic
    Aug 2008
    102
    ummm, you might want to check that again.
    The dot matrix area is not on the interior surface of the window, it is embedded in the glass. There is absolutely no difference in adhesion between that area and any other on the window.
    As far as the satellite signal, huh? this is not where the satellite gets its signal, that is in the fin on the rear of the roof.
  18. Remove Advertisements
