Put in LED DRLs and fogs
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 46
Like Tree3Likes
2008-2013 Cadillac CTS Appearance Mods Discussion, Put in LED DRLs and fogs in Cadillac CTS Second Generation Forum - 2008-2013; Before DRL Before fog light After LED DRLs After LED fog and DRL (hard to tell difference in fogs because ...
    blkillac is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS Premium
    Mar 2012
    Clemson SC / Virginia
    126
    Before DRL
    Before fog light
    After LED DRLs
    After LED fog and DRL (hard to tell difference in fogs because the first fog shot was in the garage where it is dark and second was outside)
    Let me know what you guys think! It was a pretty quick (30 minute project) and easy to do install that I think makes a big difference.
    KLX's Avatar
    KLX
    KLX is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Coupe
    May 2013
    45
    105
    Re: Put in LED DRLs and fogs
    What bulbs did you use for the fogs and was it a pain to get the fog bulbs out?
    Mar 2012
    126
    Quote Originally Posted by KLX View Post
    No it wasnt a pain at all just a simple clip once they were exposed. Like i said the whole install took about 30 minutes thats the fogs and DRLS.
    I used a super white LED H11 bulb with the equivalence of a 5.9k HID bulb.
  5. #4
    KLX's Avatar
    KLX
    May 2013
    45
    105
    Thanks so you can get to the fogs from under the car, at the point its just twist pull and disconnect the wires?
  6. #5
    Mar 2012
    126
    Im not sure if you can from just under the car I took off the whole bumper to remove the headlight housings since I was switching out the DRL OEMs with LEDS.
    You may be able to get to it from the bottom if you take the 6 clips holding the bottom of the bumper to the car off.
    To take off the whole bumper really isnt as hard as it seems 6 clips under the bumper
    2 clips and a 10mm bolt on the inside of the fender next to the tires
    the 6 clips on top of the weather stripping
    2 clips and 2 bolts holding the bumper to the radiator housing. Thats it.
  7. #6
    eye4aneye83's Avatar
    eye4aneye83 is online now Cadillac Owners Fanatic
    Automobile(s): 2011 CTS4 Premium Black Raven, 2010 SRX4 Premium White Diamo
    Oct 2011
    Southeast Florida
    33
    107
    Looks great, I like how you can change the color of the drl. Do you happen to remember the oem bulb number for the drl? Thanks.
  8. #7
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    Did you paint your grill? I do t see the normal Grey it comes with around the chrome and what not. I painted mine black and left the chrome
  9. #8
    Mar 2012
    126
    Quote Originally Posted by eye4aneye83 View Post
    The OEM DRL bulb number is 5201 but im pretty sure 5202 fits as well.
    Quote Originally Posted by arw1510 View Post
    I did paint the front grill grey areas to black so it matches the black paint of the car.
    Before
    After (This was before I fixed the condensation in the headlight)
  10. #9
    DaddysCaddy13 is offline Cadillac Owners Member
    Automobile(s): cts
    Oct 2013
    43
    65
    Nice project,might look into it myself
    Sent from AutoGuide.com Free App
  11. #10
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,502
    So you wanted blue DRL's?
  12. #11
    Mar 2012
    126
    yes matches my calipers.
    midnite_tm likes this.
  13. #12
    DarienA is offline Cadillac Owners Member
    Automobile(s): CTS 3.6
    Jun 2013
    MoCo MD
    46
    19
    Where in VA are you? Interested in possibly getting together with a fellow CTS owner and helping with some bulb swaps?
  14. #13
    jimmie jam's Avatar
    jimmie jam is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS LUXE
    Oct 2007
    FORT LAUDERDALE
    336
    Any areas to tape and protect when removing and installing the cover and is it a two man job? Thanks.
  15. #14
    Mar 2012
    126
    Quote Originally Posted by DarienA View Post
    I live in Roanoke VA and I could most certainly help you if need be!
    Quote Originally Posted by jimmie jam View Post
    No need to tape anything off when removing the bumper to swap the lights. I would set the bumper on something light to keep it from getting scratched up or anything. If you are talking about painting the calipers then yes you need to tape off quite a bit of stuff. Its a one man job to remove, but it may be beneficial to have someone help you put it back on when it comes to holding the bumper in place and putting the bolts in place.
  16. #15
    Slee_Stack is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS Wagon RWD Premium, Used to own 2005 STS 1SG
    Jan 2010
    GA
    324
    Any picture of the 10mm bolt in the wheel well to remove? I couldn't find it when I went to swap my DRLs.
    I like all your mods, but be wary that blue (or red) lights on a vehicle front are illegal. Its limited to emergency vehicles. Hopefully you won't be harassed.
  17. Remove Advertisements
