Lowering 2010 3.0 sedan?
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Hammerhead100
2008-2013 Cadillac CTS Appearance Mods Discussion, Lowering 2010 3.0 sedan? in Cadillac CTS Second Generation Forum - 2008-2013; I want to lower my 2010 CTS but every Eibach kit I've looked at states its for the 3.6. I ...
    Michelle's Cadi is offline Cadillac Owners Member
    Automobile(s): 2010 cadillac cts
    Aug 2013
    I want to lower my 2010 CTS but every Eibach kit I've looked at states its for the 3.6. I talked to the guys at autoanything.com and they are not sure if the springs will work on the 3.0. Which kits are you guys using to lower the 3.0?
    Thanks in advance.
    Hammerhead100's Avatar
    Hammerhead100 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS Performance Sedan
    Sep 2012
    South Carolina
    160
    Re: Lowering 2010 3.0 sedan?
    I can't imagine that there would be any differences in basic suspension from 3.0 to 3.6
    Someone who knows for sure should chime in here shortly. It is odd that they are only listed for 3.6
    I have the Eibach Pro Kit on my 3.6 with FE2 suspension and love them.
    Just be aware: Vehicles Equipped With Self-leveling Rear Dampers (FE3) Must Replace With Non Self-leveling Dampers Such As FE1 Or FE2 Dampers To Properly Lower.
    D VADER likes this.
    Aug 2013
    Thank you for your response; I was thinking the same about the suspension between the two but wanted to make certain. The curb weight between the two is less than 10lbs, which adds credence to my belief the use the same suspension. How do i tell if i have F3?
    Sep 2012
    South Carolina
    160
    There is a sticker on the underside of the spare tire cover in the trunk. It lists all of the build codes for your car.
  7. Remove Advertisements
