Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: Bulb model for DRLs and Front Turns on CTS w/OEM HID
    newlinux is offline Cadillac Owners Member
    Automobile(s): 2010 Black Raven CTS4 Premium
    Mar 2010
    99
    What are the bulb model #s? I was thinking of replacing the DRLs with something brighter to match the rest of the lighting and the turns with LEDs. Called cadillac parts and they didn't even know the bulb number. Anyone recommend any LED DRLs and Turn signals for this car trim?
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,391
    Re: Bulb model for DRLs and Front Turns on CTS w/OEM HID
    Try this site for information:
    http://www.sylvania.com/en-us/applic...s/lrgmain.aspx
    Marv
    Black'10CTS4 is offline Cadillac Owners Fanatic
    Automobile(s): '10 CTS4 Prem 3.6DI, '08 CTS4 Prem 3.6DI, '00 STS
    Sep 2012
    37
    104
    There's a couple write ups with before and after pics about this in the CTS-V forum.
    http://www.cadillacforums.com/forums...-pictures.html
    http://www.cadillacforums.com/forums...ml#post2046805
    I ordered the Hoen H11 Xenonmatch and the Cree 5202 LEDs today.
  5. #4
    is250sp's Avatar
    is250sp is offline Cadillac Owners Enthusiast
    Automobile(s): 2012 CTS Coupe Premium RWD
    Oct 2012
    657
    It's all about getting the correct socket which is H16 for the DRL's. I got the 30w Cree on ebay for about $50 and they are really bright. I do see they have 50w now.
  6. #5
    Mar 2010
    99
    Quote Originally Posted by Tbbt View Post
    Marv
    That doesn't quite give me enough information for the turn signals. Not sure what that model # is.
    Quote Originally Posted by Black'10CTS4 View Post
    I have the Hoen H11 Xenonmatches (had them for 3+ years, one finally burned out). Might just get another one. Contemplating HID. That's what got me looking at all this again... These links don't mention the amber turn signals, however, or perhaps I missed something. I want to replace those with LEDs as well.
    Quote Originally Posted by is250sp View Post
    The above post mentions 11W. You got 30W. What wattage do you recommend and why? I just want them to last a long time and be whiter.
    Thanks everyone for your help.
  7. #6
    is250sp's Avatar
    Oct 2012
    657
    I don't have any recommendations as it depends on how bright you want and how much you want to spend. I bought the 30w because it had the most wattage at that time and $50 seemed like a decent price. I am very happy with it. If I had to buy it now I would probably go with the 50w.
  8. #7
    Sep 2012
    37
    104
    i did see in one of those threads that an led turn signal will blink very fast because the low resistance makes the car think the bulb is burned out. decided to keep mine stock.
  9. #8
    Mar 2010
    99
    Yeah, I figured as much. I assume to get it work right I'd have to add resistors. I had the same problem in one of my other cars, however in that car I just replaced the flasher with a model that doesn't increase the blink rate on low resistance. I don't think I can do that on this car, but adding resistors should help, and these days you can buy LEDs with extra resistance built in (for some bulb types).
  10. #9
    Sep 2012
    37
    104
    So, this weekend I installed the LED lights from that ebay link and I would seriously recommend going with a different brand.
    I spent half an hour trimming excess plastic off the bulb so the connector could plug in. When I finally got it installed, the lights are barely bright enough to be seen. They are visible only at certain angles but 90% of the time, it looks like the lights are off.
    I found some 360 degree LED's that I'm gonna try next so we'll see what happens.
  11. #10
    Jul 2013
    5
    Wow very helpful post! I was also going to purchase those same bulbs. Thanks for the warning!
  12. #11
    Mar 2010
    99
    Crap, that's what i bought... Hmm, not even worth trying?
  13. #12
    is250sp's Avatar
    Oct 2012
    657
    Here's the one I got on ebay. They fit perfectly and really bright. They are from china so it took awhile to deliver http://www.ebay.com/itm/2x-CREE-SMD-...E:L:OC:US:3160
  14. #13
    Sep 2012
    37
    104
    Yeah, IDK if you want to try them or not but the installation hassle was not worth it for me. weather permitting, I'll take some pics for comparison so you can see what they look like.
  15. #14
    Sep 2012
    37
    104
    so heres the update, the link i followed was for 5W bulbs and our cars take 19W OEM. The seller I purchased then from (cortse) has emailed me and offered to give me a free upgrade to a higher wattage bulb! They have 16W bulbs so I'm gonna try them out. I'm thinking these should work out.
  16. #15
    Mar 2010
    99
    The ones I ordered (from that same seller) are supposed to be 11W, like the ones the other guy in the other thread used. Hopefully they will be okay then. Should have just gone with higher wattage in the first place... Just thought since those worked fine and looked good for the other guy they would work fine for me...
  • You may not post replies
