Passenger Airbag Light?
Results 1 to 13 of 13
2008-2013 Cadillac CTS General Discussion Discussion, Passenger Airbag Light? in Cadillac CTS Second Generation Forum - 2008-2013; Just accepted delivery today on FE1 DI and noticed the airbag light does not turn off. The light correctly indicates ...
    dog1526 is offline Cadillac Owners Member
    Automobile(s): Cadillac '08 CTS
    Nov 2007
    11
    Just accepted delivery today on FE1 DI and noticed the airbag light does not turn off. The light correctly indicates passenger airbag off/on but stays illuminated in yellow. My dealer stated this is normal, but would check with service. Anyone know if it continually stays on while vehicle is running, and if so can you turn off the light once it does it's check?
    NOT ON MY WATCH's Avatar
    NOT ON MY WATCH is offline Cadillac Owners Enthusiast
    Automobile(s): GM bought back my lemon 2008 CTS
    Dec 2007
    638
    Re: Passenger Airbag Light?
    Mine stays on too - I don't have my owner's manual on me to confirm (and GM's site doesn't have the digital version of the owner's manual for 2008s up yet), but because it's an automatic sensing type of system, I'll bet they meant for it to stay on at all times.
    spaceman78 is offline Cadillac Owners Enthusiast
    May 2005
    887
    CoolRe: Passenger Airbag Light?
    my 2008 cts when somebody sits on the passager side the light comes on.......when nobody sits there it stays off.....my btother chevy truck isthe same and my mothers buick is the same way to......it should go off...
    Dec 2007
    638
    Hmm...maybe I'll axe kick the seat a few times and see if that clears it up.
    Macdad is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 08 CTS
    Nov 2007
    Conroe, TX
    119
    Quote Originally Posted by spaceman78 View Post
    Just the opposite for my 08 CTS.
    ddawson is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS PREMIUM SEDAN 3.6 RWD
    Oct 2007
    1,019
    The message goes off, when someone or something occupies the seat, that is heavy enough to activate it. That the way the system operates. When someone sits in the seat and buckle up, the message will go off.
    rebelduke's Avatar
    rebelduke is offline Cadillac Owners Member
    Automobile(s): '17 XT5 Platinum; '15 Audi Q5
    Sep 2007
    Anderson, SC
    Mine is lit and goes off when there is a passenger occupying the seat.
    JohnnySpagz is offline Cadillac Owners Member
    Automobile(s): 2016 ATS-V coupe
    Nov 2007
    New Jersey
    84
    The light remains on when the seat is unoccupied.
    Zymurgy's Avatar
    Zymurgy is offline Cadillac Owners Connoisseur
    Automobile(s): 2017 XT5 and 2014 Corvette
    May 2007
    Richardson, TX
    1,180
    From pages 3-34 and 3-35 of the owners manual:
    Passenger Airbag Status Indicator
    Your vehicle has the passenger sensing system.
    Your instrument panel has a passenger airbag status
    indicator.
    When you start the vehicle, the passenger airbag status
    indicator will light ON and OFF, or the symbol for on
    and off, for several seconds as a system check. If you
    use remote start to start your vehicle from a distance,
    if equipped, you may not see the system check.
    Then, after several more seconds, the status indicator
    will light either ON or OFF, or either the on or off symbol
    to let you know the status of the right front passenger’s
    frontal and seat-mounted side impact airbags.
    If the word ON or the on symbol is lit on the passenger
    airbag status indicator, it means that the right front
    passenger’s frontal airbag and seat-mounted side impact
    airbag are enabled (may inflate).
    If the word OFF or the off symbol is lit on the passenger
    airbag status indicator, it means that the passenger
    sensing system has turned off the right front passenger’s
    frontal airbag and seat-mounted side impact airbag.
    See Passenger Sensing System on page 1-64 for more
    on this, including important safety information.
    If, after several seconds, both status indicator lights
    remain on, or if there are no lights at all, there may be a
    problem with the lights or the passenger sensing
    system. See your dealer/retailer for service.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    It varies a bit from model to model.
    The ones with the indicator on the mirror display the status of the air bag all the time. Whether it is on or off, one of the lights is always lit.
    The newer overhead console indicators work in a similar way but they use icons to indicate the status. I am not used to looking at them so I can't say off the top of my head. I'll pay closer attention and report back if you'd like.
    I think the excerpt from the owner's manual should clear it up for you.
    Oct 2007
    1,019
    The light will never go OFF, but the message OFF, will change to ON when someone sits in the passenger seat and buckle up.
    Spghutch is offline Cadillac Owners Member
    Automobile(s): 2010 CTS
    May 2013
    1
    I have a 2010 CTS purchased in Canada. Recently relocated to the US and have to import my CTS. One of the requirements is that the passenger air bag noticiation must state "Passenger Air Bag Off/On" where as in Canada, only tthe symbols must be activated. Any thoughts on how complicated it is to get the "Passenger Air Bag Off/On" wording activated in order to be US compliant?
    MrTwobit is offline Cadillac Owners Member
    Automobile(s): 2010 CTS Premium AWD Sedan
    Jun 2014
    65
    15
    OK, for everyone telling what "their light does", here is what the manual says for a 2010.
    "When the vehicle is started, the
    passenger airbag status indicator
    will light the words ON and OFF,
    or the symbols for on and off, for
    If the vehicle has remote start, and it
    is being used to start the vehicle
    from a distance, you may not see
    the system check. Then, after
    indicator will light either ON or OFF,
    or either the on or off symbol, to let
    passenger frontal airbag.
    lit on the passenger airbag status
    front passenger frontal airbag is
    passenger sensing system has
    frontal airbag.
    indicator lights remain on, or if there
    passenger sensing system. See
    {WARNING
    If the airbag readiness light ever
    comes on and stays on, it means
    that something may be wrong
    with the airbag system. To help
    avoid injury to yourself or others,
    have the vehicle serviced right
    away. See Airbag Readiness
    Light on page 4‑21 for more
    information, including important
    safety information.
  16. Remove Advertisements
