2008 cts awd wheel questions before i order
Results 1 to 5 of 5
2008-2013 Cadillac CTS Appearance Mods Discussion, 2008 cts awd wheel questions before i order in Cadillac CTS Second Generation Forum - 2008-2013; Hey guys, i have a 08 cts awd and im looking at buying new wheels for it as well as ...
    Drew1021 is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2013
    24
    4
    Hey guys, i have a 08 cts awd and im looking at buying new wheels for it as well as lowering it on h&r springs. The wheels im looking at are 2014 stock camaro ss wheels. We have a set on our 2014 ss at work and i really like them and id like to put them on the cts. Im just not sure as of the size i should do, as well as if the offset is correct. Im either looking at 20x10 with a +23mm offset on all 4 corners. or 20x9 with a +27mm offset on all 4 corners. Next, what tire should i use? im thinking at 285/40/20 on all 4.
    http://www.phastekperformance.com/20...1-20x10-bg.htm
    those are the wheels...
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,111
    Re: 2008 cts awd wheel questions before i order
    I believe the correct sedan offset is about 50 mm (48?). Same as the wagon. Different for the coupe.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Is the center bore correct?
    tinman's Avatar
    Jul 2006
    9,111
    dunno
    Automobile(s): none
    Jan 2013
    24
    4
    the center bore is correct. should i use a spacer for the rear since the offset is different?
  8. Remove Advertisements
