Door projectors - Page 2
Page 2 of 9 FirstFirst 123456789 LastLast
Results 16 to 30 of 131
Like Tree39Likes
2008-2013 Cadillac CTS Appearance Mods Discussion, Door projectors in Cadillac CTS Second Generation Forum - 2008-2013; Sweet!...
  1. #16
    Bobby VW is offline Cadillac Owners Member
    Oct 2012
    12
    Sweet!
  2. #17
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    How do you orient how the projector will illuminate. Do you just twist the light so the image points to the front of the car or to the side of the car or any other position.
  3. #18
    jlpz's Avatar
    jlpz is offline Cadillac Owners Member
    Automobile(s): Silver 2011 CTS sedan Cts-V clone
    Feb 2013
    Northlake Il
    59
    Re: Door projectors
    You place it in the hole which is a snug fit and then you angle it where you want, then tighten the nut on the back side of the projector.
    once tight, they aren't going anywhere.
  5. #19
    CTSCHICK Guest
    Re: Door projectors
    I think one of those would look awesome shining down in the center of my trunk
  6. #20
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    i bought a set of the door projectors. since I knew I wouldn't be using the courtesy light any more, I simply drilled the mounting hole right through the center of the light housing. I then ran the wire to the bulb connector plug and soldered the wires there. The factory power plug still connects to the courtesy light like stock, so if I ever have to remove the projectors all I have to do is replace the courtesy light put in a bulb and go. By the projectors were a very cool mod and they look great.
    Tbbt, Tbbt and migs109 like this.
  7. #21
    DarkN1gh7 is offline Cadillac Owners Member
    Automobile(s): 2009 CTS
    Feb 2012
    23
    Re: Door projectors
    These things are dope! Just ordered a set, I went with the 4th gen instead of the 5th gen as my car is black on black and wanted the black housing and mount opposed to the gold. I believe it was only 38mm in length so I dont think clearance will be an issue.
    Second question: What if you wanted to put these on all 4 doors or doors without courtesy lights? After telling a buddy about them he wants to put some Chevy ones on his truck. I was thinking instead of tapping into the door light you could tap into the window motor lines instead but just the sound of that sketches me out. Maybe I am just overly cautions, someone more skilled in the electrical department care to help a brotha out?
  8. #22
    hngacurv is offline Banned
    Automobile(s): 2008 CTS4 3.6DI
    Apr 2013
    7
    Re: Door projectors
    Nice. I just may have to order up a set.
  9. #23
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    if you tap into the power window motor, one of two things will happen. Either the lights will stay on all of the time or will onl work when the windows go up or down.
    Quote Originally Posted by DarkN1gh7 View Post
  10. #24
    bronik90's Avatar
    bronik90 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Coupe - 3.6l DI AWD
    Aug 2011
    Pittsburgh, Pennsylvania
    27
    101
    Quote Originally Posted by Hammerhead100 View Post
    Very interesting... Here is a link to some nice ones
    http://www.automotivelightstore.com/...MP=1017GUQH9DK
    No need to pay more for the Oracle ones. They're identical to the ones you can get on E........ you know.
  11. #25
    pacman2011 is offline Cadillac Owners Member
    Automobile(s): Black 2008 CTS Premium
    Apr 2013
    28
    Re: Door projectors
    Mine just arrived from the E-Store....yeah! Total cost: 80$, or 20$ per door. Plus shipping (a whopping 5$).
    I will be doing the install either tonight (will be showing off my motorcycle at a biker meetup...so may not get to it), or sometime tomorrow right after lunch.
    Can't wait to get these installed and operational! Will post a very quick how-to with pictures for the 2008 CTS Premium. Will also do some Before / After shots.
  12. #26
    Mike Zucker is offline Cadillac Owners Member
    Automobile(s): CTS Coupe
    Dec 2010
    Miami, Florida, United States,
    57
    15
    Re: Door projectors
    Pacman - besides the ones for my CTS coupe, I just ordered a set with H.D. logo - was planning on mouting them in the outer corner of the saddlebag, so I get a bar-and-shield logo on the road at night ! :-)
  13. #27
    GProdigy's Avatar
    GProdigy is offline Cadillac Owners Fanatic
    Automobile(s): cts
    Aug 2011
    29
    320
    Re: Door projectors
    [QUOTE=jlpz;3252715]
    Quote Originally Posted by Cuest View Post
    $100? You can get these on ebay for much less. I have them installed on my '12 coupe and yes they are the same ones. If anyone is going to order them make sure you get the 4th or 5th generation ones. Those look like the older ones which large and long which makes them more difficult to install.
    They wanted $100 per door. I got mine for I think $25 for both sides. They do attract alot of attention.
    Do you have a link to the $25 set you used? I'll get them right now for that....
  14. #28
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    Just go on e store and do a search for Cadillac logo door projectors. I bought a pair for $18 and see no difference between them and the more expensive models. They went in easy and they work great. They are certainly the biggest bang for the buck I've had in a while
    Mike Zucker and Mike Zucker like this.
  15. #29
    blunted is offline Cadillac Owners Enthusiast
    May 2004
    NYC
    585
    Re: Door projectors
    I just installed mine yesterday, however the light is not visible at all during the day. Same deal for everyone else, or did I just get a weak set?
  16. #30
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    Re: Door projectors
    Quote Originally Posted by blunted View Post
    Think about it for a second. If you open your door during the day; on a car without the projectors, can you see the door courtesy lights come on? The key is that for you to be able to see the projection, the surrounding light has to be darker than the projected image.
    Tbbt and Tbbt like this.
  17. Remove Advertisements
