CTS-V Headlight Swap
Results 1 to 10 of 10
2008-2013 Cadillac CTS Appearance Mods Discussion, CTS-V Headlight Swap in Cadillac CTS Second Generation Forum - 2008-2013; I am just about ready to pull the trigger on buying a pair of CTS-V Headlights with the black housing. ...
    dm16raiders's Avatar
    dm16raiders is offline Cadillac Owners Member
    Automobile(s): 2008 CTS DI
    Apr 2013
    Indiana
    23
    53
    I am just about ready to pull the trigger on buying a pair of CTS-V Headlights with the black housing. It is just a plug-and-play correct? I have an 08 CTS with the separate High and Low beams.
    GProdigy's Avatar
    GProdigy is offline Cadillac Owners Fanatic
    Automobile(s): cts
    Aug 2011
    29
    320
    Re: CTS-V Headlight Swap
    Quote Originally Posted by dm16raiders View Post
    yep..just plug and play...I did it a month or so ago here's the tread
    http://www.cadillacforums.com/forums...s-upgrade.html
    I took out the DRL fuse, b/c everyone else said to do that. Not sure why its necessary, but I did it just incase. no problems.
    Apr 2013
    Indiana
    23
    53
    Is it correct that the DRL's function through the Low/High Beam light and not the LED box by the turn signals?
    GProdigy's Avatar
    Automobile(s): cts
    Aug 2011
    29
    320
    they function in the box under the turn signals...which is in the center.
    you can search to see if someone did the swap without pulling the fuse..
    but other than that its pretty straight forward...b/c the HID ballast is built into the light...there's only one plug to connect the car and the light
    noshelter is offline Cadillac Owners Member
    Automobile(s): 08 CTS
    Oct 2013
    30
    my question is the bulbs. since i have the base halogen's, it has a different wire connector/harness to connect to the new headlight housings that have HID bulbs/ballasts dosn't it? also, how did you get your daytime running lights (above the projector low beams) to work normally?
    GProdigy's Avatar
    Automobile(s): cts
    Aug 2011
    29
    320
    THis is my car....i was just showing u were the DRL's were in the picture above.
    They ballast is part of the light as a whole so you do not have to install it separately. literally one plug to connect the light
    My DRL's are always off.
    the car's lights still turn on automatically, They also do a sequence when the door is unlocked
    Oct 2013
    30
    i've seen people that got the DRL's to work normally though. but since some say you have to pull out the DRL fuse, i don't see how the DRL's can work at all. the guy with the silver car above has the DRL's working. I have my new lights and i'm ready to put them in, but yea i want the whole thing to function properly
    Pdabs's Avatar
    Pdabs is offline Cadillac Owners Enthusiast
    Automobile(s): CTS4
    Dec 2011
    NJ
    33
    600
    Quote Originally Posted by noshelter
    Drl's won't work normally. If you keep the fuse in, your lights will be all the time. The wiring is different between the hid and non hid lights.
    The silver car is not a conversion. It was shown as an example of how Drl's look.
    Oct 2013
    30
    well that's unfortunate...there has to be some way! i actually thought the regular halogen housings had their own version of the DRL; i thought the lowbeam acted as the daytime running light but i might be wrong. so you've never gotten your DRL's to work on your black CTS? i just bought expensive bulbs for them too haha
    i read somewhere on another thread that someone had ran a new wire to make them work, but for the life of me i can't find the thread anymore. no idea how to attempt that addition.
    blkillac is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS Premium
    Mar 2012
    Clemson SC / Virginia
    126
    Are they straight plug and play if I have stock HID lights? Will everything still work or will the DRL's not work for mine as well?
  13. Remove Advertisements
