Easy Radar Detector Installation - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 49
Like Tree3Likes
2008-2013 Cadillac CTS General Discussion Discussion, Easy Radar Detector Installation in Cadillac CTS Second Generation Forum - 2008-2013; Mr. Snappy - the 9500i radar detector has GPS in it also as part of that product. That is what ...
  1. #16
    CTSing is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS DI AWD FE2 Loaded, 04 Expedition, 84 Camaro Z28 HO
    Apr 2008
    Pinckney, MI
    133
    Re: Easy Radar Detector Installation
    Mr. Snappy - the 9500i radar detector has GPS in it also as part of that product. That is what he is referring to. I got the 9500ci and the separate GPS module was mounted on the rear shelf at the rear window location. It is awesome.
  2. #17
    chris1268's Avatar
    chris1268 is offline Cadillac Owners Fanatic
    Automobile(s): 09 cts-v
    Apr 2008
    Chicagoland
    254
    Quote Originally Posted by RustedElvis View Post
    Installed my radar detector a couple days ago to the rear view mirror in about 5 minutes. Installation was very easy thanks to a sleathcord (same as invisicord). My radar detector(Beltronics 965) will not work if it is not properly installed.
    Step 1: Remove wire harness plug from rear view mirror.
    Step 2: Remove plastic covering from the plug
    Step 3: Push ground with black wire on the top row, only wire on the top row.
    Step 4: Push 12v with solid yellow wire on the bottom row (3rd wire from the left)
    Step 5: Push the wire plug back into the rear view mirror, mount radar detector and start engine. Hardest part was taking the plastic cover off the wire harness. Detector powers on when the car starts and powers off immediately when the engine is turned off.
    http://s10.photobucket.com/albums/a1...t=100_3445.flv
    short video of power on/off of radar detector
    Great write up-thanks. just installed mine. Although it took me about 15 minutes to get the wiring harness off the first time all was good. thanks again
  3. #18
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,779
    If you lower the unit so that it is not in the shaded area of the windshield you will notice a significant improvement in reception both front and rear.
  5. #19
    Bandit1's Avatar
    Bandit1 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 ATS 3.6 RWD Premium
    Oct 2008
    Ashburn, VA
    497
    Quote Originally Posted by Bee iLL View Post
    I use this rear view mount in my Jeep for my beltronics sti but works with escorts also. I think valentine sells there own version of this mount. http://www.countryjoycrafts.com/350Z/escortmount.htm Not sure if it will work in the CTS, as I don't have one.
    That is the mount that I use on my mirror and it works great. Perfect install and location.
  6. #20
    Mrdestination28's Avatar
    Mrdestination28 is offline Cadillac Owners Member
    Automobile(s): 14CTSV-Sport/13ATS 3.6L/09CTS 3.6 DI/06Escalade ESV Platinum
    Sep 2006
    Houston, TX
    51
    Does anybody know if this can be done with a Valentine One? Is there a way to connect it through the rear view mirror and if so, do I have to buy one of the specific power cables on their web site?
  7. #21
    GizmoQ's Avatar
    GizmoQ is offline The Last Good Gremlin
    Automobile(s): 06 XLR-V and 96 Eldorado ESC-V -- One day ;)
    Mar 2007
    St Louis, MO
    2,653
    Quote Originally Posted by Mrdestination28 View Post
    Yes you can. Yes there is. No you don't. I have a friend who works for the phone company and with one quick look at the connector for the V1 he said I could just take any phone cord, strip the outer layer and use the wiring in there to connect to power. I told him I wanted something better so he hooked me up with a regular phone cord connector that he crimped onto 16 gauge wires and I used it for my power. I stashed mine in the cubby for the HomeControl remote and used the power supplied there.
  8. #22
    LEOinDC's Avatar
    LEOinDC is offline Cadillac Owners Fanatic
    Automobile(s): '08 CTS4 DI Perf Crystal Red, '12 CTS-V Coupe Black Diamond
    Dec 2007
    Washington DC
    66
    110
    Thumbs upRe: Easy Radar Detector Installation
    I tried the plain mirror mount from Country Joy Crafts and the Invisicord harness on a new Beltronics GX65.
    The mirror mount is the 23mm version and the wiring harness is the 8" version. It all fits quite snugly.
    It's a nice variation on the suction cup windshield mount.
    Here is the finished installation that took 15 minutes with just the supplied allen wrench:
  9. #23
    tedcmiller is offline Cadillac Owners Connoisseur
    Apr 2004
    1,827
    The fin antenna on the rear of the roof is for receiving XM radio, not for the GPS. In both cases, the signal is receive only (inbound) - nothing is transmitted (outbound). OnStar does transmit when you ask for certain things or in the event of a crash, but this is not the same antenna as the GPS or the XM radio. It is the cellular antenna.
    Placing the RADAR detector behind the dots on the windshield will reduce the signal strength from both the microwave and LASER guns. It probably will not reduce the signal strength enough to make the unit inoperable, but for those who want maximum performance, do not place the unit behind the dots.
  10. #24
    Bandit1's Avatar
    Oct 2008
    Ashburn, VA
    497
    Quote Originally Posted by LEOinDC View Post
    Great pics Leo. I have the same setup with my Escort Passport. Very custom, perfect location, and don't have to worry about it falling off.
  11. #25
    Mr Snappy's Avatar
    Mr Snappy is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Aug 2008
    102
    Quote Originally Posted by tedcmiller View Post
    Nonsense.
    I have had my Escort mounted on the dots for a year and it gets great reception for all threats. It also hides the unit from thieves and it almost impossible to see from the outside of the car. Hanging it from the bottom of the rear-view mirror will be visible to thieves imediately.
    You are also wrong about the fin/antenna on the roof. It serves 3 systems, XM, OnStar GPS, an OnStar Cell.....
    Here is the link WITH pictures
    http://www.cadillacforums.com/forums...-question.html
  12. #26
    v vette is offline Cadillac Owners Member
    Automobile(s): SRX
    Aug 2009
    11
    Anyone have a tip on how to remove the back of the power cable (mirror power supply cable). I want to use the invisicord and jam the connectors in the back of the cable but there is a cap on it. Can this cap/cover be removed, if so how? Thanks
  13. #27
    greyghost04's Avatar
    greyghost04 is offline Cadillac Owners Connoisseur
    Automobile(s): '14 CTS 2.0 Luxury AWD, '14 SRX 3.6 AWD
    Apr 2004
    Chicago
    1,275
    Go back to the links in this thread.
  14. #28
    embassured is offline Cadillac Owners Member
    Aug 2007
    90
    A silly, simple trick but worth the piece of mind when, and if, the suction cups fail...
    I looped a piece of fishing line from the detector's suction cups mount and attached it to the sun visor securing bracket. Obviously, I've learned this through experience. Now, when your cups fail - you'll arrive back to see your detector swinging from the visor clip vs. hanging by the wiring or worse, crashed on your floorboard.
    Good luck!
    Eric
  15. #29
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,779
    I've been using the joycrafts (sic) mount for about a year now and love it. It mounts the detector much more firmly than the suction cup mount. it also sits at a better level than the suction cups. With the On* mirror the detector doesn't really show itself off. I'm fortunate in that I have always used the Passport Solo so no wiring is needed and a good set of AA batteries last about 9-12 months.
  16. #30
    6spdg37s is offline Cadillac Owners Member
    Aug 2013
    30
    great write-up I am orderin the invisicord now.. I assume there is no difference between the 9,10 models and the 13 models correct?
  17. Remove Advertisements
