2010 CTS grill replacement
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By C "T" ess
2008-2013 Cadillac CTS Appearance Mods Discussion, 2010 CTS grill replacement in Cadillac CTS Second Generation Forum - 2008-2013; Hi, just joined the forum. Just got a 2010 CTS sedan and had pulled too far forward in my garage ...
    a1fla is offline Cadillac Owners Member
    Automobile(s): 2010 CTS
    Oct 2013
    3
    Hi, just joined the forum. Just got a 2010 CTS sedan and had pulled too far forward in my garage and had my sons skateboard mess up my grill. Ouch.. so mad at myself. Anyway, does anyone know if the whole bumper cover has to come off to replace the grill? Or can it be done from the top after removing the plastic cover and brackets to the radiator. Thanks in advance!
    json3144's Avatar
    json3144 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS4 Coupe Black Ice
    Jan 2011
    St Louis MO
    35
    83
    The bumper will need to be released at the top and within the wheel arches, takes about 5min total. From there you can lower it forward and work on the grill from behind without taking it completely off the car from below.
    How bad is your grill? If not cracked you can consider plasti dip to customize and hide any blemishes.
    There are also some reasonably priced after market grills, black, chrome, etc from about $200 online.
    Hope that helps.
    Oct 2013
    3
    Re: 2010 CTS grill replacement
    I cracked the vertical chrome pieces, they fell out, I got an aftermarket replacement, so you are saying I should take out the first few black plastic push pin at top of wheel well only? Thanks for your reply
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    Quote Originally Posted by a1fla View Post
    There's a how to on the forum and a video on YouTube on how to remove the bumper. Its very easy. I had mine off last weekend painting my grill. Its probably easier to take the whole bumper off to work on it. I think its only like 8 clips on the bottom. Don't forget the two bolts inside the wheel wells
    Oct 2013
    3
    thanks for the help guys, I got the bumper cover off and installed new grill. Now I need a new crest and wreath
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Can't you use the crest and wreath from the old grill? You should be able to scrape the old tape off and put new tape on and reapply it. Otherwise you purchase them pretty cheap on ebay.
    If you have a problem with re-taping send me a pm.
    tinman likes this.
  9. Remove Advertisements
